Windwaver Turbocharged December 9, 2022 Share December 9, 2022 Oh, it's also real stupid when ISP doesn't care how little bandwidth you need and the least you can go is 1Gbps. Not much savings if you go lower and in actual fact, we're good with just 200Mbps. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Raychay 6th Gear December 10, 2022 Share December 10, 2022 A few years ago, SingTel customer service kept pestering me to recontract & upgrade my obsolete 500Mbps plan to 1Gbps. I told her politely I don't need 1Gbps & certainly don't want to pay $10 more for it ($49.90 instead of 39.90). The last straw was when she warned me that I have to pay for a new router should it fail if I don't recontract cos no more warranty. Fine, I switched to M1 1Gbps at $39.90 and got a new Asus router vs recontract at 49.90 for a SingTel rebranded Aztech router. 2 1 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged December 10, 2022 Share December 10, 2022 I looking at this.. currently on sicktel.. if i changing to Myrepublic i will need them to install and activate before i terminate sicktel right? and hoh house number will get new number right? any chance to retain if i move to Myrepublic? Link to post Share on other sites More sharing options...
Genes 6th Gear December 10, 2022 Share December 10, 2022 @Ody_2004 Think number porting is possible, but best to confirm with MR before u sign 1 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged December 11, 2022 Share December 11, 2022 On 12/10/2022 at 11:47 AM, Genes said: @Ody_2004 Think number porting is possible, but best to confirm with MR before u sign Thanks.. to save all trouble i recontracted with SinkTel at $39.90 per month for 2 years #1Gbps Got the tp link ax5400 separately but facing issue.. why can't i connect to the ONT direct to the router? got no internet error.. 1 Link to post Share on other sites More sharing options...
RadX Moderator December 11, 2022 Share December 11, 2022 2 hours ago, Ody_2004 said: Thanks.. to save all trouble i recontracted with SinkTel at $39.90 per month for 2 years #1Gbps Got the tp link ax5400 separately but facing issue.. why can't i connect to the ONT direct to the router? got no internet error.. did u reboot all? Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged December 11, 2022 Share December 11, 2022 17 minutes ago, RadX said: did u reboot all? rebooted many times liao.. never faced such challenges before.. normally plug n play de.. i even called sinktel hotline they refuse to help as not from them! whahahaha Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 11, 2022 Share December 11, 2022 3 hours ago, Ody_2004 said: Thanks.. to save all trouble i recontracted with SinkTel at $39.90 per month for 2 years #1Gbps Got the tp link ax5400 separately but facing issue.. why can't i connect to the ONT direct to the router? got no internet error.. TP link shouldn’t have this problem. Got plug in cables wrongly or not? Haha. Check again. Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged December 11, 2022 Share December 11, 2022 4 minutes ago, Fcw75 said: TP link shouldn’t have this problem. Got plug in cables wrongly or not? Haha. Check again. ok can liao.. must use laptop.. zzzzz.. refer to this video 2 Link to post Share on other sites More sharing options...
Ghgan 6th Gear December 11, 2022 Share December 11, 2022 37 minutes ago, Ody_2004 said: rebooted many times liao.. never faced such challenges before.. normally plug n play de.. i even called sinktel hotline they refuse to help as not from them! whahahaha Singtel ONT or ONR is using vlan tagging, you might to configure the vlan for your tp router for it work. See url for instructions. Otherwise Singtel might hard coded your old router mac address, you need to call singtel to remove the old router mac address and add in your new router mac address. https://www.tp-link.com/sg/support/faq/1585/ 4 Link to post Share on other sites More sharing options...
RadX Moderator December 11, 2022 Share December 11, 2022 29 minutes ago, Fcw75 said: TP link shouldn’t have this problem. Got plug in cables wrongly or not? Haha. Check again. Normally user problem and correct…😂 2 Link to post Share on other sites More sharing options...
RadX Moderator December 11, 2022 Share December 11, 2022 @Ody_2004 you think you ask a tiger to take care of your lamb, it will? Chey… so gullible😂😂 2 Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 11, 2022 Share December 11, 2022 1 hour ago, Ghgan said: Singtel ONT or ONR is using vlan tagging, you might to configure the vlan for your tp router for it work. See url for instructions. Otherwise Singtel might hard coded your old router mac address, you need to call singtel to remove the old router mac address and add in your new router mac address. https://www.tp-link.com/sg/support/faq/1585/ m1 also does that mac address tagging i think. Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 11, 2022 Share December 11, 2022 I haven't rebooted my modem or router for many years. I am not sure why so many people have to reboot so many times. I will only do it when MIL visit and doing something important and suddenly signal just disappear! 1 Link to post Share on other sites More sharing options...
Credor Twincharged December 11, 2022 Share December 11, 2022 (edited) 6 hours ago, Ody_2004 said: Thanks.. to save all trouble i recontracted with SinkTel at $39.90 per month for 2 years #1Gbps Got the tp link ax5400 separately but facing issue.. why can't i connect to the ONT direct to the router? got no internet error.. you got the tp link ax5400 locally or from taoabao? the price is of big difference. Any difference to the coverage when using the tp link? I presume the ax5400 is connect after the Singtel modern ? Is not a replacement to it. Now using the singtel mesh router and the coverage is so so. Thanks. Edited December 11, 2022 by Credor Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged December 11, 2022 Share December 11, 2022 8 minutes ago, Credor said: you got the tp link ax5400 locally or from taoabao? the price is of big difference. Any difference to the coverage when using the tp link? I presume the ax5400 is connect after the Singtel modern ? Is not a replacement to it. Now using the singtel mesh router and the coverage is so so. Thanks. Got it locally Carousell. Those signed M1 got this router.. The AX5400 antenna oredi put the stock Singtel AC Plus router to shame! whahahahahahha.. so far i will say better.. ONT to AX5400.. the stock Singtel retired to cupboard. 1 1 Link to post Share on other sites More sharing options...
RadX Moderator December 11, 2022 Share December 11, 2022 4 minutes ago, Ody_2004 said: Got it locally Carousell. Those signed M1 got this router.. The AX5400 antenna oredi put the stock Singtel AC Plus router to shame! whahahahahahha.. so far i will say better.. ONT to AX5400.. the stock Singtel retired to cupboard. free things cant be good..good things cant be free...ever since i got my spider router..NO MORE of those crap stock routers..no name ones.....like SH and ST Link to post Share on other sites More sharing options...
Volvobrick Supersonic December 11, 2022 Share December 11, 2022 I recontracted with StinkTel. supposed to get a Mesh extender, but they (stated in the agreement) gave me a WiFi 6 router instead. Counter staff told me contract stated router, could not change. Really WTF! I replaced my old router (using same WiFi name and password) but many devices did not connect. I won't go through the trouble of reconnecting 20 plus devices. So the new router ended up back in the box. ↡ Advertisement 1 1 2 Link to post Share on other sites More sharing options...
Simple home DIY repairs
Home Aircon
Home Aircon
Even after $60k in vet bills and going into debt, S’pore couple couldn’t save their dog
Dream home
Dream home
Home renovation tips
No basis for employers to cut pay if flexi-work does not affect productivity: Gan Siow Huang
