richard_crl032 6th Gear April 24, 2022 Share April 24, 2022 1 hour ago, Snorelax said: Anyone knows how to disable the auto start/stop stop engine function by default without pressing the button? or reverse the function? For face-lifted Qashqai. Check out 'Nissan Qashqai Stop Start Controller (SSC) / Auto Stop Start Module / Start Stop Controller Module', available at S$80 on #Carousell: https://carousell.app.link/tpHH35Cdupb ↡ Advertisement Link to post Share on other sites More sharing options...
richard_crl032 6th Gear April 24, 2022 Share April 24, 2022 @Dan123 Not joined ... looks fine 🥳 Link to post Share on other sites More sharing options...
Dan123 Neutral Newbie April 24, 2022 Share April 24, 2022 @richard_crl032 thanks. These 2 are aircon pipes? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear April 24, 2022 Share April 24, 2022 @Dan123 Sorry but I had been a long long time since I had the qashqai 1.2T and I do not have one to check and advise you 🙏🙏 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 24, 2022 Share April 24, 2022 9 hours ago, Dan123 said: @richard_crl032 thanks. These 2 are aircon pipes? looks like one hot water pipe and one "cold water' pipe. By the way is there any issue with these 2 pipes? Link to post Share on other sites More sharing options...
Snorelax Neutral Newbie April 25, 2022 Share April 25, 2022 On 4/21/2022 at 12:16 AM, richard_crl032 said: Vaguely remember indeed the case as mentioned by DOBIEMKZ for stock pre-FL qashqai 1.2T but it is troublesome. You will find some owners with theirs from the dimming drl mod with drl off switch and module that the then 2015 whatsapp group did ahead if later FL version that off drl when signalling. I requested and received modules that also allowed drl to be switched off. But it is complex with needed module and again, it had been a long time and I can no longer get the module but contact me if you wish for the module and detailed instruction from Croatian working in Germany to contact him if he is still willing to ship to you and hv local workshop to fit for you. Cheers. PS: He is in Brisbane with family until mid May 2022 Hi Richard, thanks for the advise.... seems quite troublesome to go through it.. guess i will live with it till i change car in the future! 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 5, 2022 Share May 5, 2022 any good andriod Head unit to recommend? saw aliexpress have a few brands like dasaita , sinomart. anyone installa and have any recommendations? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear May 5, 2022 Share May 5, 2022 @StreamRSZ @StreamRSZ Hi, really good ones are not cheap and cheap no good ones make you wish to dump them. I can only recommend ATC ones with local support from Aestmod: https://www.androidatc.com.sg/ Cheers. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 5, 2022 Share May 5, 2022 10 hours ago, richard_crl032 said: @StreamRSZ @StreamRSZ Hi, really good ones are not cheap and cheap no good ones make you wish to dump them. I can only recommend ATC ones with local support from Aestmod: https://www.androidatc.com.sg/ Cheers. is it compatible with all stock functions? eg: 360 cam, steering control buttons, reverse cam. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear May 6, 2022 Share May 6, 2022 @StreamRSZ Hi, that is the big advantage of local Aestmod .. you can speak to them and have guaranteed service before spending. They have their own 360 deg cam solution with their headunit which I dunno if stock can cos I din do but stock steering control and reverse cam are wet wet water. Just go to their shop to see all available .. boss Keeve and chief installer Boon and you can say Richard recommended 😅 Cheers. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 6, 2022 Share May 6, 2022 1 hour ago, richard_crl032 said: @StreamRSZ Hi, that is the big advantage of local Aestmod .. you can speak to them and have guaranteed service before spending. They have their own 360 deg cam solution with their headunit which I dunno if stock can cos I din do but stock steering control and reverse cam are wet wet water. Just go to their shop to see all available .. boss Keeve and chief installer Boon and you can say Richard recommended 😅 Cheers. OK thank you so much. just concern that the original functions wont worked. will drop by one of these days to see their display or demo unit before committing. 1 Link to post Share on other sites More sharing options...
Maui 1st Gear May 31, 2022 Share May 31, 2022 Anyone replace AC Compressor ($750), Condenser ($350) and Fan Coil ($850)recently? want to find out if I’m Kotok by the workshop. just change my coming 6yo J11 to replace the above. No time to compare price as need the car for work. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 31, 2022 Share May 31, 2022 42 minutes ago, Maui said: Anyone replace AC Compressor ($750), Condenser ($350) and Fan Coil ($850)recently? want to find out if I’m Kotok by the workshop. just change my coming 6yo J11 to replace the above. No time to compare price as need the car for work. All three at once? What are you driving? A Volvo? Did you crash your car? Too late to ask now. What made you replace the whole ac system? Got ask for 2nd opinion? Link to post Share on other sites More sharing options...
Maui 1st Gear May 31, 2022 Share May 31, 2022 @Watwheels im driving a Qoshqo? Lol. Well, i send my car to repair at around 7pm and the workshop promised that I can collect it on the same day. no time to compare, can die inside the car without AC. And I need my car for my work. the famous AC specialist in AMK say they fixed many QQ with same problem liao, common illness for QQ more than 5yr. Link to post Share on other sites More sharing options...
jaja2000 1st Gear May 31, 2022 Share May 31, 2022 (edited) @Maui same here, 2016 QQ. Just replace the AC compressor 2 weeks back. The compressor clutch or gear jammed and in turn prevent the engine from running. Compressor $680, Belt $85, Valve $100, top up ac gas + labour all in $900 after disc. Car broke down in multi storey carpack and towing in the night at $80. Edited May 31, 2022 by jaja2000 Additional item to be added Link to post Share on other sites More sharing options...
jaja2000 1st Gear May 31, 2022 Share May 31, 2022 *my friend 5yrs Toyota wish will be also replacing the AC compressor this week😅 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged May 31, 2022 Share May 31, 2022 3 hours ago, Maui said: Anyone replace AC Compressor ($750), Condenser ($350) and Fan Coil ($850)recently? want to find out if I’m Kotok by the workshop. just change my coming 6yo J11 to replace the above. No time to compare price as need the car for work. @Maui A few years ago I changed my Nissan Latio's condensor costed about $300 plus. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear May 31, 2022 Share May 31, 2022 (edited) @Maui No worry .. forester SJ also had condenser, coil and even fan dying b4 3 yrs warranty or just after but primarily b4 100k km 🤦♂️ Only compressor seems to be doing better with no "early" failure. Btw, do yourself a favor and go to Kim's Aircon at Ubi in the future for quality work, parts and ok pricing if no longer under warranty. Cheers. Edited May 31, 2022 by richard_crl032 ↡ Advertisement Link to post Share on other sites More sharing options...
