robtot 1st Gear November 2, 2018 Share November 2, 2018 Send in my dad Qq for 50k under last npmp. 3.5yr with 35k mileage. They OK with the extend of the npmp beyond the 3 year period so no payment. Requested GPS update but they say over 3 yr need to pay. Skip Feedback my boot struts spoil. Open hard close soft. Not part of warranty even if within 3 yr. Skip. SA called to say oil seepage due to oil seal near pulley. Quote close to $300 for repair. Skip. Anyone know if the oil seal can be done cheaper outside? Any recommendations? Thanks! Hi Wildfaye29, Your QQ is not on Infinity 3+2 years warranty.? Is so those repairs required should be on warranty? Best Regards [confused] ↡ Advertisement Link to post Share on other sites More sharing options...
Dez 1st Gear November 3, 2018 Share November 3, 2018 Hi Sx4falcon Thanks for the information. Will check in the car with TC and ask them to check on those things you mentioned. Best Regards Hafiras Hi Roger My mileage is 41k km. Best Regards Hafiras Hi Budgetice Will do so. Thanks Best Regards Hafiras Hello Hafiras. Did u managed to resolve this issue? I also occasionally experienced a tok sound underneath my right carriage when I turned right to go up the slope or over hump. Prob was that I was unable to replicate the prob when the tech tested the car with me so TC brushed it off and only applied lubricant. My ride is about 44k, coming to 2nd yr. Link to post Share on other sites More sharing options...
Fampngem 1st Gear November 3, 2018 Share November 3, 2018 Okie.. car was staionary when the start/stop kicks in.. after that, u wanted to move off, but the engine couldnt start.. any fault lights? Cause there are instances where the engine comes back, but the car cannot move. Disengage the startstop for a few days and monitor if the issue comes back like what the other bro said.. No fault lights. Turned off these few days and nothing strange happens. Will turn it on again to see if it reoccurs again.. Link to post Share on other sites More sharing options...
Budgetice 3rd Gear November 3, 2018 Share November 3, 2018 No fault lights. Turned off these few days and nothing strange happens. Will turn it on again to see if it reoccurs again..Think you can go back to TC and ask them to check the startstop Link to post Share on other sites More sharing options...
Fi5hbone 1st Gear November 3, 2018 Share November 3, 2018 Okay I am desperate. Using stock HU and used to be able to auto connect to my phone. All of a sudden cannot auto connect. Reset the HU also cannot. I also cannot seem to just reset the BT. Anyone has any ideas? 1 Link to post Share on other sites More sharing options...
giraffey99 3rd Gear November 3, 2018 Share November 3, 2018 Okay I am desperate. Using stock HU and used to be able to auto connect to my phone. All of a sudden cannot auto connect. Reset the HU also cannot. I also cannot seem to just reset the BT. Anyone has any ideas? try deleting the bluetooth pairing on both HU and phone. Then add back again 2 Link to post Share on other sites More sharing options...
Jimmy_hayashi 1st Gear November 3, 2018 Share November 3, 2018 Okay I am desperate. Using stock HU and used to be able to auto connect to my phone. All of a sudden cannot auto connect. Reset the HU also cannot. I also cannot seem to just reset the BT. Anyone has any ideas? https://www.mycarforum.com/topic/2702219-nissan-qashqai-2014-part-2/page-436?do=findComment&comment=6480651 2 Link to post Share on other sites More sharing options...
hafiras 1st Gear November 4, 2018 Share November 4, 2018 Hello Hafiras. Did u managed to resolve this issue? I also occasionally experienced a tok sound underneath my right carriage when I turned right to go up the slope or over hump. Prob was that I was unable to replicate the prob when the tech tested the car with me so TC brushed it off and only applied lubricant. My ride is about 44k, coming to 2nd yr.Hi Dez I still havent gone back to TC due to work commitments. Try to record when the tok sound occurs. I know that its an occasional thing and its hard to record or replicate the issue. For mine, the sound became more frequent after 2 months it started and i started to record whenever i go through the same road turning right which will produce the tok sound. It took me 3 days to really catch the tok sound on recording. Or u can try turning the steering wheel to the right while the car is stationary. But dont forget to start recording before turning your steering wheel. For mine, the tok sound will also occur while turning the steering wheel when the vehicle is stationary. But it will only happened once and the sound will go away if u try to do it again. That is why i ask u to start the recording before turning the steering wheel while the vehicle is stationary for the 1st time. TC wont do anything if the problem is not consistent. I waited until the tok sound is consistent then i raised the issue with TC. There is 1 bro who gave the solution on what to change to resolve the issue a few pages back. I will be bringing up the issue again during my next servicing. The 1st time they changed my shock absorber. For 1 week all is well but the sound came back. I try to dig out on what to change to resolve the issue for you. Best Regards Hafiras Hello Hafiras. Did u managed to resolve this issue? I also occasionally experienced a tok sound underneath my right carriage when I turned right to go up the slope or over hump. Prob was that I was unable to replicate the prob when the tech tested the car with me so TC brushed it off and only applied lubricant. My ride is about 44k, coming to 2nd yr.Hi Dez Here it is: from Sx4falcon experience. Will ask TC to change the same thing for my next servicing. Sx4falcon Had similar problem. Tok sound from front right tyre area when turning right. Problem resolved afther they done the following. - RENEW FRONT STABILIZER BAR BUSH - RENEW FRONT LOWER LINK - BOTH - RENEW BOTH FRT TOP INSULATOR / BEARING & SPRING SEAT - CHK KNOCKING NOISE WHEN RIGHT TURN 1 Link to post Share on other sites More sharing options...
Hd2004 2nd Gear November 4, 2018 Share November 4, 2018 Hi Dez I still havent gone back to TC due to work commitments. Try to record when the tok sound occurs. I know that its an occasional thing and its hard to record or replicate the issue. For mine, the sound became more frequent after 2 months it started and i started to record whenever i go through the same road turning right which will produce the tok sound. It took me 3 days to really catch the tok sound on recording. Or u can try turning the steering wheel to the right while the car is stationary. But dont forget to start recording before turning your steering wheel. For mine, the tok sound will also occur while turning the steering wheel when the vehicle is stationary. But it will only happened once and the sound will go away if u try to do it again. That is why i ask u to start the recording before turning the steering wheel while the vehicle is stationary for the 1st time. TC wont do anything if the problem is not consistent. I waited until the tok sound is consistent then i raised the issue with TC. There is 1 bro who gave the solution on what to change to resolve the issue a few pages back. I will be bringing up the issue again during my next servicing. The 1st time they changed my shock absorber. For 1 week all is well but the sound came back. I try to dig out on what to change to resolve the issue for you. Best Regards Hafiras Hi Dez Here it is: from Sx4falcon experience. Will ask TC to change the same thing for my next servicing. Sx4falcon Had similar problem. Tok sound from front right tyre area when turning right. Problem resolved afther they done the following. - RENEW FRONT STABILIZER BAR BUSH - RENEW FRONT LOWER LINK - BOTH - RENEW BOTH FRT TOP INSULATOR / BEARING & SPRING SEAT - CHK KNOCKING NOISE WHEN RIGHT TURN I could reproduce the sound using the following method. When moving off slowly from parking lot, make full right turn slowly and then return steering wheel slowly till tyres straighten. I could hear the tok sound. The items changed were similar. If they are changing those items, please ensure that they perform front wheels alighnment. 1 Link to post Share on other sites More sharing options...
Fi5hbone 1st Gear November 4, 2018 Share November 4, 2018 https://www.mycarforum.com/topic/2702219-nissan-qashqai-2014-part-2/page-436?do=findComment&comment=6480651Thanks this saved me!!! Link to post Share on other sites More sharing options...
Dez 1st Gear November 5, 2018 Share November 5, 2018 Hi Dez I still havent gone back to TC due to work commitments. Try to record when the tok sound occurs. I know that its an occasional thing and its hard to record or replicate the issue. For mine, the sound became more frequent after 2 months it started and i started to record whenever i go through the same road turning right which will produce the tok sound. It took me 3 days to really catch the tok sound on recording. Or u can try turning the steering wheel to the right while the car is stationary. But dont forget to start recording before turning your steering wheel. For mine, the tok sound will also occur while turning the steering wheel when the vehicle is stationary. But it will only happened once and the sound will go away if u try to do it again. That is why i ask u to start the recording before turning the steering wheel while the vehicle is stationary for the 1st time. TC wont do anything if the problem is not consistent. I waited until the tok sound is consistent then i raised the issue with TC. There is 1 bro who gave the solution on what to change to resolve the issue a few pages back. I will be bringing up the issue again during my next servicing. The 1st time they changed my shock absorber. For 1 week all is well but the sound came back. I try to dig out on what to change to resolve the issue for you. Best Regards Hafiras Hi Dez Here it is: from Sx4falcon experience. Will ask TC to change the same thing for my next servicing. Sx4falcon Had similar problem. Tok sound from front right tyre area when turning right. Problem resolved afther they done the following. - RENEW FRONT STABILIZER BAR BUSH - RENEW FRONT LOWER LINK - BOTH - RENEW BOTH FRT TOP INSULATOR / BEARING & SPRING SEAT - CHK KNOCKING NOISE WHEN RIGHT TURN Thanks Bro for sharing! I'll try in the day 1 Link to post Share on other sites More sharing options...
November 1st Gear November 7, 2018 Share November 7, 2018 Hi Guys, My reverse camera stop working, after put gear to R the HU didn't switch reverse mode. Any idea what can I check? Thanks. 1 Link to post Share on other sites More sharing options...
Hd2004 2nd Gear November 8, 2018 Share November 8, 2018 Hi Guys, My reverse camera stop working, after put gear to R the HU didn't switch reverse mode. Any idea what can I check? Thanks.You might need to stop the car first and slowly change to reverse. If the gear is changed too fast the HU might not switch to reverse mode... Not sure yours is facing the same thing but no harm giving it a try. Link to post Share on other sites More sharing options...
Weiqiang2501 1st Gear November 8, 2018 Share November 8, 2018 You might need to stop the car first and slowly change to reverse. If the gear is changed too fast the HU might not switch to reverse mode... Not sure yours is facing the same thing but no harm giving it a try.mine happen once after i got my car back from servicing. sent back and they change the fuse wireYou might need to stop the car first and slowly change to reverse. If the gear is changed too fast the HU might not switch to reverse mode... Not sure yours is facing the same thing but no harm giving it a try.mine happen once after i got my car back from servicing. sent back and they change the fuse wire. settled 1 Link to post Share on other sites More sharing options...
Budgetice 3rd Gear November 8, 2018 Share November 8, 2018 Hi Guys, My reverse camera stop working, after put gear to R the HU didn't switch reverse mode. Any idea what can I check? Thanks.Fuse 1 Link to post Share on other sites More sharing options...
November 1st Gear November 8, 2018 Share November 8, 2018 FuseAny idea which fuse? mine happen once after i got my car back from servicing. sent back and they change the fuse wire mine happen once after i got my car back from servicing. sent back and they change the fuse wire. settled The wire or the fuse? mine happen once after i got my car back from servicing. sent back and they change the fuse wire mine happen once after i got my car back from servicing. sent back and they change the fuse wire. settled The wire or the fuse? Link to post Share on other sites More sharing options...
Budgetice 3rd Gear November 8, 2018 Share November 8, 2018 Any idea which fuse? The wire or the fuse? The wire or the fuse? If not under warranty, bring it down to any accessory shop to check.. autobacs also sell fuse and can help to change Fuse quite cheap.. few bucks only if i recall correctly Link to post Share on other sites More sharing options...
Weiqiang2501 1st Gear November 9, 2018 Share November 9, 2018 Any idea which fuse? The wire or the fuse? The wire or the fuse? i recall the comment tan chong put on servicing sheet got fuse. ↡ Advertisement Link to post Share on other sites More sharing options...
Would You Buy a Nissan...
