Kippei 3rd Gear July 27, 2015 Share July 27, 2015 Hyundai Avante.Went to Kenny and was told my left camber -1.4 my right camber -2.1.Any solution beside changing the entire upper arm. ↡ Advertisement Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 27, 2015 Share July 27, 2015 Hyundai Avante. Went to Kenny and was told my left camber -1.4 my right camber -2.1. Any solution beside changing the entire upper arm. Is it within the specs? Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 27, 2015 Share July 27, 2015 Is it within the specs? 2 deg is too much. Normally rear is 0 deg or -1 deg. 2 Link to post Share on other sites More sharing options...
Kippei 3rd Gear July 27, 2015 Author Share July 27, 2015 I think i just leave it. Just now i went to the mscp to eyeball most of the parked car. Always the rear right is always more slanted than the left. Likely due to MSCP turning right most of the time. What i know is need camber kit to adjust which cost $350. But than the tyre wear for wrong toe is much worst camber. So I just leave with it and see how it goes. $350 can get another set of tyres Link to post Share on other sites More sharing options...
Splynx Clutched August 13, 2015 Share August 13, 2015 My usual mechanic also told me that my left right chamber is slanted and need to install some chamber kit to align back, i go get 2nd opinion from another workshop and he told me that it's not necessary for my kind of car (Toyota) and advise me to just leave it as it is. Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 13, 2015 Share August 13, 2015 My usual mechanic also told me that my left right chamber is slanted and need to install some chamber kit to align back, i go get 2nd opinion from another workshop and he told me that it's not necessary for my kind of car (Toyota) and advise me to just leave it as it is. I don't like camber kit , unless you are going for specific purpose like racing circuit 99.9% of the on the road cars don't need this chamber slanted may be something else please consult your reliable WS ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Is it illegal to fetch passengers at the back of a Suzuki Every?
Planetary alignment
Planetary alignment
Brake squeak every morning
Coaxial or Component for Rear speakers
Different front and rear tires
Front/rear strut bar & lower tie
