mikal Neutral Newbie September 7, 2022 Share September 7, 2022 On 9/6/2022 at 6:19 PM, richard_crl032 said: Most welcomed .. it is not difficult to diy remove and replace .. 3 mins each side once familiar but it is for yr consideration .. key point still if it is burnt socket/connector, you need/should change them .. fire hazard. I go back to AD and has limited experience with outside ws but it would Riverview AMK Autopoint when I had my Estima from PI for 10 yrs .. not cheapest but quite professional. Cheers. Thanks again!! OK - understood your advise :-) Kam Siah :-) ↡ Advertisement 1 Link to post Share on other sites More sharing options...
NestlePanas Neutral Newbie September 21, 2022 Share September 21, 2022 Hi all, I'm actually in the process of buying a used QQ 1.2(5 year old, 45k mileage) and sent for STA evaluation. I received a Grading of B with the following remarks: 1) VEHICLE UPPER ARM BUSH SIGN OF WORN (FRONT BOTH) 2) VEHICLE ENGINE SUMP & VALVE COVER AREA SIGN OF OIL STAIN 3) VEHICLE AIR COND COMPRESSOR AREA SIGN OF OIL STAIN I suppose 1 is normal wear and tear but should I be concerned with 2 & 3? Massive thanks! This is my first time buying a car 🙂 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear September 21, 2022 Share September 21, 2022 16 hours ago, NestlePanas said: Hi all, I'm actually in the process of buying a used QQ 1.2(5 year old, 45k mileage) and sent for STA evaluation. I received a Grading of B with the following remarks: 1) VEHICLE UPPER ARM BUSH SIGN OF WORN (FRONT BOTH) 2) VEHICLE ENGINE SUMP & VALVE COVER AREA SIGN OF OIL STAIN 3) VEHICLE AIR COND COMPRESSOR AREA SIGN OF OIL STAIN I suppose 1 is normal wear and tear but should I be concerned with 2 & 3? Massive thanks! This is my first time buying a car 🙂 yes you should be concern especially for the 1.2T which is having piston ring oil leak issues. also lost of power when driving, Item 2 and 3 are expensive item. And also turbo pipe crack is also another issue of the 1.2T. suggest if budget permits buy 2.0 instead. 2 Link to post Share on other sites More sharing options...
oleoleole 2nd Gear September 22, 2022 Share September 22, 2022 On 9/21/2022 at 2:05 PM, NestlePanas said: Hi all, I'm actually in the process of buying a used QQ 1.2(5 year old, 45k mileage) and sent for STA evaluation. I received a Grading of B with the following remarks: 1) VEHICLE UPPER ARM BUSH SIGN OF WORN (FRONT BOTH) 2) VEHICLE ENGINE SUMP & VALVE COVER AREA SIGN OF OIL STAIN 3) VEHICLE AIR COND COMPRESSOR AREA SIGN OF OIL STAIN I suppose 1 is normal wear and tear but should I be concerned with 2 & 3? Massive thanks! This is my first time buying a car 🙂 Point 2 and 3 are signs of engine leak oil liao. If heng, jus need to replace gasket cover. If suay, need to overhaul engine. BTW, the 2.0QQ also not invincible. I have colleague whose 2.0QQ engine sudden loss of power, then engine check light came on. Duno how he solved it in the end. Or maybe didn't solve and sold it cuz saw him driving a BMW not long after lol 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear September 22, 2022 Share September 22, 2022 4 hours ago, oleoleole said: Point 2 and 3 are signs of engine leak oil liao. If heng, jus need to replace gasket cover. If suay, need to overhaul engine. BTW, the 2.0QQ also not invincible. I have colleague whose 2.0QQ engine sudden loss of power, then engine check light came on. Duno how he solved it in the end. Or maybe didn't solve and sold it cuz saw him driving a BMW not long after lol This sounds like ignition coil issue ? but 2.0 does not have any known issue of oil leak on piston. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear September 24, 2022 Share September 24, 2022 hi all, may i check anyone bought the OBD auto speed lock device and proven working? saw many at taobao but not sure whether can work anot. anyone bought and tested working? can provide link? Link to post Share on other sites More sharing options...
Maui 1st Gear September 28, 2022 Share September 28, 2022 Hello Brothers~ just did my 110K servicing and was inform of Timing Cover Oil Leaking. Anyone have recently replaced Timing Cover oil leaking? Was quoted $770 to the repair. Please advise. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear September 28, 2022 Share September 28, 2022 (edited) 10 hours ago, Maui said: Hello Brothers~ just did my 110K servicing and was inform of Timing Cover Oil Leaking. Anyone have recently replaced Timing Cover oil leaking? Was quoted $770 to the repair. Please advise. is yours a 1.2T? Edited September 28, 2022 by StreamRSZ Link to post Share on other sites More sharing options...
Maui 1st Gear September 28, 2022 Share September 28, 2022 11 hours ago, StreamRSZ said: is yours a 1.2T? Yes Boss. 2016 QQ 1.2T. I know this is a known problem Liao. Just want to find out got cheaper option. Link to post Share on other sites More sharing options...
DaNieLRyaN77 Neutral Newbie October 11, 2022 Share October 11, 2022 Morning bros.. I have been buying Motul 8100 X-cess 5W40 from MX Tradings in Ubi. However, this recent phone call and a google search i think he close shop. Any bros buy EO from him previously? Is he still selling? Any contacts? TIA.. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear October 11, 2022 Share October 11, 2022 (edited) @DaNieLRyaN77 Just saying, you may wish to look at alternate and cheaper similiar fully synthetic eo e.g. Ravenol (made in Germany) etc. Cheers. Edited October 11, 2022 by richard_crl032 Link to post Share on other sites More sharing options...
inlinesix Hypersonic October 11, 2022 Share October 11, 2022 Lynlex sell this oil on Shopee Link to post Share on other sites More sharing options...
QQDreamer 4th Gear October 11, 2022 Share October 11, 2022 9 hours ago, DaNieLRyaN77 said: Morning bros.. I have been buying Motul 8100 X-cess 5W40 from MX Tradings in Ubi. However, this recent phone call and a google search i think he close shop. Any bros buy EO from him previously? Is he still selling? Any contacts? TIA.. owner manual says 5w30. u using 5w40? 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear October 24, 2022 Share October 24, 2022 anyone can recommend which nissan stockist is recommended? know of fong tat. are their price reasonable? genunine parts? Link to post Share on other sites More sharing options...
DaNieLRyaN77 Neutral Newbie November 21, 2022 Share November 21, 2022 Morning bros, Sent the car in for servicing today and inform SA that the brake pedal is hard after parking overnight. So after they did the initial check and came back that the brake booster & master pump assy needs to be replaced. Was quoted a whooping $3k+ quotation. Was reli shock with it. Any of the gurus here have encountered this and any advise? Thanx.. Link to post Share on other sites More sharing options...
Scorpiong 3rd Gear November 21, 2022 Share November 21, 2022 Hi, would like to ask you guys. My Nissan Sylphly 2015 model, when accelerating sometimes suddenly it will jerk. May I know what what is the problem? Thanks Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 22, 2022 Share November 22, 2022 On 11/21/2022 at 12:58 PM, Scorpiong said: Hi, would like to ask you guys. My Nissan Sylphly 2015 model, when accelerating sometimes suddenly it will jerk. May I know what what is the problem? Thanks er.. sorry this is QQ thread. Did you ask on the correct thread? But base on your sudden jerk. Just to check when was the last time you change your gear box oil? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 22, 2022 Share November 22, 2022 On 11/21/2022 at 12:27 PM, DaNieLRyaN77 said: Morning bros, Sent the car in for servicing today and inform SA that the brake pedal is hard after parking overnight. So after they did the initial check and came back that the brake booster & master pump assy needs to be replaced. Was quoted a whooping $3k+ quotation. Was reli shock with it. Any of the gurus here have encountered this and any advise? Thanx.. ask outside workshop to quote. definitely will be cheaper. sometimes have recon set which u dont be surprised is cheaper. Recon meaning those seals etc replaced with new seals. ↡ Advertisement Link to post Share on other sites More sharing options...
