Alphas 2nd Gear November 10, 2015 Share November 10, 2015 Anyone encountered while breaking just before the car stops, it gives a HMHmhmmmmmm sound. It get louder when raining and quite annoying, any idea to get rid of this noise? It is not a screeching sound cause by the brake pad, it is a Hmmmmm sound that only when the wheels just stops or starts moving. ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic November 10, 2015 Share November 10, 2015 Easy... 3 Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 10, 2015 Share November 10, 2015 braking..... sounds like worn bearing Link to post Share on other sites More sharing options...
Furrynadz 5th Gear November 10, 2015 Share November 10, 2015 when in doubt, jackup and check breaking <--- very worrying... Link to post Share on other sites More sharing options...
TVT Supercharged November 10, 2015 Share November 10, 2015 Is your car rear wheels using drum brakes? If so it could be your brake cylinder is faulty.... Link to post Share on other sites More sharing options...
Alphas 2nd Gear November 10, 2015 Author Share November 10, 2015 no leh, brake pad used half only, still got 7mm left. All 4 wheels on disc brakes. Link to post Share on other sites More sharing options...
Showster Twincharged November 11, 2015 Share November 11, 2015 Mine got similar problem. Even changed brake pad did not solve the problem although it appeared less frequently and less loudly. My car mechanic relative said it could be something about humidity and hand brake. Anyway checked at workshop many times. No issue, safe for my case. Link to post Share on other sites More sharing options...
Alphas 2nd Gear November 12, 2015 Author Share November 12, 2015 Did rotor skimming on 4 discs and braking is more smoother and even. Before they place back the brake pads, I coat the all the brake calipers with silicon grease, now the braking noise is gone. Link to post Share on other sites More sharing options...
flashbang Turbocharged November 12, 2015 Share November 12, 2015 Did rotor skimming on 4 discs and braking is more smoother and even. Before they place back the brake pads, I coat the all the brake calipers with silicon grease, now the braking noise is gone. I always thought this noise is normal. In the morning it will have a bit of the noise, but after some driving it goes away, probably as the rotor and brake pads heat up. ↡ Advertisement Link to post Share on other sites More sharing options...
Change Disc Rotors
Change Disc Rotors
Intermittent rattling noise, car in ICU
Sound Proofing the car
Whole car sound proof
