Cheesey74 6th Gear August 18, 2023 Share August 18, 2023 On 8/18/2023 at 12:32 PM, oleoleole said: Engine oil gasket leakage is common for QQ 1.2T. A $300 thereabouts fix. Rotor is wear and tear, unavoidable for used car. Cooling system I'm not so sure, but prolly <$300 fix?. Not sure abnormal noise on road test means. Probably absorber? All in all, prolly $1.2 to fix up everything, I think it's acceptable. How much is the depre anyway? Wow.. i dun think 1.2k can fix all these defects, some these defects can be endless rabbit holes, budget >3k plus multiple days to visit workshop better bah. ↡ Advertisement Link to post Share on other sites More sharing options...
Keefe 1st Gear August 18, 2023 Share August 18, 2023 @arunpurisg 225/45/19 not a lot of choices but still enough to choose. There's Primacy 4+ now but it's nearly $350 each. There's PS5 ($300), F1A6 ($300), GitiSport S2 ($135 but it's good enough for normal use and very capable too) I won't go for RV-02 now cos it's old model already. If you can find new stock then need to compare price. It's a decent tire. Just that it's pre F1A5 or PS4 models. New tires new rubber. But some thing new if you need to spend quite a bit IMHO. The newer Yokohamas to me just not worth the price. I rather pay a bit more for a better tire Link to post Share on other sites More sharing options...
arunpurisg Neutral Newbie August 18, 2023 Share August 18, 2023 On 8/18/2023 at 4:26 PM, Keefe said: @arunpurisg 225/45/19 not a lot of choices but still enough to choose. There's Primacy 4+ now but it's nearly $350 each. There's PS5 ($300), F1A6 ($300), GitiSport S2 ($135 but it's good enough for normal use and very capable too) I won't go for RV-02 now cos it's old model already. If you can find new stock then need to compare price. It's a decent tire. Just that it's pre F1A5 or PS4 models. New tires new rubber. But some thing new if you need to spend quite a bit IMHO. The newer Yokohamas to me just not worth the price. I rather pay a bit more for a better tire Thanks a lot for recommendations. I will check all of those out. Is it possible and suggested to go down to 18, for more options and cheaper tyres? Link to post Share on other sites More sharing options...
Andydavids07 Neutral Newbie August 20, 2023 Share August 20, 2023 (edited) Anyone got changed the steering column before and how much is it? Steering got sound especially turning and uneven road. Thanks Edited August 20, 2023 by Andydavids07 Link to post Share on other sites More sharing options...
Qashqai_Blaze Neutral Newbie August 21, 2023 Share August 21, 2023 Hello Sifus, My first post here, my 6 years old Nissan Qashqai 2.0 would have some minor skid whenever i do 90 degrees turn at MSCP, and when drove on metal cover at expressway. Previously i tried to ignore it since it did not affect the daily drive, but recently the issues have become more serious with the wet weather, with the skidding can also be felt by passenger at the back of the car I also noticed that my new Michelin tire that I just gotten 6 months ago seem to be quite bald, previously i had done wheel alignment during the replacement. Not sure any Qashqai out there faced this issue before? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear August 21, 2023 Share August 21, 2023 @Qashqai_Blaze Likely your tyres la. bald already sure skid lo. Safety please go and change. Link to post Share on other sites More sharing options...
oleoleole 2nd Gear August 21, 2023 Share August 21, 2023 On 8/20/2023 at 10:50 PM, Andydavids07 said: Anyone got changed the steering column before and how much is it? Steering got sound especially turning and uneven road. Thanks Again, common issue with Qashqai. Alot of owners have had it changed with Tan Chong under warranty claim, including me. Sry unable to advise the cost since I replaced it under warranty. You can check with few workshops to get the best price. Most WS shld be able to do it. Gd luck! 1 Link to post Share on other sites More sharing options...
Andydavids07 Neutral Newbie August 22, 2023 Share August 22, 2023 @oleoleole thanks for the info and will find few ws!! Got a ws quoted 570-600 to replace the part. Just wonder if that is the common price. Link to post Share on other sites More sharing options...
arunpurisg Neutral Newbie August 22, 2023 Share August 22, 2023 On 8/18/2023 at 4:26 PM, Keefe said: @arunpurisg 225/45/19 not a lot of choices but still enough to choose. There's Primacy 4+ now but it's nearly $350 each. There's PS5 ($300), F1A6 ($300), GitiSport S2 ($135 but it's good enough for normal use and very capable too) I won't go for RV-02 now cos it's old model already. If you can find new stock then need to compare price. It's a decent tire. Just that it's pre F1A5 or PS4 models. New tires new rubber. But some thing new if you need to spend quite a bit IMHO. The newer Yokohamas to me just not worth the price. I rather pay a bit more for a better tire @KeefeGot changed to F1A6 for 1100 at Kim Hoe. Thanks for your recommendation! Got good service there. Link to post Share on other sites More sharing options...
Qashqai_Blaze Neutral Newbie August 28, 2023 Share August 28, 2023 @QQDreamer The workshop had identified the issues with the front lower arm which caused the imbalance between the front tires and caused it to wear off in such short period. Replaced the arms and new tyres, feels ok now! Link to post Share on other sites More sharing options...
Qashqai_Blaze Neutral Newbie August 28, 2023 Share August 28, 2023 On 8/21/2023 at 6:46 PM, QQDreamer said: @Qashqai_Blaze Likely your tyres la. bald already sure skid lo. Safety please go and change. The workshop had identified the issues with the front lower arm which caused the imbalance between the front tires and caused it to wear off in such short period. Replaced the arms and new tyres, feels ok now! Link to post Share on other sites More sharing options...
surf88 Neutral Newbie August 28, 2023 Share August 28, 2023 On 8/28/2023 at 10:50 AM, Qashqai_Blaze said: @QQDreamer The workshop had identified the issues with the front lower arm which caused the imbalance between the front tires and caused it to wear off in such short period. Replaced the arms and new tyres, feels ok now! Hi , Can share your workshop as i have exact the same sound issue on the steering wheel and how much was the repair? TIA. Link to post Share on other sites More sharing options...
Qashqai_Blaze Neutral Newbie August 29, 2023 Share August 29, 2023 On 8/28/2023 at 10:32 PM, surf88 said: Hi , Can share your workshop as i have exact the same sound issue on the steering wheel and how much was the repair? TIA. I done the replacement at Accord Auto AMK, the damage was $700 for replacement of front lower arm at 2 sides. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear August 30, 2023 Share August 30, 2023 (edited) deleted Edited August 30, 2023 by QQDreamer Link to post Share on other sites More sharing options...
oleoleole 2nd Gear September 3, 2023 Share September 3, 2023 On 8/29/2023 at 11:50 AM, Qashqai_Blaze said: I done the replacement at Accord Auto AMK, the damage was $700 for replacement of front lower arm at 2 sides. My E-class, I replaced the 2x front lower arms too, for $480 incl labour.. Jap car parts more exp than Conti? Link to post Share on other sites More sharing options...
therock Supersonic September 3, 2023 Share September 3, 2023 On 9/3/2023 at 12:53 PM, oleoleole said: My E-class, I replaced the 2x front lower arms too, for $480 incl labour.. Jap car parts more exp than Conti? I wouldn't exactly call this a Jap car.. it's direct brother / cousin is French... The Sunny, the Cerato, Bluebird or the Godzilla etc etc are Jap.. Link to post Share on other sites More sharing options...
DaNieLRyaN77 Neutral Newbie January 22, 2024 Share January 22, 2024 Hi bros, was wondering if the rear wiper blade can be replaced. Link to post Share on other sites More sharing options...
Kxbc Turbocharged January 22, 2024 Share January 22, 2024 Has anyone replaced the tailgate mechanism before? how much does it cost and if you have recommended workshop? mine does not seem to be able to hold still (8 out of 10 times) and keep the tailgate locked when I am loading/unloading stuff. ↡ Advertisement Link to post Share on other sites More sharing options...
