Metalslug2 3rd Gear September 19, 2015 Share September 19, 2015 Guys, anyone used 3m adhesive tape for mounting your GPS or handphone car mount on the dashboard? my handphone car mount started to lose its stickiness so was thinking to just get a 3m tape and stick it back. Am scared of the residue on the dash... ↡ Advertisement Link to post Share on other sites More sharing options...
Shibadog Turbocharged September 19, 2015 Share September 19, 2015 Guys, anyone used 3m adhesive tape for mounting your GPS or handphone car mount on the dashboard? my handphone car mount started to lose its stickiness so was thinking to just get a 3m tape and stick it back. Am scared of the residue on the dash... what type of material is your dashboard made of? hard plastic or soft touch rubbery material? Link to post Share on other sites More sharing options...
Metalslug2 3rd Gear September 19, 2015 Author Share September 19, 2015 Civic FD.. Has both hard plastic and soft rubber Link to post Share on other sites More sharing options...
Shibadog Turbocharged September 19, 2015 Share September 19, 2015 Civic FD.. Has both hard plastic and soft rubber 3m has tapes with different strengths. U may hv to experiment. gotta be careful with the soft rubber material. u need a tape that is strong enough but doesn't tear out the underlying material. hard plastic should be easy. No need scared residue too, as it should be easy to clean. my defi meters hv been stuck to my dashboard (previous car hard material, current car soft rubber) for years. Wkshop had the "correct" tapes to use. Link to post Share on other sites More sharing options...
Metalslug2 3rd Gear September 19, 2015 Author Share September 19, 2015 thanks dude. yes i think i will stick on the hard plastic... am thinking of using 3m command tapes see can hold or not http://www.command.com.sg/wps/portal/3M/en_SG/APACCommand/Home/Products/Catalog/ Link to post Share on other sites More sharing options...
Jtb 6th Gear September 20, 2015 Share September 20, 2015 http://www.amazon.com/3M-Primer-94-Vinyl-Di-Noc/dp/B005LDG7HQ/ref=pd_sim_121_1?ie=UTF8&refRID=1VF89S91PTJEJG9D59A2&dpID=41UG0GmfhgL&dpSrc=sims&preST=_AC_UL160_SR118%2C160_ need this to apply first there after your 3M double tape above it. ↡ Advertisement Link to post Share on other sites More sharing options...
2014 Honda Odyssey
2014 Honda Odyssey
[Concept] Honda 0 Series EVs
Honda Vezel - Part 3
Any recommended tyre shop
Takata airbag recall
