Gwg717 Clutched July 29, 2017 Share July 29, 2017 Hi, can share how much cheaper AIG quote you? i do not received offer yet from AIG as mine expire in end Nov ↡ Advertisement Link to post Share on other sites More sharing options...
camrysfe 5th Gear July 30, 2017 Share July 30, 2017 Did you get the AIG quote as well? I received the same letter from BM about AXA. As my quote from AIG was cheaper than AXA, I went with AIG in the end. Off topic, seems like the current Camry has been discontinued. sgcarmart states that BM stopped selling in June this year. Yes the last batch of current Camry has been out of stock for quite a number of months already. Link to post Share on other sites More sharing options...
Lanky 2nd Gear July 31, 2017 Share July 31, 2017 Hi, can share how much cheaper AIG quote you? i do not received offer yet from AIG as mine expire in end Nov sent you a PM on this. Link to post Share on other sites More sharing options...
Ckwong75 Neutral Newbie August 1, 2017 Share August 1, 2017 Hi fellow Camry owners, I own a 2016 Camry and would like to seek your recommendation on car mats. I have tried a few car mats similar to 3M but the rear passenger one doesn't fit nicely and always run. I'll like to check if you have better ones to suggest. Thank you in advance! Link to post Share on other sites More sharing options...
Heman75 Supercharged August 1, 2017 Share August 1, 2017 Hi fellow Camry owners, I own a 2016 Camry and would like to seek your recommendation on car mats. I have tried a few car mats similar to 3M but the rear passenger one doesn't fit nicely and always run. I'll like to check if you have better ones to suggest. Thank you in advance! Bro search for 3D car mat. They will fit nicely for sure . I am using 3D Matt given by the AD . Link to post Share on other sites More sharing options...
Mugenr 2nd Gear August 2, 2017 Share August 2, 2017 Hi guys, do any of you have very low idling issue when u stop with gear in D or even at N? Link to post Share on other sites More sharing options...
Xtrah 3rd Gear August 2, 2017 Share August 2, 2017 Hi guys, do any of you have very low idling issue when u stop with gear in D or even at N? How old is your car? For an age vehicle, the culprit maybe due to bad oxygen sensor, dirty throttle body or spark plug (check gap). Link to post Share on other sites More sharing options...
Mugenr 2nd Gear August 2, 2017 Share August 2, 2017 (edited) 160K km on the clock for a Sept 2013 Camry I figured it could be the spark plugs too Edited August 2, 2017 by Mugenr Link to post Share on other sites More sharing options...
camrysfe 5th Gear August 2, 2017 Share August 2, 2017 (edited) 160K km on the clock for a Sept 2013 Camry I figured it could be the spark plugs too Likely to be dirty throttle body if this symptom happened after resetting battery Edited August 2, 2017 by camrysfe Link to post Share on other sites More sharing options...
Mugenr 2nd Gear August 3, 2017 Share August 3, 2017 So this happened after I collected the car yesterday. Upon closer inspection of the servicing sticker and my ODO I realized that the car has been parked since mid June So it might have been a startup issue Today's running has been fine. Fingers crossed. Link to post Share on other sites More sharing options...
teomingern 6th Gear August 3, 2017 Share August 3, 2017 So this happened after I collected the car yesterday. Upon closer inspection of the servicing sticker and my ODO I realized that the car has been parked since mid June So it might have been a startup issue Today's running has been fine. Fingers crossed. What do you mean? The car's engine has not been started since mid June this year? Link to post Share on other sites More sharing options...
Mugenr 2nd Gear August 4, 2017 Share August 4, 2017 probably started or not. but the mileage on the sticker and the day I took over was almost the same as it was more than a month ago. shows that u can leave the car unstarted for a month's holiday and come back and still be a reliable cruiser. Link to post Share on other sites More sharing options...
teomingern 6th Gear August 5, 2017 Share August 5, 2017 probably started or not. but the mileage on the sticker and the day I took over was almost the same as it was more than a month ago. shows that u can leave the car unstarted for a month's holiday and come back and still be a reliable cruiser. They must have disconnected the battery... the battery will go flat if the car is not started for one month... you're buying a second hand car, so the dealers will just give you a brand new battery when you take delivery, so you will never know if the car's battery went flat or not... Hi fellow Camry owners, I own a 2016 Camry and would like to seek your recommendation on car mats. I have tried a few car mats similar to 3M but the rear passenger one doesn't fit nicely and always run. I'll like to check if you have better ones to suggest. Thank you in advance! You can buy the anti-slip mats and slip them in between the original car mats and the new ones you bought... this will prevent the new mats from slipping... Link to post Share on other sites More sharing options...
Ckwong75 Neutral Newbie August 7, 2017 Share August 7, 2017 They must have disconnected the battery... the battery will go flat if the car is not started for one month... you're buying a second hand car, so the dealers will just give you a brand new battery when you take delivery, so you will never know if the car's battery went flat or not... You can buy the anti-slip mats and slip them in between the original car mats and the new ones you bought... this will prevent the new mats from slipping... Thank you for your feedback! Link to post Share on other sites More sharing options...
Gwg717 Clutched August 12, 2017 Share August 12, 2017 Dear friends, May i have your advice on any car vacuum cleaner to recommend? Brand/corded/cordless. thks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
2024 camry
2024 camry
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota Crown SUV Reportedly Planned Because Nothing Is Sacred Anymore
