Watwheels Supersonic February 4, 2018 Share February 4, 2018 hmm any reason for such a request? He's going to steal mummy's credit card to replace a tire. ↡ Advertisement 4 Link to post Share on other sites More sharing options...
hsl118 6th Gear February 4, 2018 Share February 4, 2018 He's going to steal mummy's credit card to replace a tire. Hopefully 4 tyres! Thanks for this will go take a look coming week Link to post Share on other sites More sharing options...
xiaozhi86 2nd Gear March 6, 2018 Share March 6, 2018 Not this Kim hoe shit again. Which Kim Hoe?? Please clarify. The one at Ubi or the one at kaki Bukit? which one to avoid? Also my car now is using 245/45/r17. May i change to 225 or even 235/45/r17 as this 2 size are more common? 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear March 7, 2018 Share March 7, 2018 which one to avoid? Also my car now is using 245/45/r17. May i change to 225 or even 235/45/r17 as this 2 size are more common? yes you can change to 225/50/17 so long the rim width not wider than 8 inch . Link to post Share on other sites More sharing options...
ntuc2018 3rd Gear April 6, 2018 Share April 6, 2018 Hong Tyre 1 Link to post Share on other sites More sharing options...
Angcheek Hypersonic May 7, 2018 Share May 7, 2018 Anyone has a tyre shop near SingMing or AMK to recommend ??? My tyre like pongchek liao Link to post Share on other sites More sharing options...
Newbie26 Hypersonic May 7, 2018 Share May 7, 2018 so many, if just to change 1-2 tyres, any shop can do if u go by those with>10 good reviews, there are MBM wheelpower, Beng heng etc if you dont mind 10 mins drive, drop by autokinetics along macpherson road many good reviews online Anyone has a tyre shop near SingMing or AMK to recommend ??? My tyre like pongchek liao 7 Link to post Share on other sites More sharing options...
Angcheek Hypersonic May 7, 2018 Share May 7, 2018 so many, if just to change 1-2 tyres, any shop can do if u go by those with>10 good reviews, there are MBM wheelpower, Beng heng etc if you dont mind 10 mins drive, drop by autokinetics along macpherson road many good reviews online Thanks bro . My rtf maybe still can tahan 10min drive 2 Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 9, 2018 Share May 9, 2018 Thanks bro . My rtf maybe still can tahan 10min drive yes Runflat tire allows you to continue driving for 85km at MAX 80km/h (with Zero pressure) But the longer you drag your tire will likely further damages and made it beyond repair. To Save your Punctured Runflat try to fill the Air as soon as your can (best is over inflate may be 20% higher) allow the pressure sustain longer to prevent further damaged to your Punctured tires. And also Request Internal repair (patch or Patch & plug) BEST (only method recognized by Most tire manufacturers). TIres are the only 4 contacts between Road and You . 1 Link to post Share on other sites More sharing options...
Angcheek Hypersonic May 9, 2018 Share May 9, 2018 yes Runflat tire allows you to continue driving for 85km at MAX 80km/h (with Zero pressure) But the longer you drag your tire will likely further damages and made it beyond repair. To Save your Punctured Runflat try to fill the Air as soon as your can (best is over inflate may be 20% higher) allow the pressure sustain longer to prevent further damaged to your Punctured tires. And also Request Internal repair (patch or Patch & plug) BEST (only method recognized by Most tire manufacturers). TIres are the only 4 contacts between Road and You . Thanks for the advice bro. Will take note of that. Cheers Link to post Share on other sites More sharing options...
Beregond Supersonic May 9, 2018 Share May 9, 2018 yes Runflat tire allows you to continue driving for 85km at MAX 80km/h (with Zero pressure) But the longer you drag your tire will likely further damages and made it beyond repair. To Save your Punctured Runflat try to fill the Air as soon as your can (best is over inflate may be 20% higher) allow the pressure sustain longer to prevent further damaged to your Punctured tires. And also Request Internal repair (patch or Patch & plug) BEST (only method recognized by Most tire manufacturers). TIres are the only 4 contacts between Road and You . if do internal patching for 18' pirelli RFT , u know roughly wat price?? kamsia Link to post Share on other sites More sharing options...
Cypher 4th Gear May 9, 2018 Share May 9, 2018 if do internal patching for 18' pirelli RFT , u know roughly wat price?? kamsia ST charges $40 for internal patching for 18" and above. 2 Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 9, 2018 Share May 9, 2018 if do internal patching for 18' pirelli RFT , u know roughly wat price?? kamsia NOT SURE whats the charges . I am pretty sure most don't practice internal patching. I am not sure who does that , you got to ask around from Friend , otherwise drop by any shop BUT ask before you allow them to remove your punctured wheel. Trust me Best way is internal Link to post Share on other sites More sharing options...
smithellison May 9, 2018 Share May 9, 2018 Eng Wah Tyre & Battries . 1 1 Link to post Share on other sites More sharing options...
Doppel Turbocharged May 13, 2018 Share May 13, 2018 NOT SURE whats the charges . I am pretty sure most don't practice internal patching. I am not sure who does that , you got to ask around from Friend , otherwise drop by any shop BUT ask before you allow them to remove your punctured wheel. Trust me Best way is internal Bro @Roberttan, Always appreciate your advice on tires at MCF. Do you think it is still safe to use tires manufactured in 2015 that have travelled 10,000 km only? Thread looks new but I can’t tell if the compound has deteriorated or hardened. Would be happy to go to my usual tire shop for a check, but afraid will be the usual “you never ask your barber if you should have a haircut”. Thanks. 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 15, 2018 Share May 15, 2018 Bro @Roberttan, Always appreciate your advice on tires at MCF. Do you think it is still safe to use tires manufactured in 2015 that have travelled 10,000 km only? Thread looks new but I can’t tell if the compound has deteriorated or hardened. Would be happy to go to my usual tire shop for a check, but afraid will be the usual “you never ask your barber if you should have a haircut”. Thanks. thanks for your compliment. Base on the Number 2015 you are safe to use them till 2020 Officially from MNC tire Manufacturers. T&C applied . It has to be Good Quality tires It has to maintain periodically like (rotation , pressured) Professionally Repaired (internal repaired only) ( FYI once tire is repaired your tire warranty stop). Must be correct or recommended tire size and TYPE. just MHO 1 Link to post Share on other sites More sharing options...
MarkHotchner Clutched May 16, 2018 Share May 16, 2018 If you want to save money, order online. The reputed tire shop I have ordered from is Supertiresonline. 2 Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged May 21, 2018 Share May 21, 2018 If you want to save money, order online. The reputed tire shop I have ordered from is Supertiresonline.Do they ship the tyres to Singapore from Florida? ↡ Advertisement Link to post Share on other sites More sharing options...
Honda Vezel - Part 3
2022 Toyota GR Corolla
