Wildfaye29 Turbocharged September 30, 2019 Share September 30, 2019 (edited) On 9/26/2019 at 10:01 AM, Wormee said: It was long ago when I change it for my previous car. I think cost is $60-80. Probably under $100 with installations. Better to call them up to check prices. Depending on your car, the horn installation could need to down bumper. E-REV would charge labour to down bumper depending on your negotiation skills with the boss. ok i noted there is 2 horn - a 400hz and a 500hz, both are loud on its own and sounds ok to me. if i were to split them and use 1 each in 2 different cars, will it be possible? will i need a relay for each separate one? Edited September 30, 2019 by Wildfaye29 ↡ Advertisement Link to post Share on other sites More sharing options...
Wormee 5th Gear September 30, 2019 Share September 30, 2019 (edited) 11 hours ago, Wildfaye29 said: ok i noted there is 2 horn - a 400hz and a 500hz, both are loud on its own and sounds ok to me. if i were to split them and use 1 each in 2 different cars, will it be possible? will i need a relay for each separate one? I believed the reason why you want to upgrade your horn is to make it louder compared to your mickey mouse horn. If you split the 2 tone horns into 2 different cars, it will only have one single frequency. Furthermore, your stock horn cable will not be enough to power your 'single' 2-tone horn without a relay wiring it to your battery and fuse box. I do not know if it is technically possible but I don't think anyone would do that. Might as well stay stock or find another type of single horn that replaces the stock one which I doubt I can find one (previously). Cheers. Edited September 30, 2019 by Wormee Link to post Share on other sites More sharing options...
Sdf4786k Twincharged October 1, 2019 Share October 1, 2019 maybe u can try redirect the horn to face outside then inside the car. The mech was telling me the horn face inside to create an echo camber .... Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged October 2, 2019 Share October 2, 2019 On 10/1/2019 at 7:41 AM, Wormee said: I believed the reason why you want to upgrade your horn is to make it louder compared to your mickey mouse horn. If you split the 2 tone horns into 2 different cars, it will only have one single frequency. Furthermore, your stock horn cable will not be enough to power your 'single' 2-tone horn without a relay wiring it to your battery and fuse box. I do not know if it is technically possible but I don't think anyone would do that. Might as well stay stock or find another type of single horn that replaces the stock one which I doubt I can find one (previously). Cheers. On 10/1/2019 at 8:07 AM, Sdf4786k said: maybe u can try redirect the horn to face outside then inside the car. The mech was telling me the horn face inside to create an echo camber .... Got the Hello Red Twin Tone (400hz is deeper and 500hz is sharper). My installer used both on his bike and it sounds threatening to me. I only want awareness but not to shock anyone. I used the 500hz sharper one on my car and it is facing down in bumper chamber - loud enough for me and definitely stronger than my mickey mouse. Will be using the 400hz in my dad's car - his mickey mouse is even mickey-ier than mine! 2 Link to post Share on other sites More sharing options...
GTO-1 5th Gear October 9, 2019 Share October 9, 2019 On 10/2/2019 at 7:49 PM, Wildfaye29 said: Got the Hello Red Twin Tone (400hz is deeper and 500hz is sharper). My installer used both on his bike and it sounds threatening to me. I only want awareness but not to shock anyone. I used the 500hz sharper one on my car and it is facing down in bumper chamber - loud enough for me and definitely stronger than my mickey mouse. Will be using the 400hz in my dad's car - his mickey mouse is even mickey-ier than mine! Why aren't you using both on your car? It's intended to both be used at the same time to warn people. If I recall my physics, there are situations when sound frequencies get cancelled out and therefore harder to hear. Additionally people have different hearing frequencies based on their age, genetics etc. By having two clear different frequencies helps make sure your horn is noticed whoever you are. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator October 9, 2019 Share October 9, 2019 On 10/2/2019 at 7:49 PM, Wildfaye29 said: Got the Hello Red Twin Tone (400hz is deeper and 500hz is sharper). My installer used both on his bike and it sounds threatening to me. I only want awareness but not to shock anyone. I used the 500hz sharper one on my car and it is facing down in bumper chamber - loud enough for me and definitely stronger than my mickey mouse. Will be using the 400hz in my dad's car - his mickey mouse is even mickey-ier than mine! https://www.mycarforum.com/marketplace/info-134773/ $48 dollar only. okay leh. Link to post Share on other sites More sharing options...
GTO-1 5th Gear February 9, 2020 Share February 9, 2020 Just installed Hella Supertone on my car, replacing a pair of PIAA slim sports horns. The supertones are definitely more annoying and attention grabbing (which is great for a horn). I suspect the horn has "better" sound because it's forward facing, while snail type horns like the PIAA's fire the sound downwards or sideways. Got the supertone for $45 and learned that SG has some of the cheapest prices for Hella horns in Asia, since the distributor is in SG. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear February 9, 2020 Share February 9, 2020 (edited) actually for those who want to DIY wire your snail horns. can buy this wiring harness. Plug and play. bought a set of this from taobao few years back. But of cos dont buy anything now from taobao. Later free virus comes with parcel also. Edited February 9, 2020 by StreamRSZ Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator February 10, 2020 Share February 10, 2020 1 hour ago, StreamRSZ said: actually for those who want to DIY wire your snail horns. can buy this wiring harness. Plug and play. bought a set of this from taobao few years back. But of cos dont buy anything now from taobao. Later free virus comes with parcel also. how does this works? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear February 10, 2020 Share February 10, 2020 10 hours ago, kobayashiGT said: how does this works? just plug and play. and the positive and negative goes to car batt. the rest is go to the horn points. Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 10, 2020 Share February 10, 2020 Some lady kept reversing and this horn saved me. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 13, 2024 Share July 13, 2024 Anyone horny and change horns recently? How much now? Anyone using PIAA OTO horns? Link to post Share on other sites More sharing options...
Jamesc Hypersonic July 14, 2024 Share July 14, 2024 On 7/13/2024 at 10:06 PM, Fcw75 said: Anyone horny and change horns recently? How much now? Anyone using PIAA OTO horns? Nice tones damn loud. Buy online take to accessories shop pay $30-50 to install. Cheaper to install in JB 5 minute job. On 2/10/2020 at 7:48 PM, Jamesc said: Some lady kept reversing and this horn saved me. 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 14, 2024 Share July 14, 2024 (edited) On 7/14/2024 at 8:17 AM, Jamesc said: Nice tones damn loud. Buy online take to accessories shop pay $30-50 to install. Cheaper to install in JB 5 minute job. One shop selling $90 with installation. Is it reasonable? But it doesn’t seem to come with relay, unlike Hella. Edited July 14, 2024 by Fcw75 1 Link to post Share on other sites More sharing options...
iamahbee 5th Gear July 14, 2024 Share July 14, 2024 On 7/13/2024 at 10:06 PM, Fcw75 said: Anyone horny and change horns recently? How much now? Anyone using PIAA OTO horns? Just changed to a set of Bosch Evolution. $60 including installation. 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 14, 2024 Share July 14, 2024 On 2/10/2020 at 7:48 PM, Jamesc said: Some lady kept reversing and this horn saved me. They were advancing at you...yet you got honky instead of horny 😁 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 14, 2024 Share July 14, 2024 On 7/13/2024 at 10:06 PM, Fcw75 said: Anyone horny and change horns recently? How much now? Anyone using PIAA OTO horns? Your neighbour irritate you issit? 😁 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic July 14, 2024 Share July 14, 2024 (edited) On 7/14/2024 at 9:45 AM, iamahbee said: Just changed to a set of Bosch Evolution. $60 including installation. How’s the sound? Can charge lobang? Did they install with relay? Sometimes also depend on car. Edited July 14, 2024 by Fcw75 ↡ Advertisement Link to post Share on other sites More sharing options...
The Best Cooling Measures: Ice Cream! 😂
Tesla hits record high in first trading session of 2021
Test forum upg
Test forum upg
Discussions on Blumont
