Tckrto 2nd Gear February 23, 2018 Share February 23, 2018 Nope..2WD.I tot it was like in sports mode the rpm always stays in 4-5k range. ↡ Advertisement Link to post Share on other sites More sharing options...
slpeh 1st Gear February 23, 2018 Share February 23, 2018 I tot it was like in sports mode the rpm always stays in 4-5k range.So high then change gear. Mine is 2wd. Could it b cos I dun step hard? I usually step on lightly n let it gradually move off then step slightly down a little bit more. Maybe due to this n it change at lower gear? Link to post Share on other sites More sharing options...
Tckrto 2nd Gear February 23, 2018 Share February 23, 2018 So high then change gear. Mine is 2wd. Could it b cos I dun step hard? I usually step on lightly n let it gradually move off then step slightly down a little bit more. Maybe due to this n it change at lower gear? Dont think so for your case. Earlier case is not normal, normal acceleration gear will auto change between 2-3k rpm. Unless going up slow u can feel lost of power then when u step harder then gear drop and rpm goes up. Link to post Share on other sites More sharing options...
Zedex Clutched March 3, 2018 Share March 3, 2018 you guys face this issue when go upslope at gear 1/2 then until 3k rpm still never change gear? then the engine rev so loud sia. In the end I manual paddle shift up the gear Link to post Share on other sites More sharing options...
Cocoleak Clutched March 3, 2018 Share March 3, 2018 you guys face this issue when go upslope at gear 1/2 then until 3k rpm still never change gear? then the engine rev so loud sia. In the end I manual paddle shift up the gearI also face this problem. But it will change gear in the end. Is it ok to manually shift gears even in auto mode? Informed the SE Liao, and thatâs why they troubleshoot by checking and resetting the ECU...the flushing is additional that required to pay. Mechanic checked and see no faults, but ask me to monitor. So I believe they did their part Liao...I dun really expect them to down the gearbox or engine to perform a thorough check..... So far so good, I didnât experience any high rev at Low gear after 1 day of driving...will still monitor further How's the drive after the resetting of the ECU? Link to post Share on other sites More sharing options...
Elepoo 2nd Gear March 4, 2018 Share March 4, 2018 So far, it is working well, and I don’t experience high rpm @ Low gear...it is back to normal 2 to 3k rpm change gear mode. Link to post Share on other sites More sharing options...
Tanuki16 1st Gear March 4, 2018 Share March 4, 2018 I also face this problem. But it will change gear in the end. Is it ok to manually shift gears even in auto mode? How's the drive after the resetting of the ECU? I often manually shift gears in auto. Should be ok. Link to post Share on other sites More sharing options...
Zedex Clutched March 4, 2018 Share March 4, 2018 So far, it is working well, and I don’t experience high rpm @ Low gear...it is back to normal 2 to 3k rpm change gear mode. Maybe I should ask them reset ECU when send car for servicing Link to post Share on other sites More sharing options...
slpeh 1st Gear March 4, 2018 Share March 4, 2018 So far, it is working well, and I donât experience high rpm @ Low gear...it is back to normal 2 to 3k rpm change gear mode.Previously u mentioned tat u resettled the ECU n need to paid right? I feel if they charge a bit dun make sense cos isn't tat they deliver the car with gd working ECU meh.. funny if need to charge cos in future they wan make money juz provide a ECU with problem n make us go back repair to earn money.. Link to post Share on other sites More sharing options...
Elepoo 2nd Gear March 4, 2018 Share March 4, 2018 (edited) Previously u mentioned tat u resettled the ECU n need to paid right? I feel if they charge a bit dun make sense cos isn't tat they deliver the car with gd working ECU meh.. funny if need to charge cos in future they wan make money juz provide a ECU with problem n make us go back repair to earn money..I paid for flushing...not resetting service I did mentioned in my previous post before.. Edited March 4, 2018 by Elepoo Link to post Share on other sites More sharing options...
slpeh 1st Gear March 4, 2018 Share March 4, 2018 I paid for flushing...not resetting service I did mentioned in my previous post before.. I c. So I had read wrongly.. Link to post Share on other sites More sharing options...
Friendstar Supercharged March 4, 2018 Share March 4, 2018 (edited) This vitara like got many issues. Rattling. High rev etc. Sianz man Grand vitara used to be so legendary. A monster Edited March 4, 2018 by Friendstar Link to post Share on other sites More sharing options...
Elepoo 2nd Gear March 5, 2018 Share March 5, 2018 (edited) Somes of us experienced different problems from our ride...some even don’t have issue at all...as Long as issues can be resolved, I dun see this as a major setback for Suzuki Vitara owners. If the high rev issue is always being highlighted, it believe CM will do ECU resetting for every owner by default during the servicing Edited March 5, 2018 by Elepoo 1 Link to post Share on other sites More sharing options...
Tckrto 2nd Gear March 6, 2018 Share March 6, 2018 (edited) This vitara like got many issues. Rattling. High rev etc. Sianz man Grand vitara used to be so legendary. A monster Like other car make problem free ah? Is still consider minor issue don't stall halfway or have life threatening issue can liao mah. Edited March 6, 2018 by Tckrto 1 Link to post Share on other sites More sharing options...
slpeh 1st Gear March 6, 2018 Share March 6, 2018 This vitara like got many issues. Rattling. High rev etc. Sianz man Grand vitara used to be so legendary. A monster Btw, which car brand n model r u driving ah? Share with us the car any problem? Link to post Share on other sites More sharing options...
skp 1st Gear March 7, 2018 Share March 7, 2018 (edited) Like other car make problem free ah? Is still consider minor issue don't stall halfway or have life threatening issue can liao mah.Agreed. Compared with my fren who had multiple sofware issues with Volkswagen, kept going back to AD, these are really nothing. Btw, think my brake vacuum pump spoiled liao. Parked 1hr+ become hard to depress for engine start. Going to service next wk... Edited March 7, 2018 by skp Link to post Share on other sites More sharing options...
Tckrto 2nd Gear March 7, 2018 Share March 7, 2018 Agreed. Compared with my fren who had multiple sofware issues with Volkswagen, kept going back to AD, these are really nothing. Btw, think my brake vacuum pump spoiled liao. Parked 1hr+ become hard to depress for engine start. Going to service next wk... Mine also same but I think should check the vacuum hose instead. Normally is leak then cause the vacuum path becomes full of air and the break pedal hardens. I just step harder nia. Reason is the break pedal still works when engine is running. Link to post Share on other sites More sharing options...
skp 1st Gear March 7, 2018 Share March 7, 2018 Mine also same but I think should check the vacuum hose instead. Normally is leak then cause the vacuum path becomes full of air and the break pedal hardens. I just step harder nia. Reason is the break pedal still works when engine is running.Ya. But shouldn't happen, since going to service might as well repair it.My previous ride no such issue but aircon compressor spoiled twice. My colleague's nissan aircon compressor, cooling coil, condenser (3Cs) all spoiled before. It's heng suay... cars I know no major issues till 10yrs scrap is Honda n Mitsubishi... But some ppl may kena differently. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Sienta 2016
Toyota Sienta 2016
Fuel Pump
Fuel Pump
2016 Mercedes E-class (W213)
2016 Audi A4 sedan & avant
2016 Hyundai Elantra / Avante
Truck casually carries van on S'pore expressway
