NicholasYeo_101060 Neutral Newbie June 11, 2016 Share June 11, 2016 I am having an issue with my 07 WRX recently. When stopping at traffic light for a long time, my ABS light comes on intermittently and when it does, my voltmeter reading drops below 10 and my radio goes off. After a while the voltmeter reading will go up, the ABS light goes off and the radio comes back on. When moving off, the car feels like there is a loss of power momentarily and will lurch forward for a bit if the ABS light is still on. Once I hit normal speeds the problem disappears. Once in a while the Check Engine Light will come on too. I sent it to a workshop today, and I ended up paying $50 for them to just tell me that there is some part that is probably failing, but there is no way for them to know until there is a permanent light. As the car is going to be scrapped next year, I don't want to spend $$$ on a wild goose chase to fix this problem. But at the same time I am driving Grab at night, so when the car lurches forward it's not comfortable for the passengers as well. I just got this car recently in April. Anyone experienced something similar before and can give advice?Have a short video here of the problem happening (pardon poor quality)https://youtu.be/t77PVht05GA ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic June 11, 2016 Share June 11, 2016 Only a OBDII diagnostic scan tool will be able to tell what the error/fault code is. From there you Google the fault code for your particular car make/model. You will be able to know what part is faulty. FYI a Check Engine Light will generate a fault code. So unless the CEL stays on permanently dan the workshop ppl is able to use the scan tool to find out what the fault code is. If it doesn't stay on or have a permanent record in the computer log nobody will be able to do anything. The only cheap solution is to wait for the part to get worse until a permanent CEL stays on. If this part fails it might render your car undrivable or totally stall and unable to start. So be prepared. 1 Link to post Share on other sites More sharing options...
Alphas 2nd Gear June 12, 2016 Share June 12, 2016 ABS light up when the voltage drops below the threshold level. This means that the alternator is not charging the battery and it will fall below that level, if not something else is causing the voltage drop. Link to post Share on other sites More sharing options...
ChickenMob 6th Gear June 12, 2016 Share June 12, 2016 could be alternator or other things. trying cleaning your MAF sensor. previously my forester was also having the blinking engine light and power loss, need to step alot harder just to get to 60km....as advised by some bros, gave the MAF sensor a clean up then its ok liow Link to post Share on other sites More sharing options...
NicholasYeo_101060 Neutral Newbie June 12, 2016 Author Share June 12, 2016 (edited) I will give the sensor cleanup a try. But yeah I guess it seems I can only wait it out to really know the problem =( Will be a pain if the car fails when I am grabbing. I am just wondering if it is the alternator problem, shouldn't the problem be more consistent. And not like when I am braking and coming to a stop or moving off from a stop. Edited June 12, 2016 by NicholasYeo_140592 Link to post Share on other sites More sharing options...
1fast1 Supersonic June 12, 2016 Share June 12, 2016 (edited) Which workshop are you going to? Workshops that charge you 50 bucks to tell you what you already know are not worth patronising. If you want a recommendation, PM me. I was in the Scooby scene for a long time in an earlier phase of life (my nick is a remnant). Edited June 12, 2016 by Turboflat4 Link to post Share on other sites More sharing options...
UncleAtas Turbocharged June 13, 2016 Share June 13, 2016 (edited) You GrabCar using Rex? Not overkill meh??? Edited June 13, 2016 by Sickboi Link to post Share on other sites More sharing options...
ChickenMob 6th Gear June 13, 2016 Share June 13, 2016 by the way there are a few pro workshops for Subaru around. can seek a 2nd advice if they problem is getting more annoying. Link to post Share on other sites More sharing options...
Bird5011 3rd Gear June 16, 2016 Share June 16, 2016 bro I had this problem before on my 07 Rex. Checked the alternator was working good, just change the battery all came good. Hope it helps. Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 16, 2016 Share June 16, 2016 I am having an issue with my 07 WRX recently. When stopping at traffic light for a long time, my ABS light comes on intermittently and when it does, my voltmeter reading drops below 10 and my radio goes off. After a while the voltmeter reading will go up, the ABS light goes off and the radio comes back on. When moving off, the car feels like there is a loss of power momentarily and will lurch forward for a bit if the ABS light is still on. Once I hit normal speeds the problem disappears. Once in a while the Check Engine Light will come on too. I sent it to a workshop today, and I ended up paying $50 for them to just tell me that there is some part that is probably failing, but there is no way for them to know until there is a permanent light. As the car is going to be scrapped next year, I don't want to spend $$$ on a wild goose chase to fix this problem. But at the same time I am driving Grab at night, so when the car lurches forward it's not comfortable for the passengers as well. I just got this car recently in April. Anyone experienced something similar before and can give advice? Have a short video here of the problem happening (pardon poor quality)https://youtu.be/t77PVht05GA Start by doing a high discharge test on the battery and check the live and ground battery connections. If the battery is in good health and there is no poor ground battery connection , proceed to check the battery connection and do a charging voltage and amp test. If all the above tests is Ok , then check yr ABS unit - brake fluid condition and level ( also do no forget to make sure the master brake fluid cover is proper fixed. Hope this helps Link to post Share on other sites More sharing options...
NicholasYeo_101060 Neutral Newbie June 19, 2016 Author Share June 19, 2016 Just a quick update to all who may be looking for solutions to similar problem. I changed the battery and the problems seemed to go away. The only exception is that the voltage still dip below 12 occasionally so I will be keeping an eye and hoping the problem doesn't resurface. Thanks all! ↡ Advertisement Link to post Share on other sites More sharing options...
2015 Forester 2.0
2015 Forester 2.0
Sgcarmart 1st Public Live Auction: "JDM" Legends like Evo X, Civic Type R FD2 & More are up for public bidding!
Advice on exhaust.
Advice on exhaust.
New Subaru XV
New Subaru XV
Cyclops Rear Light - Who came up with it first?
