qq12t Neutral Newbie November 29, 2021 Share November 29, 2021 Hi I've bought QQ1.2T 2016 registered, noted the car efficiency is between 7-8km/l within city limits (with ECO enabled) If driven in the expressway the efficiency increased to 10-11km/l How to improve the performance? Also the car seems to be sluggish with very little pickup and really slows down on the ramp-up Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Ralliwira 1st Gear November 29, 2021 Share November 29, 2021 @qq12t You can upgrade the air filter to K&N drop in and change the stock rims to a lighter one. The 17" stock rims are actually quite heavy. Link to post Share on other sites More sharing options...
qq12t Neutral Newbie November 29, 2021 Share November 29, 2021 @Ralliwira Thanks. Any recommended workshop at Sengkang/Punggol or east area? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear November 30, 2021 Share November 30, 2021 (edited) On 11/29/2021 at 4:02 PM, qq12t said: Hi I've bought QQ1.2T 2016 registered, noted the car efficiency is between 7-8km/l within city limits (with ECO enabled) If driven in the expressway the efficiency increased to 10-11km/l How to improve the performance? Also the car seems to be sluggish with very little pickup and really slows down on the ramp-up Thanks If you can check you mfg date and if before Jun 2016 and you find that eo level depletes noticably every 10k or even 5k km, there is good chance that this is the known bad piston rings causing eo leakage that will lead to non performing engine and high FC Nevertheless, this 1.2L turbo qashqai is somewhat underpowered and best you can do is to fit pivot ethrottle at sp4/5 but FC will deteriorates further of course. More imptly, watch out for power loss where rpm will get stuck at 1k rpm after moving off from idling 750 rpm which is quite scary imho but unfortunately not solved when my wife had hers. Quite unfortunately as it is nice looking and offers great ride comfort for its class. Cheers. Richard Edited November 30, 2021 by richard_crl032 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 30, 2021 Share November 30, 2021 14 hours ago, richard_crl032 said: If you can check you mfg date and if before Jun 2016 and you find that eo level depletes noticably every 10k or even 5k km, there is good chance that this is the known bad piston rings causing eo leakage that will lead to non performing engine and high FC Nevertheless, this 1.2L turbo qashqai is somewhat underpowered and best you can do is to fit pivot ethrottle at sp4/5 but FC will deteriorates further of course. More imptly, watch out for power loss where rpm will get stuck at 1k rpm after moving off from idling 750 rpm which is quite scary imho but unfortunately not solved when my wife had hers. Quite unfortunately as it is nice looking and offers great ride comfort for its class. Cheers. Richard wah the 1.2T looks very fragile. by the way when your wife own the 1.2T is the facelift version or the pre facelift? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear November 30, 2021 Share November 30, 2021 (edited) 41 minutes ago, StreamRSZ said: wah the 1.2T looks very fragile. by the way when your wife own the 1.2T is the facelift version or the pre facelift? Hi, it was said to be supplier issue of slightly undersized piston resolved after mentioned Jun 2016 ... shit happens like vw had years of issue with the dsg gearbox. It is pre-facelift version and many affected .. eo drop will be the tell-tale sign. Power loss also affected some, including facelift version but it was hearsay as I left the almost 300 strong Qashqai group then. Cheers. Richard Edited November 30, 2021 by richard_crl032 Link to post Share on other sites More sharing options...
Ralliwira 1st Gear December 1, 2021 Share December 1, 2021 @qq12t Don't have any workshop in Sengkang/Punggol to recommend. I normally go to a workshop in Tampines Street 92 area. If you are interested, I can PM u the number. BTW, forget to mention that you should not turn On the ECO mode as you will feel the car very much underpower. I am not sure it will consume more petrol if you keep stepping on the gas but the ECO mode will limit the high rev of the engine. I am just guessing as I never turn on the ECO since this car is already underpower with its size and turning on ECO will make it worse. Try turning off the ECO and monitor your FC to see any difference. Link to post Share on other sites More sharing options...
qq12t Neutral Newbie December 1, 2021 Share December 1, 2021 @Ralliwira Thanks for the sharing. Will try to go without ECO and monitor. Link to post Share on other sites More sharing options...
qq12t Neutral Newbie December 1, 2021 Share December 1, 2021 @richard_crl032 Thanks for the information. I have not monitored to that level, but time to keep my eyes open. 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear December 1, 2021 Share December 1, 2021 23 hours ago, richard_crl032 said: Hi, it was said to be supplier issue of slightly undersized piston resolved after mentioned Jun 2016 ... shit happens like vw had years of issue with the dsg gearbox. It is pre-facelift version and many affected .. eo drop will be the tell-tale sign. Power loss also affected some, including facelift version but it was hearsay as I left the almost 300 strong Qashqai group then. Cheers. Richard Hi Richard, Thanks for the info. How about the 2.0 version pre facelift and facelift version? Do they have same issues like the 1.2T? I hope not. As QQ is also one of my shortlisted car to buy next yr when i want to change. I am looking at the 2.0 ones prefer the facelift version as design is more sleek than the pre facelift. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 2, 2021 Share December 2, 2021 3 hours ago, StreamRSZ said: Hi Richard, Thanks for the info. How about the 2.0 version pre facelift and facelift version? Do they have same issues like the 1.2T? I hope not. As QQ is also one of my shortlisted car to buy next yr when i want to change. I am looking at the 2.0 ones prefer the facelift version as design is more sleek than the pre facelift. Hi, All 2.0 versions has engine from Japan and not same as 1.2L turbo jointly by Nissan and Renault in UK .. not affected by this bad piston ring issue. 1.2l turbo facelift version also not affected .. only those prior to Jun 2016. As also mentioned, looks nice and nice comfortable ride but frankly not the better ones on fc and internal size .. it is compact but still much more spacious than audi Q2 or A3 that I tried to get but these ride like an expensive jap cars since entry lower models. Cheers. Richard Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 2, 2021 Share December 2, 2021 @qq12t Hi, will be a great idea ... if you svc at TanChong, you may find that it is topped up above maximum to negate this eo loss which is not a great idea also. Cheers. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear December 2, 2021 Share December 2, 2021 9 hours ago, richard_crl032 said: Hi, All 2.0 versions has engine from Japan and not same as 1.2L turbo jointly by Nissan and Renault in UK .. not affected by this bad piston ring issue. 1.2l turbo facelift version also not affected .. only those prior to Jun 2016. As also mentioned, looks nice and nice comfortable ride but frankly not the better ones on fc and internal size .. it is compact but still much more spacious than audi Q2 or A3 that I tried to get but these ride like an expensive jap cars since entry lower models. Cheers. Richard Hi, great to hear that the FL 1.2T doesnt have this issue of the bad piston ring. Thanks much for the information. is there anything else that shall be looking out for? FL versions for 1.2T and 2.0 have any sensors issue? Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 2, 2021 Share December 2, 2021 38 minutes ago, StreamRSZ said: Hi, great to hear that the FL 1.2T doesnt have this issue of the bad piston ring. Thanks much for the information. is there anything else that shall be looking out for? FL versions for 1.2T and 2.0 have any sensors issue? Hi, sorry but FL versions I know very little cos left whatsapp group and no longer had the qashqai 🙏🙏 For me, the unresolved issue on isolated (thrice into 3rd year) powerloss of 1.2L turbo that reportedly also occurring in facelift version is not acceptable since safety related to me .. rpm 800 moved to 1000 rpm and stuck when you need to get into main road or crossing junction will be disastrous. Cheers. Link to post Share on other sites More sharing options...
qq16 Neutral Newbie December 3, 2021 Share December 3, 2021 Hi, I am new to this chat. Need help going crazy with my 2016 1.2Tqq problem. When making a slow near sharp left turn there is "kor kor" sound from the front left side of the wheel. I had changed, lower arm (both side), stabilizer bar (both side), drive shaft (both side), shock absorber with bearing and mounting (both aside) and wheel bearing (both side). Problem not fixed. I want to a few Mechanics still cannot detect the sound come from where as all parts are new and tight, No free paly. Also caliper and brake pads all checks - ok. Any of you guys having the same problem in the past that can advise me. Thanks a million Link to post Share on other sites More sharing options...
PaulMeng 2nd Gear December 3, 2021 Share December 3, 2021 @qq16 9 hours ago, qq16 said: Hi, I am new to this chat. Need help going crazy with my 2016 1.2Tqq problem. When making a slow near sharp left turn there is "kor kor" sound from the front left side of the wheel. I had changed, lower arm (both side), stabilizer bar (both side), drive shaft (both side), shock absorber with bearing and mounting (both aside) and wheel bearing (both side). Problem not fixed. I want to a few Mechanics still cannot detect the sound come from where as all parts are new and tight, No free paly. Also caliper and brake pads all checks - ok. Any of you guys having the same problem in the past that can advise me. Thanks a million you might want to go different mechanic to test drive your car and find out the problem. you had just spend too much to find out the root cause of the problem Link to post Share on other sites More sharing options...
qq16 Neutral Newbie December 3, 2021 Share December 3, 2021 @PaulMeng Agreed bro. Going to another workshop tomorrow hope can solve the problem. Thanks Link to post Share on other sites More sharing options...
richard_crl032 6th Gear December 3, 2021 Share December 3, 2021 (edited) 1 hour ago, qq16 said: @PaulMeng Agreed bro. Going to another workshop tomorrow hope can solve the problem. Thanks @qq16 Hi qq16, just go back to tanchong instead of some outside workshop ... tanchong has seen all causes of noises that generic workshops cannot be more experienced and you had already tried some. Not sure svc manager, Kwek, or technical mgr, CheeKeong, are still there and you may asked for them when there. Please say Richard send his best regards if either are available. Good luck and cheers. Edited December 3, 2021 by richard_crl032 ↡ Advertisement Link to post Share on other sites More sharing options...
