Ender Hypersonic July 14, 2015 Share July 14, 2015 On 7/14/2015 at 7:33 AM, Mustank said: the most run lan cable outside the house window Got to engage spiderman to lay the outside cable. Can try carpet the house, and lay the cable underneath it. On 7/14/2015 at 7:36 AM, Watwheels said: Ask you guys, where to get phone-Ethernet adapter like this... I know Amazon is selling but locally does anyone sell? Like Element14? Does this work? the number of small cables is different for the phone and ethernet. ↡ Advertisement Link to post Share on other sites More sharing options...
Mustank Hypersonic July 14, 2015 Share July 14, 2015 On 7/14/2015 at 7:36 AM, Watwheels said: Ask you guys, where to get phone-Ethernet adapter like this... I know Amazon is selling but locally does anyone sell? Like Element14? bro telephone keystone looks like this only connect 4 out of 8 of the LAN cable so even if you use the adaptor also no use one you need to change the telephone keystone to LAN keystone On 7/14/2015 at 7:39 AM, Ender said: Got to engage spiderman to lay the outside cable. Can try carpet the house, and lay the cable underneath it. Does this work? the number of small cables is different for the phone and ethernet. can one use tek koh to do, 2 man job Link to post Share on other sites More sharing options...
Ender Hypersonic July 14, 2015 Share July 14, 2015 On 7/14/2015 at 7:41 AM, Mustank said: can one use tek koh to do, 2 man job Serious, you actually gave me an idea. Currently I'm using flat type of lan cable running along the edge of the wall. Certain expose area quite unsightly.. got to make sure i don't dropped the tek koh onto someone head below. Link to post Share on other sites More sharing options...
Watwheels Supersonic July 14, 2015 Share July 14, 2015 (edited) On 7/14/2015 at 7:41 AM, Mustank said: bro telephone keystone looks like this only connect 4 out of 8 of the LAN cable so even if you use the adaptor also no use one you need to change the telephone keystone to LAN keystone can one use tek koh to do, 2 man job I see.... Can share where do you get the LAN keystone from? I mean other dan online. Edited July 14, 2015 by Watwheels Link to post Share on other sites More sharing options...
Mustank Hypersonic July 14, 2015 Share July 14, 2015 On 7/14/2015 at 7:43 AM, Ender said: Serious, you actually gave me an idea. Currently I'm using flat type of lan cable running along the edge of the wall. Certain expose area quite unsightly.. got to make sure i don't dropped the tek koh onto someone head below. actually I did that but it was not for lan cable it was for high pressure water hose (I place my high pressure water jet machine, then the high pressure hose, I link to the toilet by going thru the external of the building. I use tek koh to do. but need two man job. one guy hold tek koh, the other to grab the other end of the hose) to hold the hose tight, I use cable tie Link to post Share on other sites More sharing options...
Kusje Supersonic July 14, 2015 Share July 14, 2015 On 7/14/2015 at 7:45 AM, Watwheels said: I see.... Can share where do you get the LAN keystone from? I mean other dan online. Sim Lim Tower (not square). They should sell entire reels of cables there too. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged July 14, 2015 Share July 14, 2015 TS, I have a unopen new Asus N56 (I think is this model no) router given free by M1 during signup U interested? Cheap cheap.....S$60. self Collect sengkang Link to post Share on other sites More sharing options...
Mustank Hypersonic July 14, 2015 Share July 14, 2015 (edited) On 7/14/2015 at 7:45 AM, Watwheels said: I see.... Can share where do you get the LAN keystone from? I mean other dan online. you go hardware shop should have just tell them you want to buy cat6 wall socket but you will need the punch down tool also Edited July 14, 2015 by Mustank Link to post Share on other sites More sharing options...
Alpha78 6th Gear July 14, 2015 Share July 14, 2015 On 7/14/2015 at 7:51 AM, Mustank said: actually I did that but it was not for lan cable it was for high pressure water hose (I place my high pressure water jet machine, then the high pressure hose, I link to the toilet by going thru the external of the building. I use tek koh to do. but need two man job. one guy hold tek koh, the other to grab the other end of the hose) to hold the hose tight, I use cable tie Eh, better not do such stunts for LAN cables. Once exposed to outside weather, means possibly lightning strike can hit the cable. And confirmed the equipment will get fried. Link to post Share on other sites More sharing options...
Watwheels Supersonic July 14, 2015 Share July 14, 2015 On 7/14/2015 at 7:52 AM, Kusje said: Sim Lim Tower (not square). They should sell entire reels of cables there too. Oh ok...Thanks. On 7/14/2015 at 7:53 AM, Mustank said: you go hardware shop should have just tell them you want to buy cat6 wall socket but you will need the punch down tool also I see...thanks. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 14, 2015 Author Share July 14, 2015 On 7/14/2015 at 7:00 AM, Kusje said: You live in one of the newer HDBs? Your house might already have LAN cables installed in the wall socket... Just need to do some modification. Actually, most of the newer condos also should have it. Ya. think can change from rj11 to rj45 socket. Not sure if i can pull out the cover w/o damaging the wall. That's why quite reluctant to change. Link to post Share on other sites More sharing options...
Matoonia 6th Gear July 14, 2015 Share July 14, 2015 I went through this situation couple of months back. Explored the options discussed here. I suggest TS to try to move around the existing router to the best central location for a start. Even 2-3 metres I feel a difference liao. This is the easiest way for me, and now my EM (2 storey HDB) has Wifi signal everywhere, even in my master bedroom toilet which is blocked by staircase and 2 doors. Link to post Share on other sites More sharing options...
Mustank Hypersonic July 14, 2015 Share July 14, 2015 On 7/14/2015 at 8:00 AM, Stratovarius said: Ya. think can change from rj11 to rj45 socket. Not sure if i can pull out the cover w/o damaging the wall. That's why quite reluctant to change. 2 mounting screws only mah wont spoil the wall lah if realy is lan cable inside, huat ah! Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 14, 2015 Author Share July 14, 2015 On 7/14/2015 at 7:08 AM, KilluaX said: Power plug is another option. http://www.tp-link.com/common/subject/powerline/TL-PA211/ Might give this a try. Thanks. Link to post Share on other sites More sharing options...
Neutrino Supercharged July 14, 2015 Share July 14, 2015 Funny thing is I have two very solid pre cast concrete walls between my router and the PC in my study. I don't get any drop off in download speed at all. Not even 0.1Mbps. Anyway if there had been a severe drop off when we moved in 4 years ago my plan was to run cable through the A/C ducting which runs between all rooms or as last resort Power plugs sometimes known as Home Plugs. Link to post Share on other sites More sharing options...
Blackyv Turbocharged July 14, 2015 Share July 14, 2015 i have a mixture of set up after i bought a better router (Asus RT-AC68U) after my Tp-link Archer C7 seems "weak" recently... i have the main fiber connect to AC68U in living room, this Asus router connect to a TP-link homeplug. i have a receiving homeplug in my study room with Lan output connect to my old Archer C7. this C7 provide wifi to my master bedroom which is the farthest from living hall, and Lan to my computer. with this setup, i have strong wifi coverage in any part of my flat... Link to post Share on other sites More sharing options...
Lala81 Hypersonic July 14, 2015 Share July 14, 2015 I have ac68 at TV console area. Have lan ports in my room. But it connects to my android box. But wifi in my room is still patchy especially with closed doors. Usually it's only 15 mbps only which is liveable. Bought a cheap tenda router from aliexpress but it can't f ING act as an access point. Anyone knows if a cheap tp link wireless n router can do that? The 20 plus dollar one at challenger. Don't want to spend too much. Not going to move my router also. My starhub d link router was donated to my in laws place. So I don't have any other spare routers... 1 Link to post Share on other sites More sharing options...
Vid Hypersonic July 14, 2015 Share July 14, 2015 On 7/14/2015 at 11:42 AM, Lala81 said: I have ac68 at TV console area. Have lan ports in my room. But it connects to my android box. But wifi in my room is still patchy especially with closed doors. Usually it's only 15 mbps only which is liveable. Bought a cheap tenda router from aliexpress but it can't f ING act as an access point. Anyone knows if a cheap tp link wireless n router can do that? The 20 plus dollar one at challenger. Don't want to spend too much. Not going to move my router also. My starhub d link router was donated to my in laws place. So I don't have any other spare routers... Yes, tp link can work as access point. http://www.tp-link.com/gr/FAQ-417.html ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Simple home DIY repairs
Even after $60k in vet bills and going into debt, S’pore couple couldn’t save their dog
Dream home
Dream home
