Recommendation for Frying pan
Jusnel
Hypersonic
15 minutes ago, Tohto said:
My Tefal one used since last September.
i think your interior base a bit discolored liao leh. I show mine later.
Edited by Lala81
Hypersonic
Yes, slight dis-color liao... May not last long.
Internal Moderator
You use metal spatula to fry thing arh? For teflon, try use wooden/silicone spatula to reduce scraping the coating away.
Hypersonic
i think the coating overheated without oil inside the wok to conduct away.
It happens to me sometimes when i try to gan1 bian1 hae bee hiam to get the flavour out. Or if I overfry some things until dry like mushrooms.
I try to stop doing it.
Hypersonic
coating u wash, will go away already. That usually come off easily. In my experience is usually when u are sauteing mushrooms until dry to develop flavour.
His one is the coating damaged by excess heat.
Edited by Lala81
Hypersonic
Always used wooden.
Hypersonic
I think due to too hot.
My way of cooking sometimes using high heat to get the wok hey.
Hypersonic
haha U are better getting a carbon steel wok then! If your maid cooks often for your family, maintenance is easy bah. Not like me. When CB ends properly, going to grandparents to makan + the kids start back all their swimming ECAs, at most cook twice a week only.
  • Praise 2
Hypersonic
You are right, I cooking steak on it without put any oil quite often.
Learn from James, high heat without any oil at first to trap the juice inside, that may the reason.
Any recommendation of pan for cooking steak or similar dishes?
Edited by Tohto
Hypersonic
Steak must be cast iron skillet. Flat and super high heat. Most versatile.
Can do reverse sear in your oven also. Heat at low temp in your oven uncovered to like sous vide principle then high heat sear finish in your cast iron skillet.
  • Praise 2
Supersonic
Wah you cook boh ? The word to use is "pristine condition" in sgcarmart .😆
  • Haha! 1
Hypersonic
Wah piang. U call that pristine? Then this one is "lady doctor driver. Ad serviced. Less than 5k mileage per year. See to believe!"
Edited by Lala81
  • Haha! 8
Hypersonic
If u don't want to put inside oven to do like baked shashuka eggs or some dry roasting. Then can get a bigger size skillet. Cos need to account for handle. My oven depth is 38cm.
Hypersonic
No, this is 'high mileage' pan. Cook almost everyday even during non-CB.
Can see already slight burnt.
Edited by Tohto
Hypersonic
Wah, shiny shiny,  original factory protection coating still intact. :a-m1212:
  • Haha! 1
On 1/31/2016 at 8:28 PM, serenade said:
Korean made heavy Happy Call pan. Can close cover where magnet holds it shut. Closed lid cooking keeps oil from splattering.
I use it for fry egg, grill steak, pan fry salmon and steam veggies. Ever since got it, my wok is little used. Because wok have to clean stove and floor after cooking.
Good call
  • Haha! 1
