Atlantis80 1st Gear February 7, 2016 Share February 7, 2016 After I updated my profile, my time settings becom screwed up. The time now reads as 11.35am SGT, when it's now 7.35pm GMT +8 (Singapore time). Can anyone advise how do I switch the time back? I tried exploring Edit Profile but there's no option for me to change. Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Angcheek Hypersonic February 8, 2016 Share February 8, 2016 On 2/7/2016 at 11:38 AM, Atlantis80 said: After I updated my profile, my time settings becom screwed up. The time now reads as 11.35am SGT, when it's now 7.35pm GMT +8 (Singapore time). Can anyone advise how do I switch the time back? I tried exploring Edit Profile but there's no option for me to change. Thanks! your computer is set to GMT +8 ? 6 Link to post Share on other sites More sharing options...
Atlantis80 1st Gear February 8, 2016 Author Share February 8, 2016 Yes - time settings are correct on all my devices (be it computer, tablet or mobile phones). When I open MCF website without logging in, the time settings is correct. But when I log in with my credentials, the timing screws... Link to post Share on other sites More sharing options...
Thorvon 1st Gear March 17, 2016 Share March 17, 2016 Wondering if anyone has any update on this? Previously when reading the forum anonymously the timestamps were all correct. After signing up for an account, all the times are wrong, showing GMT time zone. Can't find a setting to change the time too. Link to post Share on other sites More sharing options...
1fast1 Supersonic March 20, 2016 Share March 20, 2016 (edited) I'm seeing weird posting times (for example "Today, 11.23pm" when it's half past seven in the morning today). Is there an issue with the time server that MCF is using? My local clock has been set correctly, and the issue is on multiple platforms and network connections. EDIT: and this post got tagged for 11:39pm today even though I'm posting from 7.39am Singapore. Likely some sort of timezone problem. I've never changed location , am going through a local ISP and am not connecting through a VPN. Edited March 20, 2016 by Turboflat4 Link to post Share on other sites More sharing options...
RadX Moderator March 20, 2016 Share March 20, 2016 send to admin. Small correction needed. On 3/20/2016 at 11:39 PM, Turboflat4 said: I'm seeing weird posting times (for example "Today, 11.23pm" when it's half past seven in the morning today). Is there an issue with the time server that MCF is using? My local clock has been set correctly, and the issue is on multiple platforms and network connections. EDIT: and this post got tagged for 11:39pm today even though I'm posting from 7.39am Singapore. Likely some sort of timezone problem. I've never changed location , am going through a local ISP and am not connecting through a VPN. poonde search next time hor.......this aldy mentioned...hahhahaahha but yeah, this issue happened to me and told lj abt it and he corrected it. @pchou for your necessary please 1 Link to post Share on other sites More sharing options...
1fast1 Supersonic March 20, 2016 Share March 20, 2016 On 3/20/2016 at 11:48 PM, RadX said: send to admin. Small correction needed. poonde search next time hor.......this aldy mentioned...hahhahaahha but yeah, this issue happened to me and told lj abt it and he corrected it. @pchou for your necessary please LJ = L** J*** ? Link to post Share on other sites More sharing options...
RadX Moderator March 21, 2016 Share March 21, 2016 On 3/20/2016 at 11:58 PM, Turboflat4 said: LJ = L** J*** ? if you cannot login after this, you know why...hahahah Link to post Share on other sites More sharing options...
pChou Admin March 22, 2016 Share March 22, 2016 @atlantis08 @thorvon @turbofl4@turboflat4 Let us check and get back to you guys! On 3/20/2016 at 11:48 PM, RadX said: send to admin. Small correction needed. poonde search next time hor.......this aldy mentioned...hahhahaahha but yeah, this issue happened to me and told lj abt it and he corrected it. @pchou for your necessary please thanks for informing! hahhaaaaa Link to post Share on other sites More sharing options...
RadX Moderator March 22, 2016 Share March 22, 2016 On 3/22/2016 at 8:25 AM, pChou said: @atlantis08 @thorvon @turbofl4@turboflat4 Let us check and get back to you guys! thanks for informing! hahhaaaaa You KOW then reply Your clock heaven time zone ah... Haaaa Link to post Share on other sites More sharing options...
1fast1 Supersonic March 22, 2016 Share March 22, 2016 On 3/22/2016 at 8:25 AM, pChou said: @atlantis08 @thorvon @turbofl4@turboflat4 Let us check and get back to you guys! thanks for informing! hahhaaaaa Thanks, haha Admin cannot praise one. Link to post Share on other sites More sharing options...
pChou Admin March 23, 2016 Share March 23, 2016 On 3/22/2016 at 9:09 AM, RadX said: You KOW then reply Your clock heaven time zone ah... Haaaa wahhaha i go ask the master in heaven first! Link to post Share on other sites More sharing options...
pChou Admin March 23, 2016 Share March 23, 2016 On 3/20/2016 at 11:58 PM, Turboflat4 said: LJ = L** J*** ? can check if you're still having the same issues? On 2/8/2016 at 1:37 PM, Atlantis80 said: Yes - time settings are correct on all my devices (be it computer, tablet or mobile phones). When I open MCF website without logging in, the time settings is correct. But when I log in with my credentials, the timing screws... hi, can you check if you still hv the same problem? Link to post Share on other sites More sharing options...
Atlantis80 1st Gear March 25, 2016 Author Share March 25, 2016 On 3/23/2016 at 6:53 AM, pChou said: can check if you're still having the same issues? hi, can you check if you still hv the same problem? Thanks for checking. It's been resolved (by you?) already. :) Link to post Share on other sites More sharing options...
pChou Admin March 27, 2016 Share March 27, 2016 On 3/25/2016 at 8:01 AM, Atlantis80 said: Thanks for checking. It's been resolved (by you?) already. :) Haha no not me. Too advance :p. The IT team does it.. I know nuts about the codes haha Link to post Share on other sites More sharing options...
Thorvon 1st Gear March 27, 2016 Share March 27, 2016 Unfortunately my problem isn't fixed yet! Link to post Share on other sites More sharing options...
SimonSeah 2nd Gear April 22, 2016 Share April 22, 2016 I have the same issue too. Link to post Share on other sites More sharing options...
Cokiee 1st Gear November 18, 2017 Share November 18, 2017 (edited) Sorry to dig this up, but i'm experiencing the same problem. @pchou, can i seek your help please? Edited November 18, 2017 by Cokiee ↡ Advertisement Link to post Share on other sites More sharing options...
Sg Election 2025!
Sg Election 2025!
MyResponder app to call SCDF
Help with STA report remarks
Changing of Spark Plugs
On borrowed Time!
On borrowed Time!
