benoit16 4th Gear August 6, 2018 Share August 6, 2018 Thanks. Am driving a Honda Stream, and will usually let my kids watch animation movies on the rear overhead screen, so I would most probably put a pair of coaxials there since the cost isn't very high and labour fee would already be needed anyway (or is that charged separately?). What do I look out for in determining the required power? I see a lot of specifications/numbers but have no idea what I ought to filter. Between a subwoofer and an amplifier, which one will give a more obvious difference? can look at jbl speakers. they can run at lower power too.subwoofer makes more of a difference unless your amp is with a DSP function ↡ Advertisement 1 Link to post Share on other sites More sharing options...
YorYor 1st Gear August 8, 2018 Share August 8, 2018 So I just have to look at the RMS value and find something sub-100W? Guess I won't need either the amp or subwoofer then, thanks! Link to post Share on other sites More sharing options...
Karu 6th Gear August 8, 2018 Share August 8, 2018 Collecting car soon. Probably changing out stock speakers without amp. What can I get below 500? Link to post Share on other sites More sharing options...
benoit16 4th Gear August 8, 2018 Share August 8, 2018 So I just have to look at the RMS value and find something sub-100W? Guess I won't need either the amp or subwoofer then, thanks! yes look at rms value and also sensitivity of the speaker. for me, I used jbl 609 speakers with stock HU before and it was alright Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 8, 2018 Share August 8, 2018 (edited) Collecting car soon. Probably changing out stock speakers without amp. What can I get below 500? Hertz HSK 165 Sensitivity dB SPL 92 http://www.mycarforum.com/index.php?app=sgcarstore&req=showprod&product=58169&si=&cat=6&low=0&high=0&div=adv_search&sti=Component%20Speakers http://www.sgcarmart.com/products/product_reviews.php?ID=4669&RID=2478#comments2478 http://www.sgcarmart.com/products/overview.php?ID=4669 Edited August 8, 2018 by Jamesc Link to post Share on other sites More sharing options...
giraffey99 3rd Gear August 10, 2018 Share August 10, 2018 So I just have to look at the RMS value and find something sub-100W? Guess I won't need either the amp or subwoofer then, thanks! In general, yes. More importantly. It depends on your expectations and budget on the type of speakers, and whether amp, dsp and sub is required. Link to post Share on other sites More sharing options...
Hosaybo 6th Gear August 10, 2018 Share August 10, 2018 Amp is important... As most HU is puny in power. A decent package amp plus speakers can be found in the hertz.... Get a hcp 4 plus speakers. It gives decent sound. Link to post Share on other sites More sharing options...
YorYor 1st Gear August 11, 2018 Share August 11, 2018 Thanks for all the info! Will consider trying out a set of components in front at least. I read that it's possible to even leave the rear on stock and there won't be much of a difference even if I install a pair of coaxials there? Link to post Share on other sites More sharing options...
benoit16 4th Gear August 12, 2018 Share August 12, 2018 Thanks for all the info! Will consider trying out a set of components in front at least. I read that it's possible to even leave the rear on stock and there won't be much of a difference even if I install a pair of coaxials there?not as significant unless you do proper setup and tuning etc. btw if you are looking for active sub, I have a 10 inch one used for just 2 months to let go haha. Link to post Share on other sites More sharing options...
Headshok 1st Gear August 15, 2018 Share August 15, 2018 Thanks for all the info! Will consider trying out a set of components in front at least. I read that it's possible to even leave the rear on stock and there won't be much of a difference even if I install a pair of coaxials there? yoyo! Its been sometime since i ventured down to MCF! Anyway, basically, rear fill is good if you have to entertain rear passengers ( mostly to keep kids entertained) Hardcore ICE people do nothave the rear fill. Overall, for a setup, it will depend on your overall budget and expectations :) Cheers! Link to post Share on other sites More sharing options...
YorYor 1st Gear August 15, 2018 Share August 15, 2018 Yeah, got kids to entertain during long road trips, so need to have rear fill. I've set my eyes on a set of Pioneer A1606C components for the front and TS-G1620F for the rear that seems to fit my budget. Think I will skip the amp and subwoofer. My expectatations aren't high - as long as it gives a better experience than the stocks, I'll be satisfied! Not like the speakers will help to remove the static from the radio anyway hahaha! Link to post Share on other sites More sharing options...
Pocy Hypersonic August 15, 2018 Share August 15, 2018 Hertz HSK 165 Sensitivity dB SPL 92 http://www.mycarforum.com/index.php?app=sgcarstore&req=showprod&product=58169&si=&cat=6&low=0&high=0&div=adv_search&sti=Component%20Speakers http://www.sgcarmart.com/products/product_reviews.php?ID=4669&RID=2478#comments2478 http://www.sgcarmart.com/products/overview.php?ID=4669 Cash and carry at $400. Do you know installation cost and also SP? 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 15, 2018 Share August 15, 2018 Cash and carry at $400. Do you know installation cost and also SP? Replace speakers is about $30 - $80. Actually its a very simple job. Unscrew 4 screws to remove the old speakers and fix the new speakers. SP should be about $100 - $300 depending on 2 or 4 doors, 1 or 2 layers. Link to post Share on other sites More sharing options...
Pocy Hypersonic August 15, 2018 Share August 15, 2018 Replace speakers is about $30 - $80. Actually its a very simple job. Unscrew 4 screws to remove the old speakers and fix the new speakers. SP should be about $100 - $300 depending on 2 or 4 doors, 1 or 2 layers. Good info on pricing, thanks!Did you use this spk before? Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 15, 2018 Share August 15, 2018 Good info on pricing, thanks! Did you use this spk before? I used Vifa CS 2399. Its a power hungry speaker but I used it with an amplifier. All the request here is for using a speaker without amplifier so the speaker needs to be very efficient and Hertz is very efficient with sensitivity at 92. For reference the Vifa is only 87. Before buying you can ask the dealer to demo the speakers to see if you like the sound. You just have to take note when hearing the speaker ask the dealer to run without an amp. Also the sound of the speaker will take sound of the head unit. So if the dealer uses a really good head unit and your head unit is not so good, the sound in your car will not sound as good as in the shop. 1 Link to post Share on other sites More sharing options...
kylemart Neutral Newbie August 15, 2018 Share August 15, 2018 unless your car comes with premium sound system, 95% of our cars are paper cone speakers. My PI car lagi best, came empty !! Any upgrade from paper will show significant improvement. A < $100 Pioneer set will be good enough. Many entry level speakers around lah, Set yourself a $200+ budget and go look at MB Quart, JBL, Pioneer, Alpine, Rockford Fosgate. I noticed a certain advertiser at Marketplace (MM) has a variety of speakers. Go there and tell the guy your listening style, ask to recommend for your budget. Personally, I use CDT. I am totally agree with you mate. And I am going for the pioneer. It's the top notch brand in the market regarding modern technologies I used Vifa CS 2399. Its a power hungry speaker but I used it with an amplifier. All the request here is for using a speaker without amplifier so the speaker needs to be very efficient and Hertz is very efficient with sensitivity at 92. For reference the Vifa is only 87. Before buying you can ask the dealer to demo the speakers to see if you like the sound. You just have to take note when hearing the speaker ask the dealer to run without an amp. Also the sound of the speaker will take sound of the head unit. So if the dealer uses a really good head unit and your head unit is not so good, the sound in your car will not sound as good as in the shop. Interested to know more experience about this product. It seems good and interesting one to pick for my car ↡ Advertisement Link to post Share on other sites More sharing options...
2026 Mazda EZ-60 / CX-6e
2025 Mazda 6e
2025 Mazda 6e
Mazda FC3S RX-7
Mazda FC3S RX-7
MAZDA 6
MAZDA 6
Win a Limited-Edition Mazda RX-7 Diecast in Sgcarmart livery!
2022 Mazda CX-5 Facelift
