Mustank Hypersonic August 14, 2018 Share August 14, 2018 Male friend or female friend hah? ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Vid Hypersonic August 14, 2018 Share August 14, 2018 I got a question: can I connect an access point to another access point? M = modem R = router AP1 = access point 1 AP2 = access point 2 S = network switch ———— = lan cable Can I do this? M——-R——-AP1——-AP2 Or do I need a network switch between the two AP and the router? M——-R——-S————AP1 .......................|————-AP2 The ..... doesn’t mean anything. I just have to put it there to show that AP2 is connected to S Simple ans - Can connect AP to AP. Which GCB is this? [laugh] 2 Link to post Share on other sites More sharing options...
Ender Hypersonic August 14, 2018 Share August 14, 2018 (edited) I got a question: can I connect an access point to another access point? M = modem R = router AP1 = access point 1 AP2 = access point 2 S = network switch ———— = lan cable Can I do this? M——-R——-AP1——-AP2 Or do I need a network switch between the two AP and the router? M——-R——-S————AP1 .......................|————-AP2 The ..... doesn’t mean anything. I just have to put it there to show that AP2 is connected to S Does your AP1 and AP2 has 4 ethernet ports? if both have then both setup you propose should work, as long as the router is the only Dhcp server. Currently mine is PC1 -----| |--S1(a router disabled dhcp)-------Router |-------|S2 ---HTPC/TV/Media player PC2 -----| |-------|S3 --- Nas1 and Nas2 So it seems, the switch can anyhow put as long as your have enough ports and only one Dhcp server which is the router. AP with mulitple ports are also switches. Edited August 14, 2018 by Ender 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic August 14, 2018 Share August 14, 2018 (edited) I got a question: can I connect an access point to another access point? M = modem R = router AP1 = access point 1 AP2 = access point 2 S = network switch ———— = lan cable Can I do this? M——-R——-AP1——-AP2 Or do I need a network switch between the two AP and the router? M——-R——-S————AP1 .......................|————-AP2 The ..... doesn’t mean anything. I just have to put it there to show that AP2 is connected to S Go like this M——-R——-S————AP1 .......................|————-AP2 R and AP1, AP2 must be on the same network. That means all the connected ports must be something like this: If the network is 192.168.0.0 with subnet mask 255.255.255.0 Then R can be 192.168.0.1 AP1 can be 192.168.0.2 AP2 can be 192.168.0.3 Edited August 14, 2018 by Kb27 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic August 14, 2018 Share August 14, 2018 (edited) I got a question: can I connect an access point to another access point? M = modem R = router AP1 = access point 1 AP2 = access point 2 S = network switch ———— = lan cable Can I do this? M——-R——-AP1——-AP2 Or do I need a network switch between the two AP and the router? M——-R——-S————AP1 .......................|————-AP2 The ..... doesn’t mean anything. I just have to put it there to show that AP2 is connected to S Can. You just configure the AP2 as "Bridge mode". Go to settings look for bridge mode. M——-AP1—connected via wifi—-AP2 SSID and password set as the same as AP1. The two AP will be connected wirelessly. Quite easy. Edited August 14, 2018 by Watwheels 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic August 14, 2018 Share August 14, 2018 I may be a little rusty here, but your connection depends on how you want to design your network. Switch - connects multiple devices (or hosts) together in the same network Router - connects different networks together, and sending packets from one network to the other and vice versa. In most home routers, it just connects the home network typically private IP like 192.168.x.x to the internet (publicly routed) IP assigned to the modem. Link to post Share on other sites More sharing options...
Watwheels Supersonic August 14, 2018 Share August 14, 2018 (edited) Aiya, just buy the Mesh Wifi System. So common now. Asus wan is only $399? Edited August 14, 2018 by Watwheels 2 Link to post Share on other sites More sharing options...
Mustank Hypersonic August 14, 2018 Share August 14, 2018 Thank you so much everyone!!!! Confirm both AP router is 4 lan port. I will connect them together It is gcp in a gcb Link to post Share on other sites More sharing options...
Enye Hypersonic August 14, 2018 Share August 14, 2018 Thank you so much everyone!!!! Confirm both AP router is 4 lan port. I will connect them together It is gcp in a gcb wah and you are the visiting network service guy? sounds like a great plot for a certain type of movie Link to post Share on other sites More sharing options...
Mustank Hypersonic August 14, 2018 Share August 14, 2018 wah and you are the visiting network service guy? sounds like a great plot for a certain type of movie ðð Hehe Aiya, just buy the Mesh Wifi System. So common now. Asus wan is only $399? Cannot suggest thisWait gcp don’t call me Link to post Share on other sites More sharing options...
mersaylee Hypersonic August 14, 2018 Share August 14, 2018 Male friend or female friend hah?Must be darn chio until he wants to route his “extender” into the fren gcb so that he can make her his WIFe... wait a second...isn’t Mustank oredi married? ...and what’s gcb huh, bro Vid? Link to post Share on other sites More sharing options...
Vid Hypersonic August 14, 2018 Share August 14, 2018 (edited) Must be darn chio until he wants to route his “extender” into the fren gcb so that he can make her his WIFe... wait a second...isn’t Mustank oredi married? ...and what’s gcb huh, bro Vid? Edited August 14, 2018 by Vid 4 Link to post Share on other sites More sharing options...
Mustank Hypersonic August 14, 2018 Share August 14, 2018 Link to post Share on other sites More sharing options...
mersaylee Hypersonic August 14, 2018 Share August 14, 2018 Ahh...good cheese pie. Or is it gorgeous classy babe? 1 Link to post Share on other sites More sharing options...
Tianmo Hypersonic August 14, 2018 Share August 14, 2018 next time I got such problem I will find @mustank.. 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic August 14, 2018 Share August 14, 2018 If I buy GCB, I will look for @mustank. Link to post Share on other sites More sharing options...
Mustank Hypersonic August 14, 2018 Share August 14, 2018 If I buy GCB, I will look for @mustank.Hehe 1 Link to post Share on other sites More sharing options...
Ash2017 Twincharged September 17, 2018 Share September 17, 2018 Hehe Mustank all the bros here acknowledge you are THE Guru here may i seek your advice Starhub is giving away free linksys EA8100 router but I am thinking of getting EA9500S currently using Linksys EA7500 but lousy in penetrating walls (especially toilet - bombing cannot play MCF) your advice - you think worth getting the EA9500S for greater penetration thinking of investing in inksys Velop (Triband) but not sure how many we need because there seem no way to calculate or assess until you set up the router first currently, I am using two router piggybacking on the other to extend the reach but not satisfactory your advice - can avoid buying MESH with EA9500S Thank you guru Mustank ↡ Advertisement 4 Link to post Share on other sites More sharing options...
Simple home DIY repairs
Home Aircon
Home Aircon
Even after $60k in vet bills and going into debt, S’pore couple couldn’t save their dog
Dream home
Dream home
