WoeiSongKeh 5th Gear May 16, 2016 Share May 16, 2016 Does anyone know where I can buy similar or this type of Plug & Play monitoring system ? What are the sizes available ? ↡ Advertisement Link to post Share on other sites More sharing options...
Yuan 6th Gear May 16, 2016 Share May 16, 2016 There are many brands and types. Depends on whether you prefer the digital gauges or analog ones and what and why you want to monitor. Is your car stock? Do you track your car? Link to post Share on other sites More sharing options...
WoeiSongKeh 5th Gear May 16, 2016 Author Share May 16, 2016 On 5/16/2016 at 10:39 AM, Yuan said: There are many brands and types. Depends on whether you prefer the digital gauges or analog ones and what and why you want to monitor. Is your car stock? Do you track your car? Car is stock Altis. Want track those I display in the picture Link to post Share on other sites More sharing options...
Yuan 6th Gear May 17, 2016 Share May 17, 2016 On 5/16/2016 at 3:10 PM, WoeiSongKeh said: Car is stock Altis. Want track those I display in the picture You can try scangauge or ultragauge. I have tried ultragauge for a period of time but I sold it because it was unable to read readings of oil temperature and oil pressure (they matter to me as I do go to the tracks from time to time). And the readings varies from car model to model. I am now using in-built gauge readings programmed into my stock display from one of the reputable workshops which specialize in certain models. Link to post Share on other sites More sharing options...
WoeiSongKeh 5th Gear May 17, 2016 Author Share May 17, 2016 On 5/17/2016 at 2:18 AM, Yuan said: You can try scangauge or ultragauge. I have tried ultragauge for a period of time but I sold it because it was unable to read readings of oil temperature and oil pressure (they matter to me as I do go to the tracks from time to time). And the readings varies from car model to model. I am now using in-built gauge readings programmed into my stock display from one of the reputable workshops which specialize in certain models. Thanks. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged May 17, 2016 Share May 17, 2016 Just get a bluetooth OBD adaptor, connect to the OBD socket. that will read most of the statistics from the engine. Should cost you less than 10 bucks from ebay. As for the LCD terminal, get a use phone that is large enough for your eye, mount it somewhere you are comfortable with and connect the the OBD scanner using bluetooth. This is the simplest, cheapes and most flexible setup you can do... 12 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged May 18, 2016 Share May 18, 2016 On 5/17/2016 at 5:05 PM, Tigershark1976 said: Just get a bluetooth OBD adaptor, connect to the OBD socket. that will read most of the statistics from the engine. Should cost you less than 10 bucks from ebay. As for the LCD terminal, get a use phone that is large enough for your eye, mount it somewhere you are comfortable with and connect the the OBD scanner using bluetooth. This is the simplest, cheapes and most flexible setup you can do... just to add on. use torque pro paid version if yours is turbo charge to read boost from the ODB2 port. Link to post Share on other sites More sharing options...
cllq 6th Gear May 18, 2016 Share May 18, 2016 got mine from taobao... cheap and good. under $30 with shipment and can be DIY. Link to post Share on other sites More sharing options...
JX83 3rd Gear May 25, 2016 Share May 25, 2016 Anyone using boost gauge here can intro a cheap version? My ultra gauge can't measure boost on my car so maybe need to get another 1.. Not getting the Defi brand as too exp for me.. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 25, 2016 Share May 25, 2016 On 5/25/2016 at 3:59 AM, JX83 said: Anyone using boost gauge here can intro a cheap version? My ultra gauge can't measure boost on my car so maybe need to get another 1.. Not getting the Defi brand as too exp for me.. Call 6281 7990 Ask for Alex. Link to post Share on other sites More sharing options...
Optramagnum 6th Gear May 25, 2016 Share May 25, 2016 (edited) Previously, I also quite crazy over these gauges, will monitor them diligently like a pilot flying an aircraft.. But over the time, it became bored and a distraction, esp at night.. Well, it's just me and I'm driving a B&B car.. Nothing really to see.. Edited May 25, 2016 by Optramagnum Link to post Share on other sites More sharing options...
Kklee 6th Gear May 25, 2016 Share May 25, 2016 On 5/25/2016 at 4:22 AM, Optramagnum said: Previously, I also quite crazy over these gauges, will monitor them diligently like a pilot flying an aircraft.. But over the time, it became bored and a distraction, esp at night.. Well, it's just me and I'm driving a B&B car.. Nothing really to see.. For Scanguage on Optra, using I monitor coolant temp or throttle position sensor - either need to top up water or go for throttle body cleaning. Link to post Share on other sites More sharing options...
Hoonigan 1st Gear June 3, 2016 Share June 3, 2016 I using Ultragauge. No Oil temp but there's coolant temp. But the important thing to monitor to protect engine is actually oil pressure Link to post Share on other sites More sharing options...
Stevetp1 Clutched June 23, 2016 Share June 23, 2016 Hi, that is Greddy Touch Informeter which I have just debit from my accord yesterday. I'm letting go at a reasonable price as it is not compatible with my new Volkswagen ride. Drop me a msg if keen. Tks ↡ Advertisement Link to post Share on other sites More sharing options...
8th Gen Toyota Camry (XV70)
Takata airbag recall
Toyota Corolla Cross
Toyota Land Cruiser Mini
