Dleodleo Twincharged January 27, 2016 Share January 27, 2016 So is d brake faulty. Something new. Accelerator jam also problem, brake not working also problem. Once investigation completed, we should know d problem. If quick enough, should have used d parking brake. Tats is what my driving instructor do once upon a time. I read from the chinese nite newspaper one. He also said police ruled out foul play. ↡ Advertisement Link to post Share on other sites More sharing options...
Mockngbrd Supersonic January 27, 2016 Share January 27, 2016 u all go try press brake an throttle at the same time, see which one prevails. Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 27, 2016 Share January 27, 2016 sticky throttle + brake pedal depressed. i guess modern engine management will cut off fuel supply when it sense brake pedal depressed. Link to post Share on other sites More sharing options...
Sp4wn Turbocharged January 27, 2016 Share January 27, 2016 The brake light was on and the car still accelerate? step on both pedals? Also for the lexus crash, is it possible for the engine to be switched off? or hit brake and shift lower gear? what can be done? wait ... do MB come with launch control? i know LC is not an easy procedure to initiate ... but i know most of the time, it always involves stepping on the brakes. (same with my car, need to be in race mode, step brake ya da ya da).. im not even sure her car would have such a feature though .. Link to post Share on other sites More sharing options...
Angcheek Hypersonic January 27, 2016 Share January 27, 2016 wait ... do MB come with launch control? i know LC is not an easy procedure to initiate ... but i know most of the time, it always involves stepping on the brakes. (same with my car, need to be in race mode, step brake ya da ya da).. im not even sure her car would have such a feature though ..Waaa mine no sport mode .... only eco . 古早车 。。。 Does the electronic handbrake any use under such circumstances ? 1 Link to post Share on other sites More sharing options...
Myxilplix Turbocharged January 27, 2016 Share January 27, 2016 Yah lets go install bollards everywhere so that nobody will fall into the river, fall down the hill, fall down the stairs. I think easier to install bollards outside everyone's house, that way they won't go out into the big bad world and die. Also install bollards around their beds so they won't fall out of bed and die. Goddamn. 10 Link to post Share on other sites More sharing options...
Mockngbrd Supersonic January 27, 2016 Share January 27, 2016 (edited) sticky throttle + brake pedal depressed. i guess modern engine management will cut off fuel supply when it sense brake pedal depressed. try again (+ majority of drivers don't know how to apply max brake pressure also) Edited January 27, 2016 by Mockngbrd Link to post Share on other sites More sharing options...
Porker Turbocharged January 27, 2016 Share January 27, 2016 Yah lets go install bollards everywhere so that nobody will fall into the river, fall down the hill, fall down the stairs. I think easier to install bollards outside everyone's house, that way they won't go out into the big bad world and die. Also install bollards around their beds so they won't fall out of bed and die. Goddamn. Exactly the same thoughts as me when it comes to being kiasu kiasi everything want protection. Best is don't exist then for sure no danger 2 Link to post Share on other sites More sharing options...
Shibadog Turbocharged January 27, 2016 Share January 27, 2016 Yah lets go install bollards everywhere so that nobody will fall into the river, fall down the hill, fall down the stairs. I think easier to install bollards outside everyone's house, that way they won't go out into the big bad world and die. Also install bollards around their beds so they won't fall out of bed and die. Goddamn. bollards have gaps inbetween. U don't care abt motorbikes? retaining walls all round, pls. 6 Link to post Share on other sites More sharing options...
Adrianli Hypersonic January 27, 2016 Share January 27, 2016 sticky throttle + brake pedal depressed. i guess modern engine management will cut off fuel supply when it sense brake pedal depressed. No. It wont. Thatz how you should launch your car in a street race for auto cars. Left leg step on brake, right leg on accelerator till rpm at 5,000rpm. On green, let go left leg(brake pedal) and you will launch the car with minimum wheel spin. Another way is select netural on GB, right leg on accelerator till rpm at 5,000rpm. On green, push gear lever to D and it will launch the car. This method, GB will wear very fast. Both methods, tried and tested on my 2004 1.6A FL Nissan Sunny. Engine no cut off. 2 Link to post Share on other sites More sharing options...
Sp4wn Turbocharged January 27, 2016 Share January 27, 2016 No. It wont. Thatz how you should launch your car in a street race for auto cars. Left leg step on brake, right leg on accelerator till rpm at 5,000rpm. On green, let go left leg(brake pedal) and you will launch the car with minimum wheel spin. Another way is select netural on GB, right leg on accelerator till rpm at 5,000rpm. On green, push gear lever to D and it will launch the car. This method, GB will wear very fast. Both methods, tried and tested on my 2004 1.6A FL Nissan Sunny. Engine no cut off. 5000rpm? wa ... mine only 3500rpm max for LC. u sure urs can hit 5000? Link to post Share on other sites More sharing options...
Adrianli Hypersonic January 27, 2016 Share January 27, 2016 (edited) 5000rpm? wa ... mine only 3500rpm max for LC. u sure urs can hit 5000? Yes. I hold it at 5,000rpm. Redline was 6000 to 7000rpm. It was also how I manually calculated my sunny's 0-100km/h timing. Spec say 12sec. But I only get 14sec. Ya, its a slow car, but do it for shiokness. Poor man's trill on b&b car. My Sunny on NSH (look at rev meter only) : Edited January 27, 2016 by Adrianli Link to post Share on other sites More sharing options...
Sp4wn Turbocharged January 27, 2016 Share January 27, 2016 Yes. I hold it at 5,000rpm. Redline was 6000 to 7000rpm. wa, i learnt something new today sia. maybe that time nissan dont have so many GB problem ..lol! Link to post Share on other sites More sharing options...
Mockngbrd Supersonic January 27, 2016 Share January 27, 2016 wa, i learnt something new today sia. maybe that time nissan dont have so many GB problem ..lol! not GTR la, not computer LC, is human LC. 1 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged January 27, 2016 Share January 27, 2016 Yah lets go install bollards everywhere so that nobody will fall into the river, fall down the hill, fall down the stairs. I think easier to install bollards outside everyone's house, that way they won't go out into the big bad world and die. Also install bollards around their beds so they won't fall out of bed and die. Goddamn. AND not forgetting 1 storey HDB flats so no one jump off buliding 3 Link to post Share on other sites More sharing options...
Nzy Twincharged January 27, 2016 Share January 27, 2016 (edited) The brake light was on and the car still accelerate? step on both pedals? Also for the lexus crash, is it possible for the engine to be switched off? or hit brake and shift lower gear? what can be done? Possible that it is the floor mat that got stuck. If the floor mat slides up and covers the accelerator partially, when the person steps on the brakes, the floor mat presses down on the accelerator even harder. The harder the person steps on the brakes, the further the accelerator is depressed. This is more likely to happen if the accelerator is those that are mounted on the floor. Many Singaporeans love to add extra floor mats in their cars on top of the one that came with the car. Edited January 27, 2016 by Nzy Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic January 27, 2016 Share January 27, 2016 No. It wont. Thatz how you should launch your car in a street race for auto cars. Left leg step on brake, right leg on accelerator till rpm at 5,000rpm. On green, let go left leg(brake pedal) and you will launch the car with minimum wheel spin. Another way is select netural on GB, right leg on accelerator till rpm at 5,000rpm. On green, push gear lever to D and it will launch the car. This method, GB will wear very fast. Both methods, tried and tested on my 2004 1.6A FL Nissan Sunny. Engine no cut off. This one kills the car haha. Gearbox will kaput easily. But some sports car nowadays have launch control which is safe for the car. Some bmw models do have this as well Link to post Share on other sites More sharing options...
Nzy Twincharged January 27, 2016 Share January 27, 2016 This one kills the car haha. Gearbox will kaput easily. But some sports car nowadays have launch control which is safe for the car. Some bmw models do have this as well Manual car easier. Just rev and release the clutch and handbrake together. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
1 child dead, 18 injured after fire breaks out at River Valley Road shophouse
Pope Francis RIP
Pope Francis RIP
Mercedes Owners Thread
[Spyshots] 2026 2nd Generation Mercedes Benz GLB
Mercedes Extended Warranty
