Blueray Hypersonic June 25, 2021 Share June 25, 2021 43 minutes ago, inlinesix said: Question: Should rotate or change the tyre? Tread Depth Front: 3.1mm Rear: 3.6mm YoM: 2017 Installation: 2018 if still not yet touch indicator, i'd rotate and use 12 months max. ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 25, 2021 Share June 25, 2021 3 minutes ago, Blueray said: if still not yet touch indicator, i'd rotate and use 12 months max. Touch indicator means go below 1.8mm le. Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 25, 2021 Share June 25, 2021 50 minutes ago, inlinesix said: Question: Should rotate or change the tyre? Tread Depth Front: 3.1mm Rear: 3.6mm YoM: 2017 Installation: 2018 Will use it till it hits the week of the DOM at 4years. Then change. don’t waste money to rotate. 1 Link to post Share on other sites More sharing options...
Shibadog Turbocharged June 25, 2021 Share June 25, 2021 Just now, inlinesix said: Touch indicator means go below 1.8mm le. i find tyres drive even better in the dry when they are near the indicator albeit more noisy. But scary in the wet. So it depends on how the user drives according to the weather. Sometimes i would change a half worn set just before the year end monsoon season esp if planning a trip up north. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 25, 2021 Share June 25, 2021 1 minute ago, Shibadog said: i find tyres drive even better in the dry when they are near the indicator albeit more noisy. But scary in the wet. So it depends on how the user drives according to the weather. Sometimes i would change a half worn set just before the year end monsoon season esp if planning a trip up north. I am an aggressive driver shine or rain. I will not let tread depth go so low. 1 Link to post Share on other sites More sharing options...
Shibadog Turbocharged June 25, 2021 Share June 25, 2021 2 minutes ago, inlinesix said: I am an aggressive driver shine or rain. I will not let tread depth go so low. depends on the tyres- it might be unavoidable for some models with low threadwear index. I had one set of tyres that only lasted 4k km before i had to change it out 😀 it had a TWI of 80 (not 180). Used it for drives in malaysia (not sepang - just road trip and B roads) during dry season while switching to another set of different rims/tyres for use in SG. After each drive, can see the tyre is clearly thinner than before. LOL 1 Link to post Share on other sites More sharing options...
Roberttan 5th Gear June 26, 2021 Share June 26, 2021 21 hours ago, inlinesix said: Question: Should rotate or change the tyre? Tread Depth Front: 3.1mm Rear: 3.6mm YoM: 2017 Installation: 2018 YES FOR the age should consider change, but you still can continue use since still have 3.1mm left, YOM 2017 plus 5 or 6 manufacturer warrant. notice Michelin Official warranty booklet to 9 years from DOM(T & C ) , Michelin is so confidents their poduct Quality 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 26, 2021 Share June 26, 2021 4 hours ago, Roberttan said: YES FOR the age should consider change, but you still can continue use since still have 3.1mm left, YOM 2017 plus 5 or 6 manufacturer warrant. notice Michelin Official warranty booklet to 9 years from DOM(T & C ) , Michelin is so confidents their poduct Quality My plan is to rotate the tyre 1 last time. Measures the tread depth after 2.5k km. If goes below 3.1mm, I will change to PS4s. 😄 Link to post Share on other sites More sharing options...
t0y0ta Supercharged June 26, 2021 Share June 26, 2021 On 6/25/2021 at 4:30 PM, inlinesix said: Question: Should rotate or change the tyre? Tread Depth Front: 3.1mm Rear: 3.6mm YoM: 2017 Installation: 2018 I was in almost identical situtaion (SUV tyres which have used for around 50k). I just changed full set. 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged July 27, 2021 Share July 27, 2021 Recently I saw in a tyre shop that there is a variant of Michelin Pilot Sport 4 calls "Michelin Pilot Sport 4 S" and the thread pattern is a bit different. Is it a superior or successor version to the PS4? Link to post Share on other sites More sharing options...
Beregond Supersonic July 27, 2021 Share July 27, 2021 2 minutes ago, DOBIEMKZ said: Recently I saw in a tyre shop that there is a variant of Michelin Pilot Sport 4 calls "Michelin Pilot Sport 4 S" and the thread pattern is a bit different. Is it a superior or successor version to the PS4? yes its totally different, another grade higher. PS3>>> PS4 PSS>>>PS4S 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged July 27, 2021 Share July 27, 2021 30 minutes ago, Beregond said: yes its totally different, another grade higher. PS3>>> PS4 PSS>>>PS4S How about this variant calls "Michelin Pilot Sport 4 ST"? So bewildering. Link to post Share on other sites More sharing options...
Beregond Supersonic July 27, 2021 Share July 27, 2021 9 minutes ago, DOBIEMKZ said: How about this variant calls "Michelin Pilot Sport 4 ST"? So bewildering. The ST stand for slient tuned i believe, mostly for asia market. 2 Link to post Share on other sites More sharing options...
ER-3682 Twincharged July 27, 2021 Share July 27, 2021 7 hours ago, Beregond said: The ST stand for slient tuned i believe, mostly for asia market. But not Silent at ALL. 1 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 27, 2021 Share July 27, 2021 Have the PS4 on current ride. Front tomyum, rear German, all same profile. Best tyres I ever have...very grippy in dry and wet. Can drive with confidence even in very wet condition. But noisy like hell in the dry...reminds me of the noisy rumbling GY Eagle F1 I once had...😅 2 Link to post Share on other sites More sharing options...
D3badge 6th Gear July 27, 2021 Share July 27, 2021 9 hours ago, DOBIEMKZ said: How about this variant calls "Michelin Pilot Sport 4 ST"? So bewildering. my PS4 come with form inside the centre diameter, was told this reduce noise from tyre 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged July 27, 2021 Share July 27, 2021 9 hours ago, mersaylee said: Have the PS4 on current ride. Front tomyum, rear German, all same profile. Best tyres I ever have...very grippy in dry and wet. Can drive with confidence even in very wet condition. But noisy like hell in the dry...reminds me of the noisy rumbling GY Eagle F1 I once had...😅 What is your tyre size? Are your tyres low-profile sidewall type? Like say 50 or below. And generally is it that the lower the sidewall profile the noiser the tyre will be? 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 27, 2021 Share July 27, 2021 2 minutes ago, DOBIEMKZ said: What is your tyre size? Are your tyres low-profile sidewall type? Like say 50 or below. And generally is it that the lower the sidewall profile the noiser the tyre will be? 😁 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
New Land Rover Discovery Sport
Indonesia's Batik Air faces probe after pilots fall asleep mid-flight
