DACH Supersonic April 18, 2018 Share April 18, 2018 just booked a astra 1.0ST. SE will go for COE bidding tmr So got your COE? ↡ Advertisement Link to post Share on other sites More sharing options...
rocky168 Clutched April 19, 2018 Share April 19, 2018 So got your COE?yes! hopefully can get my car by end of the month. 1 Link to post Share on other sites More sharing options...
kelaihoyin 5th Gear April 20, 2018 Share April 20, 2018 (edited) Seems Europe is having a product recall for the 1.4T engine (manual & auto) to fix the misfiring problem. A simple ECU update was suggested. Maybe should give AG a call next week to check on this as well? https://www.astrakforums.co.uk/viewtopic.php?f=8&t=4476&start=10 18-E-3388 is the recall code it seems. Edited April 20, 2018 by kelaihoyin 1 1 Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear April 20, 2018 Share April 20, 2018 Astra ST got auto tailgate .. Fun to play with. Hahaha. Driver seat got adjustable lower back support Link to post Share on other sites More sharing options...
Teo2000 4th Gear April 20, 2018 Share April 20, 2018 Seems Europe is having a product recall for the 1.4T engine (manual & auto) to fix the misfiring problem. A simple ECU update was suggested. Maybe should give AG a call next week to check on this as well? https://www.astrakforums.co.uk/viewtopic.php?f=8&t=4476&start=10 18-E-3388 is the recall code it seems. If it is a manufacturer's recall, LTA will know about it. LTA will then see if any cars imported into Singapore are affected by it. If LTA orders a recall, AG will have to do the rectification. This is required by law. So far, mine has no misfiring issues. Let's wait and see. 1 Link to post Share on other sites More sharing options...
kelaihoyin 5th Gear April 22, 2018 Share April 22, 2018 If it is a manufacturer's recall, LTA will know about it. LTA will then see if any cars imported into Singapore are affected by it. If LTA orders a recall, AG will have to do the rectification. This is required by law. So far, mine has no misfiring issues. Let's wait and see. Yea true those updated the ECU saw better response under warm conditions. Apparently for all 1.4T engines manual or auto included. Misfiring aside definitely worth a look if really got an update. Link to post Share on other sites More sharing options...
kelaihoyin 5th Gear April 23, 2018 Share April 23, 2018 For those 1.4T owners, u can check if your car is indeed required to be updated through here : https://tis2web.service.gm.com/tis2web/ Enter your VIN, go into K20 Engine control module and under programming you should see the recall description. I've got mine. Link to post Share on other sites More sharing options...
Tkew 1st Gear April 23, 2018 Share April 23, 2018 For those 1.4T owners, u can check if your car is indeed required to be updated through here : https://tis2web.service.gm.com/tis2web/ Enter your VIN, go into K20 Engine control module and under programming you should see the recall description. I've got mine. Screen Shot 2018-04-23 at 11.18.27.png I have the same as your's. Have you called AG? What did they say? Thanks! 1 Link to post Share on other sites More sharing options...
kelaihoyin 5th Gear April 23, 2018 Share April 23, 2018 I have the same as your's. Have you called AG? What did they say? Thanks! Yup have to praise AG for their fast response. Was told that there is indeed a campaign for updating for the engine control module. I will probably do it tgt with my servicing. If what the Europeans are saying is true should except better throttle response overall 1 Link to post Share on other sites More sharing options...
Johnny86 4th Gear April 23, 2018 Share April 23, 2018 Hope +50bhp +2km/L -1s to 100km/h 1 Link to post Share on other sites More sharing options...
Spinball 1st Gear April 24, 2018 Share April 24, 2018 For those 1.4T owners, u can check if your car is indeed required to be updated through here : https://tis2web.service.gm.com/tis2web/ Enter your VIN, go into K20 Engine control module and under programming you should see the recall description. I've got mine. Screen Shot 2018-04-23 at 11.18.27.png Have the same.. guessed that most of 1.4T are affected. Anyway, previously was told that.. to AG, that is not a recall just a campaign. They can choose to ignore it since there is no official recall register with LTA. If AG choose to rectify it.. good for owners.. if not, we also can’t do anything.. Anyone have this issue rectified by AG? Yup have to praise AG for their fast response. Was told that there is indeed a campaign for updating for the engine control module. I will probably do it tgt with my servicing. If what the Europeans are saying is true should except better throttle response overall Should AG inform all affected owners rather than owners call AG to check? 1 Link to post Share on other sites More sharing options...
Whattheheck 2nd Gear April 29, 2018 Share April 29, 2018 For those 1.4T owners, u can check if your car is indeed required to be updated through here : https://tis2web.service.gm.com/tis2web/ Enter your VIN, go into K20 Engine control module and under programming you should see the recall description. I've got mine. Screen Shot 2018-04-23 at 11.18.27.png I think I got mine done on 24 Apr. I happened to send my car in on 24 Apr to fix the stupid ‘croaking’ sounds from the front right undercarriage when driving and turning at low speed. Which they managed to fix. Apparently it is my link arm that is causing the problem. The ball joint of the link arm is not sitting properly cos it is faulty. After that replaced the link arm, there is no sound Liao. And they called me to tell me also that they updated the engine software. I dont really feel there is a obvious difference to the engine performance. But then maybe cos I just changed my rims from 17in to 18in, but lighter rims. For those curious about our stock 17in rims weight, it is 10.5kg. My new OZ Leggera HLT 18in is 9.5kg. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 29, 2018 Share April 29, 2018 Can advise current price of HB 1.0L? Tq. Link to post Share on other sites More sharing options...
Johnny86 4th Gear April 29, 2018 Share April 29, 2018 I think I got mine done on 24 Apr. I happened to send my car in on 24 Apr to fix the stupid âcroakingâ sounds from the front right undercarriage when driving and turning at low speed. Which they managed to fix. Apparently it is my link arm that is causing the problem. The ball joint of the link arm is not sitting properly cos it is faulty. After that replaced the link arm, there is no sound Liao. And they called me to tell me also that they updated the engine software. I dont really feel there is a obvious difference to the engine performance. But then maybe cos I just changed my rims from 17in to 18in, but lighter rims. For those curious about our stock 17in rims weight, it is 10.5kg. My new OZ Leggera HLT 18in is 9.5kg. How long did it take for replacement ? Link to post Share on other sites More sharing options...
Whattheheck 2nd Gear April 29, 2018 Share April 29, 2018 How long did it take for replacement ?Less than a day bro. I dropped my car with them at 8am. I collected my car at 4pm same day. Link to post Share on other sites More sharing options...
Whattheheck 2nd Gear April 29, 2018 Share April 29, 2018 For those who are curious about what is causing the door rattling sound. It is because of this water proofing plastic sheet behind our door panel. You can download the attached video to see how the plastic sheet cause the sound. Apologies for the low res as I am limited by file size upload. In real life, the sound is even louder. Untitled.mov So we removed the plastic sheet completely and replace with 3 layers of sound proofing materials for all 4 doors. Now there is not a single whisper of door rattling sound. I can't rmb exactly how much it cost. But I rmb it cost about $60 or $80/layer/door. But I think it is money well spent. Cos even AG's technician tell me my car is very very quiet. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear April 29, 2018 Share April 29, 2018 Wah bro you very hardcore.. I only did front door double layer - rear doors single layer! haha Link to post Share on other sites More sharing options...
kelaihoyin 5th Gear April 29, 2018 Share April 29, 2018 For those who are curious about what is causing the door rattling sound. It is because of this water proofing plastic sheet behind our door panel. You can download the attached video to see how the plastic sheet cause the sound. Apologies for the low res as I am limited by file size upload. In real life, the sound is even louder. Untitled.mov InkedIMG_5320_LI.jpg So we removed the plastic sheet completely and replace with 3 layers of sound proofing materials for all 4 doors. Now there is not a single whisper of door rattling sound. I can't rmb exactly how much it cost. But I rmb it cost about $60 or $80/layer/door. But I think it is money well spent. Cos even AG's technician tell me my car is very very quiet. The replaced sound proofing layers are also waterproof? ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Sienta 2016
Toyota Sienta 2016
2016 Mercedes E-class (W213)
2016 Audi A4 sedan & avant
2016 Hyundai Elantra / Avante
2016 / 2017 Subaru Impreza
Car Wrap or respraying of the car?
Comparing Opel Astra 1.6 Twinport and Ford Focus 1.6 H/B
