DACH Supersonic January 2, 2018 Share January 2, 2018 Saw in a ZaoBao article that the Qashqai 1.2T only incurred a change from 5k rebate to Neutral under the new VES scheme. I reckon the Pulsar would have been similarly categorised given both are using the same engine. Maybe - $5k ↡ Advertisement Link to post Share on other sites More sharing options...
ecneret_eel 1st Gear January 3, 2018 Share January 3, 2018 (edited) went to the ubi one. your knocking, i got that also, you can ask them to fix it at your next servicing.did they mention what was causing it? edit: saw your reply to others liao, thanks! btw would you recommend I change to sharkfin too? Edited January 3, 2018 by ecneret_eel Link to post Share on other sites More sharing options...
able712 1st Gear January 4, 2018 Share January 4, 2018 Recently I found that my car difficult to shift out of park after parking for some time. Also if I shift to reverse out from park, the car will have a strong jerk. My car is only 2 months old... Is it gearbox problem? Anyone have the same experience that could provide me some advice? TIA... Link to post Share on other sites More sharing options...
Pulsar97 1st Gear January 4, 2018 Share January 4, 2018 Recently I found that my car difficult to shift out of park after parking for some time. Also if I shift to reverse out from park, the car will have a strong jerk. My car is only 2 months old... Is it gearbox problem? Anyone have the same experience that could provide me some advice? TIA...I read someone mentioned before, before set to Park, put in Neutral, pull handbrake, then set to Park. It works for me. If other drivers got another way, please share. :) Link to post Share on other sites More sharing options...
able712 1st Gear January 5, 2018 Share January 5, 2018 Thanks. I've tried the other way by pulling the handbrake before shifting to park. Some times it helps but not always. Also most of the time the car will move forward slightly after I released the foot brake. I'll tried the method you mentioned...thx... 2 Link to post Share on other sites More sharing options...
Lawduck Clutched January 7, 2018 Share January 7, 2018 Hi All, wan to check do u’ll change fuel at times like pump Esso 5000, shell 95 & etc or u’ll will stick to one fuel company? 2 Link to post Share on other sites More sharing options...
neski 1st Gear January 8, 2018 Share January 8, 2018 (edited) Hi All, wan to check do u’ll change fuel at times like pump Esso 5000, shell 95 & etc or u’ll will stick to one fuel company? I will simply stick to the the station behind my house which is Shell for convenient sake. Edited January 8, 2018 by neski 2 Link to post Share on other sites More sharing options...
Lawduck Clutched January 8, 2018 Share January 8, 2018 I will simply stick to the the station behind my house which is Shell for convenient sake.So u pump 95 or 98? 1 Link to post Share on other sites More sharing options...
Friendstar Supercharged January 8, 2018 Share January 8, 2018 It doesn't matter. Drink evian and ice mountain together won't hurt u 1 Link to post Share on other sites More sharing options...
neski 1st Gear January 9, 2018 Share January 9, 2018 So u pump 95 or 98?95 lor why bother with 98. Sometimes if I go jb then 97. Link to post Share on other sites More sharing options...
YiYuLim 1st Gear January 9, 2018 Share January 9, 2018 Pump 95 as per instructed by owner’s manual. 1 Link to post Share on other sites More sharing options...
Warlock8187 1st Gear January 11, 2018 Share January 11, 2018 Pump 95 as per instructed by ownerâs manual.Anyone here changed their stock head unit? If yes, do u encountered any steering wheel controls not able to use? 1 Link to post Share on other sites More sharing options...
ecneret_eel 1st Gear January 13, 2018 Share January 13, 2018 I read someone mentioned before, before set to Park, put in Neutral, pull handbrake, then set to Park. It works for me. If other drivers got another way, please share. :)me! i also commented that I experienced this.. my first automatic car after all, anyway when I rmbr to follow this sequence it's much better, but I still forget sometimes Anyone here changed their stock head unit? If yes, do u encountered any steering wheel controls not able to use?any sharing on this enquiry? also thinking of changing my head unit.. sian liao the GPS sucks big time.. I prefer to use Google maps.. Link to post Share on other sites More sharing options...
ecneret_eel 1st Gear January 14, 2018 Share January 14, 2018 how to find out what's the maximum rim size our car can fit ah? anyone knows? Link to post Share on other sites More sharing options...
ecneret_eel 1st Gear January 17, 2018 Share January 17, 2018 anyone changed their exhaust muffler tip? Link to post Share on other sites More sharing options...
Kazeronin Clutched January 17, 2018 Share January 17, 2018 how to find out what's the maximum rim size our car can fit ah? anyone knows?Nissan pulsar Europe have an 18 inch rim option. 215/45ZR18 1 Link to post Share on other sites More sharing options...
ecneret_eel 1st Gear January 18, 2018 Share January 18, 2018 Nissan pulsar Europe have an 18 inch rim option. 215/45ZR18 thanks! i also googled and saw that, guess max is 18, anyway anything more doesn't make sense lol anyone here changed their rims? Link to post Share on other sites More sharing options...
Noneng73 1st Gear January 18, 2018 Share January 18, 2018 Will change rims when its time to change tyres... I make do with the stock rims first... ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Nissan QashQai 2014 Part 2
Nio Firefly - coming to Singapore in 2026
future of mitsubishi?
2018 Nissan Serena e-POWER
Nissan N7
Nissan N7
