Bluepica 4th Gear May 18, 2016 Share May 18, 2016 Hi, Planning to reno my home and change all the windows. Old HDB flat, no extend ledge on top, thus have to close window whenever rain. What is you take of the differences between sliding and casement windows? and also with or without top-hung section. To me, casement window will direct wind blow into the flat but sliding window will not. Sliding window easier to open close. casement window more sound proof? (my room facing E'way) Having top-hung window, they say at least got ventilation when heavy rain have to close all other windows but I don't feel the different. Worst, cleaning the window more leceh compare to cleaning one whole piece... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Mockngbrd Supersonic May 18, 2016 Share May 18, 2016 Sliding wun drop down 2 Link to post Share on other sites More sharing options...
Mustank Hypersonic May 18, 2016 Share May 18, 2016 Casement can open wide wide 1 Link to post Share on other sites More sharing options...
Kxbc Turbocharged May 18, 2016 Share May 18, 2016 http://www.decorille.com/technology/ problem solved. except for the rain splashing in. 2 Link to post Share on other sites More sharing options...
Mustank Hypersonic May 18, 2016 Share May 18, 2016 2 Link to post Share on other sites More sharing options...
Kusje Supersonic May 18, 2016 Share May 18, 2016 On 5/18/2016 at 9:00 AM, Mustank said: I am currently living in this type of flat but my door definitely more old school! 2 Link to post Share on other sites More sharing options...
Vratenza Supersonic May 18, 2016 Share May 18, 2016 Give you more headache I am using this sliding casement windows: Good especially if you are high floor and faces some decently nice scenery. 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic May 18, 2016 Share May 18, 2016 Casement with top hung. 3 Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 18, 2016 Author Share May 18, 2016 On 5/18/2016 at 9:11 AM, Vratenza said: Give you more headache I am using this sliding casement windows: Good especially if you are high floor and faces some decently nice scenery. mine can only see tree top Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 18, 2016 Share May 18, 2016 Yes, this type, but much larger glass planes, like those used in Singapore Polytechnic classrooms. Rain won't come in. On 5/18/2016 at 9:00 AM, Mustank said: 2 Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 18, 2016 Author Share May 18, 2016 On 5/18/2016 at 8:52 AM, Mustank said: Casement can open wide wide open wide wide but when close almost half ur body out the window to close it, dangerous for old ppl lei Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 18, 2016 Share May 18, 2016 tie strings. On 5/18/2016 at 9:33 AM, Bluepica said: open wide wide but when close almost half ur body out the window to close it, dangerous for old ppl lei 1 Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 18, 2016 Author Share May 18, 2016 On 5/18/2016 at 9:24 AM, Adrianli said: Casement with top hung. For casement window, rain will splatter in when raining... I always wonder if I can stick a high quality plastic sheet on top between the top of the window and the frame like a rectangular shape so that I don't need to close window even when it rains.... problem is, I can't close the window unless I tear off this plastic sheet.... Link to post Share on other sites More sharing options...
Beaver 2nd Gear May 18, 2016 Share May 18, 2016 On 5/18/2016 at 9:11 AM, Vratenza said: Give you more headache I am using this sliding casement windows: Good especially if you are high floor and faces some decently nice scenery. how do you clean the outside window ? 1 Link to post Share on other sites More sharing options...
Bluepica 4th Gear May 18, 2016 Author Share May 18, 2016 I ever saw the casement window in US before they have this winding mechanism macam those car manual window... wind it to open out or close in...think SG don't have On 5/18/2016 at 9:34 AM, Kangadrool said: tie strings. 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic May 18, 2016 Share May 18, 2016 Lagi easier compared to fixed casement. Main reason is because you can slide each of the panel to whichever position you want and each panel can swing >90 degrees. So my method is to slide all the panels to one side, then one by one pull each panel from the bunch. this panel can be closed (0 degree) to clean the inner surface. Then flip it almost 180 degree to wipe the "oute side" which is facing you now. On 5/18/2016 at 9:39 AM, Beaver said: how do you clean the outside window ? Treetop is good lar.... can see birds..... sure relaxing! On 5/18/2016 at 9:31 AM, Bluepica said: mine can only see tree top Link to post Share on other sites More sharing options...
Janling3 6th Gear May 18, 2016 Share May 18, 2016 to close or open a casement window, we only need to stretch our arm to pull the lower portion of the window, it is not that difficult. :) On 5/18/2016 at 9:39 AM, Beaver said: how do you clean the outside window ? when the window panel is perpendicular to the wall... 2 Link to post Share on other sites More sharing options...
Beaver 2nd Gear May 18, 2016 Share May 18, 2016 On 5/18/2016 at 9:47 AM, Vratenza said: Lagi easier compared to fixed casement. Main reason is because you can slide each of the panel to whichever position you want and each panel can swing >90 degrees. So my method is to slide all the panels to one side, then one by one pull each panel from the bunch. this panel can be closed (0 degree) to clean the inner surface. Then flip it almost 180 degree to wipe the "oute side" which is facing you now. Treetop is good lar.... can see birds..... sure relaxing! interesting although I cannot really visualise it...how much do you pay ? Must be a bomb. On 5/18/2016 at 9:51 AM, Janling3 said: to close or open a casement window, we only need to stretch our arm to pull the lower portion of the window, it is not that difficult. :) when the window panel is perpendicular to the wall... haha sorry cannot visualize it ... and how much you paid for yours ? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Simple home DIY repairs
Higher property tax for most 3-room HDB flats, all bigger units from Jan 1, 2022: Iras
Home Aircon
Home Aircon
