Saravana194 Neutral Newbie March 16, 2016 Share March 16, 2016 Have anyone tried the in car Camera from Autopia, Cowon AN2 Auto capsule?? Heard from my friend that not bad... Any recommendation? ↡ Advertisement Link to post Share on other sites More sharing options...
queenofoeb Clutched March 24, 2016 Share March 24, 2016 On 12/6/2015 at 2:17 PM, elmoguy said: V9 user here. I set to parking mode and motion. Sensitivity is medium. There will be recording as long as any vehicle passed by mine. So far so good. You may want to set the sensitivity to low. If you are not driving for 5 days, it is better to unplug as my friend who is using V7 had his battery total flat after he came back from holiday. When I got my V9, the recording while driving on the road is ON and OFF. I did troubleshooting and realised that it is not camera issue but the cable connector is faulty. Hence, when I use force to push the connector, it will be POWER ON and when I released it, it will POWER OFF. hi @elmoguy, where does your v9 get the power from when car is in parking mode? thanks. Link to post Share on other sites More sharing options...
elmoguy 2nd Gear March 24, 2016 Share March 24, 2016 On 3/24/2016 at 6:03 AM, queenofoeb said: hi @elmoguy, where does your v9 get the power from when car is in parking mode? thanks. Hi, I don't use power bank. My V9 obtained power from the car battery. My 2 friends and myself bought V9 together and so far so good. Initially, I faced some cable issue, the workshop guy changed for me. Ever since, it is running good. http://www.mycarforum.com/topic/2699508-iroad-in-car-camera-recorder-users/page-12 This is current setting and it's fine so far: Link to post Share on other sites More sharing options...
whypaymore_sellcheap Clutched March 31, 2016 Share March 31, 2016 I think so but, if there is no reason why i have done it? On 3/5/2016 at 4:32 PM, Alheych said: Based on the only 7 posts made by the gentleman... it would seem so: http://www.mycarforum.com/index.php?app=core&module=search&do=user_activity&mid=164376&userMode=content Do you know why it is too much hot? The most of the components are from China and IROAD uses Cheap components only. So, it is too hot. If you use wifi connection more than 30 mins, it will be faulty definately. A lot of problems on IROAD wifi dongle and V9 is too much hot when working. On 3/7/2016 at 3:25 AM, Mavwong said: Owner of V9. YEs, the format is not standard. Need to export to AVI in pc/notebook. The app is practically useless, only for change settings and view. Can't save video in iphone also. Export video I can't choose PIP either. I can confirm that the front unit of V9 is HOT! but I never try park under hotsun and verify its functionality. Only know it drain battery like no body business. If I were to buy another car cam, won't be considering iroad anymore. Link to post Share on other sites More sharing options...
whypaymore_sellcheap Clutched March 31, 2016 Share March 31, 2016 Choice is on you. But, IROAD uses cheap components mostly from china. That is why there are a lot of problems on IROAD cameras. V9 has critical problems since it uses cheap china components but it is FullHD. That is why V9 has a lot of faulties but, work shops never tell you because IROAD re-seller prices are cheaper than blackvue and Thinkware. V9 only S$ 219, V7 only S$169 T10 is Fullhd and screen. IROAD T8 has so many hot problems. choice is on you. T10 re-seller price is S$ 289 + 64SD card On 3/7/2016 at 4:33 AM, elmoguy said: Sorry to hear that. Where you staying? Your neighbourhood so much hit and run? T10 has a wider angle, you may want to consider that. There's also temperature monitoring function too. I'm using V9 but then it is too early for me to change at the moment. 1.jpg 2.jpg So far, I only downloaded the file by Wi-Fi and it is AVI format. 3.jpg Yes it is not because of wifi dongle, because IROAD uses mostly cheap China components. IROAD T10 is Full HD and screen and also most of components also from china. choice is on you. On 3/7/2016 at 5:50 AM, Mavwong said: The heat is not due to wifi dongle trust me, I pull it out and tested. IF you didn't pull out the wifi dangle will heat up also. CAn we really download video via wifi? Andriod phone only? As far as I tried, iphone can't. T10 is interesting, 2.3W power draw only. Any trade in program for iroad? I wanna get rid of v9 if t10 really won't heat up and draw much power. T10 is Full HD and screen and most of its components are from CHINA. Choice is on you. T10 re-seller price is S$289 + 64SD card On 3/8/2016 at 2:55 AM, Sglanevo said: Like tat how sia. Lol. Btw will the current IT show a good to get incar? Shld be a better offer right? So far iroad T9 & blackvue are mentioned but with hot weather issues. T10 is new but didnt state that it is heat resistance, only this: "high performance CPU which is designed as low voltage consumption(2.3w) prevents heat deformation and degradation phenomenon and enables stable system operation." So might have issues when sunlight is heating up the cam. Link to post Share on other sites More sharing options...
Fongcasey Neutral Newbie April 2, 2016 Share April 2, 2016 Hi I am using Iroad V7 and just changed car. Salvage the camera but did not manage to pull out the cable. Anyone have a spare set to sell? Link to post Share on other sites More sharing options...
Valx 2nd Gear April 4, 2016 Share April 4, 2016 My V9 dying.. when i on engine it will say camera is connected start recording. inside 5 seconds after they say camera is connected start recording they will say system shutdown and this goes for like a loop like 1 hour + while i was driving.. Anyone has the same problem and fixed it? Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear April 4, 2016 Share April 4, 2016 (edited) On 4/2/2016 at 2:31 PM, Fongcasey said: Hi I am using Iroad V7 and just changed car. Salvage the camera but did not manage to pull out the cable. Anyone have a spare set to sell? I got a spare set for my v9 when I experimented on making a switch to off it instead of pulling out the cable. Not sure if it's compatible. I live in JURONG west st92 in case you wanna try. You can also get the cable from the corvit office at WCEGA TOWER at bukit batok. Should be around $20. On 4/4/2016 at 3:04 AM, Valx said: My V9 dying.. when i on engine it will say camera is connected start recording. inside 5 seconds after they say camera is connected start recording they will say system shutdown and this goes for like a loop like 1 hour + while i was driving.. Anyone has the same problem and fixed it?You wanna try disconnecting the rear camera cable and see if the problem persists? Heard older batch has some rear camera cable issue. Edited April 4, 2016 by Ken_leong Link to post Share on other sites More sharing options...
rovwei 2nd Gear April 4, 2016 Share April 4, 2016 On 4/4/2016 at 3:04 AM, Valx said: My V9 dying.. when i on engine it will say camera is connected start recording. inside 5 seconds after they say camera is connected start recording they will say system shutdown and this goes for like a loop like 1 hour + while i was driving.. Anyone has the same problem and fixed it? My case is exactly the same as yours.. I got new ride n this V9 only last 4months. The Msg kept repeating for the whole journey. Restart, reinstall, shutdown n repeats.. haha.. I went to Hq in bb n they change new Pc (front).. then problem solved..now almost 3months, still ok. Will monitor.. Link to post Share on other sites More sharing options...
Kawan 1st Gear April 4, 2016 Share April 4, 2016 On 4/4/2016 at 3:04 AM, Valx said: My V9 dying.. when i on engine it will say camera is connected start recording. inside 5 seconds after they say camera is connected start recording they will say system shutdown and this goes for like a loop like 1 hour + while i was driving.. Anyone has the same problem and fixed it? Had once during the first few months ... check rear camera cables whether it is loose. Unplug and plug again properly. 1 Link to post Share on other sites More sharing options...
Kuanhui 1st Gear April 16, 2016 Share April 16, 2016 My V7 is dying too, replaced a used unit from Corvit but still the same. WTF Seem like IROAD cannot make it at all. Link to post Share on other sites More sharing options...
LPPL 6th Gear April 17, 2016 Share April 17, 2016 Looking for a reliable multi-angle cam that can record 24hours with/without using car battery and chargeable outside. Any recommendations? Link to post Share on other sites More sharing options...
whypaymore_sellcheap Clutched April 19, 2016 Share April 19, 2016 On 3/24/2016 at 6:03 AM, queenofoeb said: hi @elmoguy, where does your v9 get the power from when car is in parking mode? thanks. Iroad V7, v9 have many flat battery cases, if you dont trust me? Call IROAD OFFICE and ask them how could we prevent flat battery? They will say it has been some problems on iroad pls plug out the power cable. So ridiculaous. They admitted iroad makes a lot of flat battery problems. On 4/16/2016 at 4:33 AM, Kuanhui said: My V7 is dying too, replaced a used unit from Corvit but still the same. WTF Seem like IROAD cannot make it at all. I have emphasized IROAD V7 is rabish. So many blur problem, not clear image, interference and so on. Just buy and get stressed out. On 4/4/2016 at 1:02 PM, Kawan said: Had once during the first few months ... check rear camera cables whether it is loose. Unplug and plug again properly. That is a very common problem on IROAD. There are so many this cases. On 4/4/2016 at 11:25 AM, rovwei said: My case is exactly the same as yours.. I got new ride n this V9 only last 4months. The Msg kept repeating for the whole journey. Restart, reinstall, shutdown n repeats.. haha.. I went to Hq in bb n they change new Pc (front).. then problem solved..now almost 3months, still ok. Will monitor.. This is a common IROAD PROBLEM. a lot of these cases. That is why i dont sell Iroad anymore. Too many faulty cameras. On 4/4/2016 at 5:01 AM, Ken_leong said: I got a spare set for my v9 when I experimented on making a switch to off it instead of pulling out the cable. Not sure if it's compatible. I live in JURONG west st92 in case you wanna try. You can also get the cable from the corvit office at WCEGA TOWER at bukit batok. Should be around $20. You wanna try disconnecting the rear camera cable and see if the problem persists? Heard older batch has some rear camera cable issue. Old version has the interference problem on the rear cable and they changed it to a new version. But same problem. So many my customers compained me that's why I dont sell IROAD ANYMORE. Link to post Share on other sites More sharing options...
howleon Neutral Newbie April 21, 2016 Share April 21, 2016 Anyone currently using iRoad T10? Any reviews on it as I'm deciding whether to purchase one Link to post Share on other sites More sharing options...
Forte3737 5th Gear April 21, 2016 Share April 21, 2016 On 4/19/2016 at 2:02 AM, whypaymore_sellcheap said: Iroad V7, v9 have many flat battery cases, if you dont trust me? Call IROAD OFFICE and ask them how could we prevent flat battery? They will say it has been some problems on iroad pls plug out the power cable. So ridiculaous. They admitted iroad makes a lot of flat battery problems. I have emphasized IROAD V7 is rabish. So many blur problem, not clear image, interference and so on. Just buy and get stressed out. That is a very common problem on IROAD. There are so many this cases. This is a common IROAD PROBLEM. a lot of these cases. That is why i dont sell Iroad anymore. Too many faulty cameras. Old version has the interference problem on the rear cable and they changed it to a new version. But same problem. So many my customers compained me that's why I dont sell IROAD ANYMORE. You from which company? 1 Link to post Share on other sites More sharing options...
Earthboy 4th Gear April 21, 2016 Share April 21, 2016 if you do it a little bit others may still believe you but looks like you have over done it now and make your agenda very obvious. don't always think that others are stupid and dont make yourself look stupid. On 4/19/2016 at 2:02 AM, whypaymore_sellcheap said: Iroad V7, v9 have many flat battery cases, if you dont trust me? Call IROAD OFFICE and ask them how could we prevent flat battery? They will say it has been some problems on iroad pls plug out the power cable. So ridiculaous. They admitted iroad makes a lot of flat battery problems.I have emphasized IROAD V7 is rabish. So many blur problem, not clear image, interference and so on. Just buy and get stressed out.That is a very common problem on IROAD. There are so many this cases.This is a common IROAD PROBLEM. a lot of these cases. That is why i dont sell Iroad anymore. Too many faulty cameras.Old version has the interference problem on the rear cable and they changed it to a new version. But same problem. So many my customers compained me that's why I dont sell IROAD ANYMORE. 1 Link to post Share on other sites More sharing options...
Forte3737 5th Gear April 21, 2016 Share April 21, 2016 On 4/21/2016 at 11:33 PM, Earthboy said: if you do it a little bit others may still believe you but looks like you have over done it now and make your agenda very obvious. don't always think that others are stupid and dont make yourself look stupid.Obviously stupid Link to post Share on other sites More sharing options...
Louiscyr 2nd Gear April 22, 2016 Share April 22, 2016 On 3/7/2016 at 5:50 AM, Mavwong said: The heat is not due to wifi dongle trust me, I pull it out and tested. IF you didn't pull out the wifi dangle will heat up also. CAn we really download video via wifi? Andriod phone only? As far as I tried, iphone can't. T10 is interesting, 2.3W power draw only. Any trade in program for iroad? I wanna get rid of v9 if t10 really won't heat up and draw much power. I'm a iroad v9 user have download multiple videos using WiFi and onto my Samsung phones no problems with it :) If the camera is WiFi enabled u will definitely be able to download to any phones be it android or apple ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Car camera recommendation
Explore High-Performance FineVu Dashcams by Auto Interior Pte Ltd
Marbella DashCam Users
Wifi IP CCTV
Wifi IP CCTV
Huawei Mate 20 Pro / Leica Camera
