Antzng 1st Gear July 14, 2015 Share July 14, 2015 Hi Guys, Need advise for my almost 8 year-old Honda Stream. Recently, I can feel my car shaking when I try to accelerate. This happens especially when I am accelerating up a slope. I dun think it is the engine mount as it was replaced less than 2 yrs ago. What could be the cause? ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 14, 2015 Share July 14, 2015 try plug/coils and clean throttle body Link to post Share on other sites More sharing options...
Count_duku 4th Gear July 14, 2015 Share July 14, 2015 (edited) Hi Guys, Need advise for my almost 8 year-old Honda Stream. Recently, I can feel my car shaking when I try to accelerate. This happens especially when I am accelerating up a slope. I dun think it is the engine mount as it was replaced less than 2 yrs ago. What could be the cause? Check the drive shafts - there is a rubber boot where the shaft connects to the front wheel, if it's torn then likely sand has entered in. Turn the front wheels and check under the car, both sides. The company that specializes in removing and cleaning, replace boot is Elite Drive Shaft at Sin Ming. Edited July 14, 2015 by Count_duku Link to post Share on other sites More sharing options...
Watwheels Supersonic July 14, 2015 Share July 14, 2015 Hi Guys, Need advise for my almost 8 year-old Honda Stream. Recently, I can feel my car shaking when I try to accelerate. This happens especially when I am accelerating up a slope. I dun think it is the engine mount as it was replaced less than 2 yrs ago. What could be the cause? Is it the grooves on the ramp? Very vague. If you dunno whether it's coming from your engine or from the suspension, there's no way of telling. Link to post Share on other sites More sharing options...
ChickenMob 6th Gear July 14, 2015 Share July 14, 2015 could be a lot of things....throttlebody dirty, foul plugs , fuel pump choked blah blah...... need to check it out.... Link to post Share on other sites More sharing options...
Sunny Hypersonic July 14, 2015 Share July 14, 2015 like our body also shiver/shake at times...due to many reasons ghost presence fever/cold after urination having orgasm lolx but let's see if TS will come back let us know what actually the cause after he visit workshop 1 Link to post Share on other sites More sharing options...
Mnns 4th Gear July 14, 2015 Share July 14, 2015 Hi Guys, Need advise for my almost 8 year-old Honda Stream. Recently, I can feel my car shaking when I try to accelerate. This happens especially when I am accelerating up a slope. I dun think it is the engine mount as it was replaced less than 2 yrs ago. What could be the cause? Try coming to a complete stop on a slope at your carpark (assuming you are staying in hdb like me, the ramps up to the next level will do) when there are no traffic, accelerate and move upwards, if it shakes alot, try checking the engine mount nearer to passenger side or nearer to the front. Unless you changed all mounts, the one you replaced two years ago might not be the one failing now - I had this issue last time with a Honda. Link to post Share on other sites More sharing options...
Kippei 3rd Gear July 14, 2015 Share July 14, 2015 it could be transmission shudder. Link to post Share on other sites More sharing options...
Antzng 1st Gear July 15, 2015 Author Share July 15, 2015 it could be transmission shudder. I also suspect there is some problem with the transmission since there is not sound from the drive shaft during u-turn or when cruising. Link to post Share on other sites More sharing options...
Kippei 3rd Gear July 15, 2015 Share July 15, 2015 I also suspect there is some problem with the transmission since there is not sound from the drive shaft during u-turn or when cruising. I usually happen at some particular gear. You see if it is always gear 1 or 2 Link to post Share on other sites More sharing options...
Camry2Harrier 1st Gear July 15, 2015 Share July 15, 2015 recently I have same problem with my ride, later found out to be one of the ignition coil malfunction. Link to post Share on other sites More sharing options...
Quekwb Clutched July 15, 2015 Share July 15, 2015 Last mth, I had this issue too. The car shake whenever I accelerate at speed of 70/80/90km/h. My workshop replaced my driveshaft and the issue was ratified. So far so good. Link to post Share on other sites More sharing options...
teycz 2nd Gear July 16, 2015 Share July 16, 2015 Hi Guys, Need advise for my almost 8 year-old Honda Stream. Recently, I can feel my car shaking when I try to accelerate. This happens especially when I am accelerating up a slope. I dun think it is the engine mount as it was replaced less than 2 yrs ago. What could be the cause? Bro, just change the spark plug.. maybe worn out already. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Any recommended workshop with reasonable labour charges?
