Kklee 6th Gear Wednesday at 03:10 AM Share Wednesday at 03:10 AM On 9/25/2024 at 10:48 AM, ER-3682 said: @Kklee i think 98 more additives...more smell. IMHO. Perhaps. My concern is more of whether it can combust fully given that the timing can only advance that much. 🤔 ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Hypersonic Wednesday at 03:11 AM Share Wednesday at 03:11 AM On 9/25/2024 at 10:52 AM, ER-3682 said: Same as why V-Power why sometime they selling at Fuelsaver 98 Price...just wonder why Shell have 2 types of 98 Petrol.? Shell marketing? Just like car manufacturers must have a Halo Product. I think Shell has V-power in every market it operates. But not all has the same octane. Malaysia V-power is RON97 Link to post Share on other sites More sharing options...
ER-3682 Twincharged Wednesday at 03:17 AM Share Wednesday at 03:17 AM On 9/25/2024 at 11:10 AM, Kklee said: IMHO. Perhaps. My concern is more of whether it can combust fully given that the timing can only advance that much. 🤔 If Fuel-Air Ratio is correct..sure can fully combust. Link to post Share on other sites More sharing options...
mersaylee Hypersonic Wednesday at 04:21 AM Share Wednesday at 04:21 AM Just drop to lower gear and drag at high rpm for a while lah...clear carbon with whatever ron...hope no need to go workshop for engine or gearbox overhaul...😂 Link to post Share on other sites More sharing options...
inlinesix Hypersonic Wednesday at 04:38 AM Share Wednesday at 04:38 AM On 9/25/2024 at 12:21 PM, mersaylee said: Just drop to lower gear and drag at high rpm for a while lah...clear carbon with whatever ron...hope no need to go workshop for engine or gearbox overhaul...😂 Within 5 sec, you already exceed speed limit 😂 Link to post Share on other sites More sharing options...
mersaylee Hypersonic Wednesday at 04:53 AM Share Wednesday at 04:53 AM On 9/25/2024 at 12:38 PM, inlinesix said: Within 5 sec, you already exceed speed limit 😂 Gear satu dua wont lah...hit hardware limit niah...😅 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear Wednesday at 05:12 AM Share Wednesday at 05:12 AM On 9/25/2024 at 11:17 AM, ER-3682 said: If Fuel-Air Ratio is correct..sure can fully combust. IMHO. Thus if AFR is a variable and to achieve full combustion, then it should be possible to have improve FC ( depending on design ) when the ECU either reduce the fuel or advances the ignition timing. Just like the specific energy for different octane fuel can be very similar, higher compression and more advanced in ignition timing can lead to more power. Again, better FC? 🤔 Link to post Share on other sites More sharing options...
ER-3682 Twincharged Wednesday at 05:14 AM Share Wednesday at 05:14 AM On 9/25/2024 at 1:12 PM, Kklee said: IMHO. Thus if AFR is a variable and to achieve full combustion, then it should be possible to have improve FC ( depending on design ) when the ECU either reduce the fuel or advances the ignition timing. Just like the specific energy for different octane fuel can be very similar, higher compression and more advanced in ignition timing can lead to more power. Again, better FC? 🤔 FC control by Right Leg. 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged Wednesday at 05:30 AM Share Wednesday at 05:30 AM On 9/25/2024 at 8:15 AM, Mkl22 said: this one hard to say. each brand kaki kong kaki song. Unless you borescope the cylinder walls regularly, no way to tell. this is my thought too 👍 1 Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged Thursday at 05:21 AM Share Thursday at 05:21 AM On 9/25/2024 at 9:15 AM, Volvobrick said: Higher Octane allows higher compression ratio without knocking. Whether rpm is 1000 or 10000 the compression ratio remains the same. Anyway who drives around at 6000 rpm all the time except chow bengs? First time i heard RON100 allows the engine to hold high rpm for longer 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic Thursday at 05:49 AM Share Thursday at 05:49 AM (edited) On 9/26/2024 at 1:21 PM, Beehive3783 said: First time i heard RON100 allows the engine to hold high rpm for longer Not surprising as most ppl here never use RON100 before. I used it Mini as well as MYVI. Edited Thursday at 05:50 AM by inlinesix ↡ Advertisement Link to post Share on other sites More sharing options...
McLaren entry level sports car, 570S and its related series
2016 Hyundai Elantra / Avante
