BanCoe Hypersonic February 24, 2016 Share February 24, 2016 (edited) Agreed. My kitchen sink cabinet made of plywood gave way after 3 years, partly due to water ingress. The plywood is so soft and weak. Changed to Ikea cabinet, the compressed wood doors are so heavy, the laminate is well made, overall should be more durable than those plywood doors. Are you talking about the countertop right ?? If that is the item you can use the so called PVC type Corrian or even granite and I kept the base tiles exposed and the wood frame structure can be seen when the doors are opened so that in case there is water seepage it can be seen easily as there are drainage pipes and this area is always somehow moist due to spillage over the silicon between the basin and countertop and gets smelly - I leave ithe doors open always overnight - I put some pandan leaves always so roaches / chichaks don't come in Edited February 24, 2016 by BanCoe ↡ Advertisement Link to post Share on other sites More sharing options...
Matrix0405 5th Gear February 24, 2016 Share February 24, 2016 Want to rebuild (DIY) part of the toilet door frame. The lower portion rotten due to water. Want to chop off the bottom section and replace with wood. Where to buy blocks of wood cut to dimension or long rectangle strips of woods? Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear February 24, 2016 Share February 24, 2016 Quality has dropped badly in all houses now, whether hdb or private!This is due to some greedy developers want to have big profits. Another type is use low quality materials cut cost to make the selling price looks "affordable" or cheaper compare to other projects. Link to post Share on other sites More sharing options...
Yaloryalor 5th Gear February 24, 2016 Share February 24, 2016 I think the immediately negatives are the owners. This incident will affect their selling price or rental yield. Link to post Share on other sites More sharing options...
Wt_know Supersonic February 25, 2016 Share February 25, 2016 (edited) where got ... muahahahahaha ... This is due to some greedy developers want to have big profits.Another type is use low quality materials cut cost to make the selling price looks "affordable" or cheaper compare to other projects. Edited February 25, 2016 by Wt_know 2 Link to post Share on other sites More sharing options...
Flying_genie 6th Gear February 25, 2016 Share February 25, 2016 Almost every new development in Singapore have a China partner, either as main-con or sub-con. Be prepared for more mishaps, especially once the developments get older; or maybe as soon as the glue dries. Link to post Share on other sites More sharing options...
BanCoe Hypersonic February 25, 2016 Share February 25, 2016 Want to rebuild (DIY) part of the toilet door frame. The lower portion rotten due to water. Want to chop off the bottom section and replace with wood. Where to buy blocks of wood cut to dimension or long rectangle strips of woods? if you want in the city area - try Kim Hup Lee 16 King Georges Avenue (opposite Song Lim Bldg and the blue mosque near on Victoria Street/jalan Sultan ) , I see a lot of planks there last time , there was another one in Balestier Road near Khalsa Assn, but i think they closed down already) But I dont know if they cut on the spot the size (if not carry a saw and cut on the spot ) unless you got a pick up/lorry or van But you must check out the different types of wood suitable too; 2 Link to post Share on other sites More sharing options...
Throttle2 Supersonic February 25, 2016 Share February 25, 2016 So after the launch how is poiz doing? Same devekoper i think Link to post Share on other sites More sharing options...
Beregond Supersonic February 25, 2016 Share February 25, 2016 if got burget , try to get 柚木 furniture they really can last a few generation Link to post Share on other sites More sharing options...
Alpha78 6th Gear February 25, 2016 Share February 25, 2016 Are you talking about the countertop right ?? If that is the item you can use the so called PVC type Corrian or even granite and I kept the base tiles exposed and the wood frame structure can be seen when the doors are opened so that in case there is water seepage it can be seen easily as there are drainage pipes and this area is always somehow moist due to spillage over the silicon between the basin and countertop and gets smelly - I leave ithe doors open always overnight - I put some pandan leaves always so roaches / chichaks don't come inMy counter top was made of acrylic. But all counter tops will have a layer of plywood below. To make things worse, the sink was mounted from below, and not using proper bracket. Over time water leaked through the gap between the sink and the counter top. I had no say in the construction as it was fidone by the previous house owner. So when I changed to Ikea cabinet and counter top, decided to do top mount of the sink. Aesthetically not as nice, but more lasting and water tight. Very important as my mom cooks 2 meals a day in the kitchen. Link to post Share on other sites More sharing options...
Kb27 Supersonic February 25, 2016 Share February 25, 2016 There are various ways to "anchor" a piece of wood and the cabinet, to the wall. Length, width, number of screws used, depth of hole, type of anchors, will determine if they have enough load-bearing. If properly done, the cabinet will stay on the wall indefinitely. If you scrimp on something, then it will fall off. Link to post Share on other sites More sharing options...
Dleodleo Twincharged February 26, 2016 Share February 26, 2016 Agreed. My kitchen sink cabinet made of plywood gave way after 3 years, partly due to water ingress. The plywood is so soft and weak. Changed to Ikea cabinet, the compressed wood doors are so heavy, the laminate is well made, overall should be more durable than those plywood doors. Ya true. Mine too was spoilt . Wonder why they nvr use cement instead of plywood for the sink area. Our parents' time they use cement instead of plywood right? I always tell my first timers friends who are renovating their house to make sure that their sink area are not made of wood. Make sure it is made with cement. Now everything made in China. Even the workers that "do" your renovation also china. When I ask for replacement of my spoilt heater, I insisted that a Singaporean electrician. If not later kena electric shock and die. http://singaporeseen.stomp.com.sg/this-urban-jungle/18-year-old-dies-during-shower-at-hougang-flat-after-freak-accident-with-water Link to post Share on other sites More sharing options...
Volvobrick Supersonic February 26, 2016 Share February 26, 2016 Still can find Singaporean electricians etc meh? At most can find Malaysians... Better equipped yourself with a test pen and have some basic knowledge of electrical circuits..... 4 Link to post Share on other sites More sharing options...
Pinobii Hypersonic February 26, 2016 Share February 26, 2016 Ya true. Mine too was spoilt . Wonder why they nvr use cement instead of plywood for the sink area. Our parents' time they use cement instead of plywood right? I always tell my first timers friends who are renovating their house to make sure that their sink area are not made of wood. Make sure it is made with cement. Now everything made in China. Even the workers that "do" your renovation also china. When I ask for replacement of my spoilt heater, I insisted that a Singaporean electrician. If not later kena electric shock and die. http://singaporeseen.stomp.com.sg/this-urban-jungle/18-year-old-dies-during-shower-at-hougang-flat-after-freak-accident-with-water Wise choice 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic February 26, 2016 Share February 26, 2016 Can, but very old kind. Mine 60+ ownself employ ownself kind. Still can find Singaporean electricians etc meh? At most can find Malaysians... Better equipped yourself with a test pen and have some basic knowledge of electrical circuits..... 1 Link to post Share on other sites More sharing options...
KumarB 3rd Gear February 29, 2016 Share February 29, 2016 (edited) sometimes i feel perturbed by the way hdb works. when the land is released for bidding, the one who bid the highest gets the dough, this pushes up the house prices as the developer need to earn a princely amount of $. why can't they choose the one with the lowest bidding? collect money they will take the highest bid. when choosing vendors for their contract services they will take the vendor with lowest tender amount. what fxxk logic is this seriously? they should wake up their ideas and start to accept bid lowest amount from the developer in order to keep competitive and affordable price for hdb peasants like us. Edited February 29, 2016 by KumarB Link to post Share on other sites More sharing options...
Kusje Supersonic February 29, 2016 Share February 29, 2016 sometimes i feel perturbed by the way hdb works. when the land is released for bidding, the one who bid the highest gets the dough, this pushes up the house prices as the developer need to earn a princely amount of $. why can't they choose the one with the lowest bidding? collect money they will take the highest bid. when choosing vendors for their contract services they will take the vendor with lowest tender amount. what fxxk logic is this seriously? they should wake up their ideas and start to accept bid lowest amount from the developer in order to keep competitive and affordable price for hdb peasants like us. Is this a joke? Link to post Share on other sites More sharing options...
Mockngbrd Supersonic February 29, 2016 Share February 29, 2016 Is this a joke? Accept lowest bid than building collapse kpkb gahmen take cheapo contractor ↡ Advertisement Link to post Share on other sites More sharing options...
Shop Houses Collapse at Syed Alwi Road
From $10 billion to zero: How a crypto hedge fund collapsed and dragged many investors down with it
Properties info
Properties info
Renovation budget that blows your mind
Worker missing after building structure collapses at Tanjong Pagar work site.
Hidden wall bed
Hidden wall bed
Security guard abuse at Condos
