Jellandross Supersonic September 28, 2016 Share September 28, 2016 Latest update, H-lee-bee officer came and take a look, say he had spoke to upstair neighbor, neighbor said no need to inspect, if officer think need to redo the toilet flooring, just go ahead and apply for the 50% subsidise and 25/25 share scheme. So officer will apply to do upstair flooring... hope everything settled Good for you your neiber very steady. Last time I encountered similar issue my upstair neiber bo hiu lan say they no money to repair HDB officer also bo pian. Luckily, the EASE program from HDB happened soon after so everything settled sui sui for only few hundred bucks, including new toilets, waterproofing and new tiles. ↡ Advertisement Link to post Share on other sites More sharing options...
Bluepica 4th Gear September 28, 2016 Share September 28, 2016 Good for you your neiber very steady. Last time I encountered similar issue my upstair neiber bo hiu lan say they no money to repair HDB officer also bo pian. Luckily, the EASE program from HDB happened soon after so everything settled sui sui for only few hundred bucks, including new toilets, waterproofing and new tiles. But i also give and take... I told officer I applied two more layers of sealant and gloss paint and last layer of emulsion paint...because this is not some obvious leakage problem, let see if the yellow patch reappear or not, if yes, we go ahead with the plan, if not, he can cancel the request, because such request according to him, takes time too. 1 Link to post Share on other sites More sharing options...
Bluepica 4th Gear September 29, 2016 Share September 29, 2016 Is this floortrap acceptable?? will water seep in between the concrete and the pipe and spell trouble for my downstairs neighbor in time to come? Link to post Share on other sites More sharing options...
Hibeam2 4th Gear September 29, 2016 Share September 29, 2016 Is this floortrap acceptable?? will water seep in between the concrete and the pipe and spell trouble for my downstairs neighbor in time to come? Came across this post in renotalk while i was researching on stuff relating to renovation http://www.renotalk.com/forum/topic/62505-top-kew-drive/?do=findComment&comment=857733 Apparently, the above (and the way your bathroom is done) is suppose to be the correct way. It'll be great if there are experts in this forum who can verify this. Link to post Share on other sites More sharing options...
Bluepica 4th Gear September 29, 2016 Share September 29, 2016 Came across this post in renotalk while i was researching on stuff relating to renovation http://www.renotalk.com/forum/topic/62505-top-kew-drive/?do=findComment&comment=857733 Apparently, the above (and the way your bathroom is done) is suppose to be the correct way. It'll be great if there are experts in this forum who can verify this. hmmm... I thought the whole floor trap need to be in one piece (unlike my current, the cover chopped of from the main pipe) so that water got no chance to seep into the concrete.... Link to post Share on other sites More sharing options...
Bluepica 4th Gear September 29, 2016 Share September 29, 2016 hmmm... I thought the whole floor trap need to be in one piece (unlike my current, the cover chopped of from the main pipe) so that water got no chance to seep into the concrete.... I have forwarded the photo to the HDB officer attending to my case, he said my contractor cutting corner..... there should not be a joint from the white piping as well.... the floor trap should be in one full piece. Asked me to ask contractor to re do it or I will have to redo it few years down the road when the concrete joint to the pipe gives way and start to leak downstairs. 1 Link to post Share on other sites More sharing options...
13177 Hypersonic September 29, 2016 Share September 29, 2016 (edited) Looks like cannot trust contractor nowadays, as many of them anyhow do or do shabby works and create problems later. They only know how to collect money but dont know how to produce quality work. Edited September 29, 2016 by 13177 Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear May 3, 2018 Share May 3, 2018 My unit also encounter leaking from upper floor. I was informed $1200 job. HDB foots $600 Upper $300 Me $300 Link to post Share on other sites More sharing options...
Buadongdong Twincharged May 3, 2018 Share May 3, 2018 My unit also encounter leaking from upper floor. I was informed $1200 job. HDB foots $600 Upper $300 Me $300 Sounds about right. Then HDB will send a contractor to come and do grouting but will be very messy and dusty. Link to post Share on other sites More sharing options...
Mustank Hypersonic May 3, 2018 Share May 3, 2018 Sounds about right. Then HDB will send a contractor to come and do grouting but will be very messy and dusty.No choice oneThis kind of job sure messy one 1 Link to post Share on other sites More sharing options...
13177 Hypersonic May 3, 2018 Share May 3, 2018 No choice one This kind of job sure messy one Treat it like hdb home improvement programme lo, when they come and upgrade your toilets also very messy and dirty. 1 Link to post Share on other sites More sharing options...
Buadongdong Twincharged May 3, 2018 Share May 3, 2018 No choice one This kind of job sure messy one Yah.. have to ensure that they close the door and at least lay some canvas over to collect the large debris. Otherwise, clean up is gonna be a headache lo.. 2 Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 3, 2018 Share May 3, 2018 My unit also encounter leaking from upper floor. I was informed $1200 job. HDB foots $600 Upper $300 Me $300 HDB will still foot? thought always the case of 50/50 between upper and lower floor. Link to post Share on other sites More sharing options...
Buadongdong Twincharged May 3, 2018 Share May 3, 2018 HDB will still foot? thought always the case of 50/50 between upper and lower floor.If within 10yrs, hdb will pay full because water proofing warranty is for 10yrs by the builder. 2 Link to post Share on other sites More sharing options...
carloverguy2017 5th Gear May 3, 2018 Share May 3, 2018 More than 10 years already. But if I'm not wrong, HDB has this graceful act of footing 50% while the two tenants pays the oter 25%+25% Link to post Share on other sites More sharing options...
Count-Bracula Twincharged September 20, 2018 Share September 20, 2018 More than 10 years already. But if I'm not wrong, HDB has this graceful act of footing 50% while the two tenants pays the oter 25%+25% That's correct. If within 10yrs, hdb will pay full because water proofing warranty is for 10yrs by the builder. Now after waterproofing works done, warranty is only for one year . . . . HDB contractor say one. Link to post Share on other sites More sharing options...
Buadongdong Twincharged September 20, 2018 Share September 20, 2018 That's correct. Now after waterproofing works done, warranty is only for one year . . . . HDB contractor say one. Is it? Water-proofing works has always been 10yrs, either the water-proofing specialist 5yrs and contractor 5yrs back to back or 10yrs straight by specialist leh.. I go ask my friends and see if this has changed.. Link to post Share on other sites More sharing options...
Jman888 Moderator September 20, 2018 Share September 20, 2018 i dun remember paying, maybe use cpf to pay. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
Ceiling fan
Ceiling fan
Hdb flat renovation
Hdb flat renovation
Higher property tax for most 3-room HDB flats, all bigger units from Jan 1, 2022: Iras
Mold/Fungus on the ceiling
Properties info
Properties info
