BanCoe Hypersonic June 13, 2016 Share June 13, 2016 On 6/13/2016 at 4:30 AM, nazerath said: Unfortunately that is right because the frame is made of tubular steel and the area that the screw touches is probably 4 mm max. Using a longer screw won't help unless I can extend it beyond the hollow steel onto the concrete wall. That is making this repair hard. Nowadays, quite rare to file door frames made of steel one.... unless maybe industrial space or some hospitals have them .... i wonder why...is it to prevent warping ??? but steel frame also must paint regularly if not rust if people or things banging againt it on regular basis unlike wood will just be dented but no need to worry of rust ↡ Advertisement Link to post Share on other sites More sharing options...
nazerath Turbocharged June 13, 2016 Author Share June 13, 2016 On 6/13/2016 at 4:34 AM, BanCoe said: Nowadays, quite rare to file door frames made of steel one.... unless maybe industrial space or some hospitals have them .... i wonder why...is it to prevent warping ??? but steel frame also must paint regularly if not rust if people or things banging againt it on regular basis unlike wood will just be dented but no need to worry of rustYa, I measured the screw, it's a m6x 8, even shorter than my estimation. Link to post Share on other sites More sharing options...
nazerath Turbocharged June 13, 2016 Author Share June 13, 2016 On 6/13/2016 at 4:24 AM, Kb27 said: I doubt the length is correct. If you can, remove it and measure, thickness and length is important. The screw is rated, #6, #8 or #10 in thickness. Length is usually 1 to 1.5 inch depending on the frame. There's flat-head concrete screw available, but I'm not sure if it can hold both hinge/steel frame and concrete together. If you're seeing a 1 cm length screw, it might have broken off, with the rest stuck inside. Are these concrete screws able to hold the concrete without a plug? Locally anyone sells them in longer length I'd 2 to 2.5" May just be the thing I need. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged June 13, 2016 Share June 13, 2016 Looks like the screws are designed to secure onto the metal door frame itself without protruding into the concrete wall. On 6/13/2016 at 4:38 AM, nazerath said: Ya, I measured the screw, it's a m6x 8, even shorter than my estimation. All of the door frames in my HDB BTO pigeon hole are metal. On 6/13/2016 at 4:34 AM, BanCoe said: Nowadays, quite rare to file door frames made of steel one.... unless maybe industrial space or some hospitals have them .... i wonder why...is it to prevent warping ??? but steel frame also must paint regularly if not rust if people or things banging againt it on regular basis unlike wood will just be dented but no need to worry of rust 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic June 13, 2016 Share June 13, 2016 My door where I added the 2nd hinge. Forgive the dirty grease. It prevents rusting and corrosion. On 6/13/2016 at 4:44 AM, nazerath said: Are these concrete screws able to hold the concrete without a plug? Locally anyone sells them in longer length I'd 2 to 2.5" May just be the thing I need. Concrete screw is meant to be used by drilling a hole and screw in direct to masonry, without having to add a wall plug. They may sell locally, you need to search for it at hardware shops, those more speciallized, not the local neighbourhood shops. I lifted the picture off Amazon. You can search Amazon for description and sizes. 1 Link to post Share on other sites More sharing options...
BanCoe Hypersonic June 13, 2016 Share June 13, 2016 On 6/13/2016 at 4:49 AM, Beehive3783 said: Looks like the screws are designed to secure onto the metal door frame itself without protruding into the concrete wall. All of the door frames in my HDB BTO pigeon hole are metal. Maybe my house very old one - all wood frame one - so far never had any warping issues or tilting issues (so far in 10 years ) 2 Link to post Share on other sites More sharing options...
nazerath Turbocharged June 13, 2016 Author Share June 13, 2016 Steel door frame comes ready n easy , wood ones need some skill to install so nowadays like Lego. 2 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 13, 2016 Share June 13, 2016 (edited) Nowadays new flats use metal door frame with timber door. The correct way of installing should be 2 hinges near the top of the door to prevent this sagging problem you are facing. And also, not all fire-rated doors are heavy nowadays. My company manufacture fire-rated doors. Edited June 13, 2016 by Fcw75 2 Link to post Share on other sites More sharing options...
Evillusion Supersonic June 13, 2016 Share June 13, 2016 wah bro?got discount for fellow mcfers anot? I maybe doing up my bedrrom doors this year end. Not fireproof ones..normal nyatoh can oredfy! On 6/13/2016 at 5:09 AM, Fcw75 said: Nowadays new flats use metal door frame with timber door. The correct way of installing should be 2 hinges near the top of the door to prevent this sagging problem you are facing. And also, not all fire-rated doors are heavy nowadays. My company manufacture fire-rated doors. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 13, 2016 Share June 13, 2016 On 6/13/2016 at 12:18 PM, Eviilusion said: wah bro?got discount for fellow mcfers anot? I maybe doing up my bedrrom doors this year end. Not fireproof ones..normal nyatoh can oredfy! Bedroom doors just go to Yontat at Eunos or Yi Seng at AMK. They are cheap nowadays. Paiseh, we only supply fire-rated timber door. 3 Link to post Share on other sites More sharing options...
Matrix0405 5th Gear June 13, 2016 Share June 13, 2016 (edited) On 6/13/2016 at 12:18 PM, Eviilusion said: wah bro?got discount for fellow mcfers anot? I maybe doing up my bedrrom doors this year end. Not fireproof ones..normal nyatoh can oredfy! Looking for toilet bifold. Any groupbuy/MO coming up for MCF? Suggestions for door repair: 1) Add a hing at the top. 2) Unscrew originas, add in toothpicks into holes and screw back the screws. Edited June 13, 2016 by Matrix0405 1 Link to post Share on other sites More sharing options...
Evillusion Supersonic June 13, 2016 Share June 13, 2016 Thanks for the head-up. no need paisay lar! Sure got other forummers interested and will support fellow mcfers, On 6/13/2016 at 12:28 PM, Fcw75 said: Bedroom doors just go to Yontat at Eunos or Yi Seng at AMK. They are cheap nowadays.Paiseh, we only supply fire-rated timber door. thinking of that too but eoy! On 6/13/2016 at 12:30 PM, Matrix0405 said: Looking for toilet bifold. Any groupbuy/MO coming up for MCF? 1 Link to post Share on other sites More sharing options...
lausai88 Hypersonic June 13, 2016 Share June 13, 2016 On 6/13/2016 at 2:56 AM, Jamesc said: These two things are exactly what my wife told me too. I think she must be a natural wood worker. very funny... rofl,,, 3 Link to post Share on other sites More sharing options...
Hotamp 3rd Gear June 13, 2016 Share June 13, 2016 On 6/13/2016 at 12:28 PM, Fcw75 said: Bedroom doors just go to Yontat at Eunos or Yi Seng at AMK. They are cheap nowadays. Paiseh, we only supply fire-rated timber door. Since we are at this topic of doors, anyone here has contact for a contractor who can install wooden door frame? my toilet door frame got attack by termites, some damages were done before I could call for a exterminator. does those doors contractors also supply and install door frames? 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 14, 2016 Share June 14, 2016 (edited) On 6/13/2016 at 2:37 PM, Hotamp said: Since we are at this topic of doors, anyone here has contact for a contractor who can install wooden door frame? my toilet door frame got attack by termites, some damages were done before I could call for a exterminator. does those doors contractors also supply and install door frames? I did asked two companies to quote for replacement of my main door, including door frame and metal gate. Both quoted abt $3k, includes hacking of existing door frame. 1) hohoengineering1976 at yahoo.com.sg - from an exhitbition at Expo. 2) enquiry at doctordoors.com.sg - from Ch5 Renovate show. Take some photos and measurement and send to them for quotation. Edited June 14, 2016 by Adrianli 1 Link to post Share on other sites More sharing options...
nazerath Turbocharged June 14, 2016 Author Share June 14, 2016 guys, Know where can I get these type of m6 x 8 screws apart from kelantan lane? About a pack of 100? Any nuts n screw shops you all know of? Link to post Share on other sites More sharing options...
Kusje Supersonic June 14, 2016 Share June 14, 2016 Try RS components. They can deliver to you too. sg.rs-online.com/ 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 14, 2016 Share June 14, 2016 On 6/14/2016 at 2:25 AM, nazerath said: guys, Know where can I get these type of m6 x 8 screws apart from kelantan lane? About a pack of 100? Any nuts n screw shops you all know of? There are a few shops at King's George Ave. Famous is Pan Sun. http://www.pansun.com/about-us.html There is also a shop at Northlink, Sembawang Drive. Ground floor, near to Stamford Tyres. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Simple home DIY repairs
Lee Sheng Auto - One Stop Auto Repair Centre! From accident repair & claims, spray painting, diagnostics, general repairs to servicing.
Car repair and maintenance
Car accident advice
Car accident advice
