Audi Q2 Coming Soon
Lab4games
Of course no la.. i am saying we do tap other charging devices from battery as well. So there are a lot of charging/discharging process happening in the battery - Battery life depends very much on this. Anyway. in-car camera do have cut off voltage. But these days there are too much electronics, not surprising battery died in 8 months.
He is saying no warranty because he installed motion sensor recording, no AD will give u a free replacement, because the installation is not done by them and if there is no battery pack.
I had warranty of battery voided by 4 different AD, maybe u can let me know which AD allows and I can change car with them next time?
Thanks in advance
Engine options are very interesting
petrol
  • 1.0-litre three-cylinder turbocharged with around 110hp
  • 1.4-litre turbocharged with around 150hp
  • 2.0-litre turbocharged with around 220hp
Diesel
  • 1.6-litre four-cylinder engine with 114hp
  • 2.0-litre unit with 148hp
quattro four-wheel drive is standard on the 2.0-litre petrol and an option on the 2.0-litre diesel.
Test drove the Q2 and Q5 last weekend as Audi had roadshow at VivoCity.
They only have the 1.4L Q2 which is running on the Dry Clutch... Not fun to drive. The Q5 was solid.
New Audi SQ2 Makes Early Debut, Gets S3’s 300 PS Powertrain
https://www.carscoops.com/2018/09/new-audi-sq2-makes-early-debut-gets-s3s-300-ps-powertrain/
After months of testing having been spied on several occasions, the Audi SQ2 is finally ready to bow at next week’s 2018 Paris Auto Show.
The range-topping version of the first-ever Q2 small crossoveris powered by the same engine as the Audi S3 models.
The turbocharged 2.0-liter four-cylinder gasoline unit makes an identical 300 PS (296 hp / 221 kW) and 400 Nm (280 lb-ft) of torque, and is connected to a seven-speed DCT S Tronic transmission, and Quattro AWD.
Naught to 100 km/h (0-62 mph) takes only 4.8 seconds, or 0.2 seconds slower than the Audi S3 Sportback, and top speed is electronically capped at 250 km/h (155 mph).
Other mechanical work includes the beefier braking system, with 340 mm (13.4 in) front and 310 mm (12.2 in) rear discs, S-badged calipers available in red as an option, and new suspension. The latter brings the body by 20 mm (0.79 in) closer to the ground, makes the ride stiffer and improves the hot crossover’s cornering abilities.
On the outside, the Audi SQ2 has a reworked grille, with ‘S’ badging, a different front bumper with larger air intakes, LED headlamps and 18- or 19-inch wheels. We don’t get to see the rear, but spy shots and sources confirm quad exhaust pipes, updated bumper and LED taillights.
No images of the interior have been released at the time of writing, but Audi says the optional virtual cockpit has an ‘S’ start screen. Other novelties inside include embossed S logos, black-finished headlining, pillars and seat upholstery as standard, decorative inlay on the instrument panel in matte brushed aluminum, stainless steel pedals and footrest, and illuminated door sill trims at the front.
The seats of the Audi SQ2 are trimmed in a leather-fabric combo, with leather-Alcantara offered as an option, with contrast stitching in red and grey. Fine Nappa leather is also available, in black or black with red and a rhombus pattern, red interior rings for the air vents, and flat-bottomed steering wheel with paddle shifters.
Audi’s Pre-Sense Front is standard, as are the adaptive cruise control with Stop&Go and Traffic Jam Assist, Active Lane Assist and others. Thus, the Audi SQ2 can basically drive itself at speeds up to 64 km/h (40 mph), but drivers will still have to pay attention to the road ahead and keep their hands on the steering wheel at all times.
Audi will open the order books for the SQ2 before the end of the year, with the first deliveries expected in early 2019.
I just recently got my new Q2 1.0 with GPS & smartphone interface. Any idea how to connect to Android Auto using wifi instead of cable?
If I am not wrong not many cars enable Apple CarPlay or android auto via wifi. So cable is probably the only way to go
I am getting a pre-owned Q2 next month. Anyone knows what is the offset for the standard 17" rim? Thinking whether can do a direct swap with my current rim on the A4...
