mbt2015 1st Gear December 30, 2015 Share December 30, 2015 On 12/8/2015 at 1:20 PM, Yuguangr said: bro, can take a pic of the switch? thanks. For the benefits of those who wants to know how the switch is installed on my car for the V9 cam. It is just a small switch hidden in front of the driver's seat near the brake paddle. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Yuguangr 2nd Gear December 30, 2015 Share December 30, 2015 On 12/30/2015 at 2:19 AM, mbt2015 said: For the benefits of those who wants to know how the switch is installed on my car for the V9 cam. It is just a small switch hidden in front of the driver's seat near the brake paddle. nicely done bro. 1 Link to post Share on other sites More sharing options...
elmoguy 2nd Gear December 30, 2015 Share December 30, 2015 On 12/30/2015 at 2:19 AM, mbt2015 said: For the benefits of those who wants to know how the switch is installed on my car for the V9 cam. It is just a small switch hidden in front of the driver's seat near the brake paddle. Very good workmanship. Link to post Share on other sites More sharing options...
Kennethou Clutched January 4, 2016 Share January 4, 2016 (edited) did a switch for the iRoad at Car Beauty Centre. quite well done i think for $15 Edited January 4, 2016 by Kennethou 2 Link to post Share on other sites More sharing options...
Yuguangr 2nd Gear January 4, 2016 Share January 4, 2016 On 1/4/2016 at 2:22 PM, Kennethou said: did a switch for the iRoad at Car Beauty Centre. quite well done i think for $15 bro, how long it took? and u just walk in or need to make any appointment? and just curious, should we change to another cam, can this switch be used for the other cam as well? cos afraid will leave a permanent hole there. thanks. Link to post Share on other sites More sharing options...
Yewheng Twincharged January 4, 2016 Share January 4, 2016 https://www.facebook.com/yoursingapore/videos/10156364493825704/?fref=nf We already have 360 degrees video technology, maybe in future it will become mainstream and drivers no need scared of accident or incident at any direction as it is captured by the 360degrees video cam. Link to post Share on other sites More sharing options...
Kennethou Clutched January 5, 2016 Share January 5, 2016 On 1/4/2016 at 3:00 PM, Yuguangr said: bro, how long it took? and u just walk in or need to make any appointment? and just curious, should we change to another cam, can this switch be used for the other cam as well? cos afraid will leave a permanent hole there. thanks. I did other stuff there so it took longer. But I didn't make appt . Not sure about your 2nd question. I suppose it's possible to reuse Link to post Share on other sites More sharing options...
Surecheong 1st Gear January 7, 2016 Share January 7, 2016 It seems like my camera is off upon parking for my car. Is it easy to re-wire yourself such that parking mode can be enabled or do I need to get some shop to rewire for me? If so, how much will it cost? 1 Link to post Share on other sites More sharing options...
Surecheong 1st Gear January 7, 2016 Share January 7, 2016 On 1/7/2016 at 6:23 AM, R0_ger said: U plug in to the cigarette lighter socket? It comes with the new car. It is not plugged to the cigarette lighter socket. Suspect it could be wired to the ignition and not to the battery. Do you know how do I check? Link to post Share on other sites More sharing options...
Kennethou Clutched January 15, 2016 Share January 15, 2016 if iinstalling a new sd card. do I have to format the sd card first? and if yes, in what format? Link to post Share on other sites More sharing options...
Stevle 5th Gear January 15, 2016 Share January 15, 2016 On 1/15/2016 at 6:10 AM, Kennethou said: if iinstalling a new sd card. do I have to format the sd card first? and if yes, in what format? Don't need. Just plug in and let the machine do the work... but has to be patient... refer to my earlier post #161 2 Link to post Share on other sites More sharing options...
Ek3stage 1st Gear January 15, 2016 Share January 15, 2016 (edited) On 1/15/2016 at 2:04 PM, Ek3stage said: I find the wifi recep also keep disconnecting. Quite cock sure is due to heat, so I add a 15cm usb ext cable, and plug the wifi away from the unit. This serves few purpose: 1. Heat from the wifi wont be trapped/transferred to the unit. The unit is actually MUCH cooler now. 2. I can hide the wifi under the sun shade, so less heat from sun. 3. The usb cable metal casing acts as heatsink, so the wifi is now LESS hot than before. I will add a small heatsink to the wifi to diffuse the heat buildup further. Wifi recep issue gone! Dont even need to off phone data. Just some sharing, hope it helps! My rear camera metal connector is not that hot. If yours is freaking hot, you can wrap aluminum tape or foil to act as heatsink. I didnt feel the need to do yet, but it will work. But in the first place, should it be that hot?...if so, your board could have sinking problem.... Edited January 15, 2016 by Ek3stage Link to post Share on other sites More sharing options...
Chuapcd 1st Gear January 26, 2016 Share January 26, 2016 Can someone please recommend me a place to do installation? I also need to be able to record 24x7 and I believe I need to get a power unit installed as welll....thanks in advance. Link to post Share on other sites More sharing options...
Ken_leong 2nd Gear January 28, 2016 Share January 28, 2016 On 1/26/2016 at 1:30 AM, Chuapcd said: Can someone please recommend me a place to do installation? I also need to be able to record 24x7 and I believe I need to get a power unit installed as welll....thanks in advance. https://www.facebook.com/667racingTrading/ My friend intro them to me. I not promoting on their behalf. Just that I thinking of upgrading my aev and get a v9 from them. Link to post Share on other sites More sharing options...
Zoarium 1st Gear January 28, 2016 Share January 28, 2016 Want to sell a mint condition Garmin GDR 190 car camera. This is export set so no camera but in good working condition. Will give personal warranty of 3 months on factory defects (Wear and tear not counted). Only super wide angle car cam on the market at 200 degrees. Will give a free 8 GB SD card. Retails @ $399. Selling for $300.Deal @ Tiong bahru. Contact me @ 98483320.GDR190 200° WIDE ANGLE HD RECORDING-Built-in GPS function-Built-in 1500mAh Battery, up to 90 minutes working time-G-sensor spontaneous sensing image automatically protected-Support SDHC memory card-200 degree wide angle recording-3.0" adjustable display screen-Front Collision Warning Link to post Share on other sites More sharing options...
Chuapcd 1st Gear January 29, 2016 Share January 29, 2016 Hi, for iRoad V9. .do we need 2 SD cards? One for front and one for rear ? Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged January 29, 2016 Share January 29, 2016 On 1/29/2016 at 4:15 PM, Chuapcd said: Hi, for iRoad V9. .do we need 2 SD cards? One for front and one for rear ?No need 2. Just 1 MicroSD class 10 card.. preferably 32 or 64gb Link to post Share on other sites More sharing options...
Heman75 Supercharged January 30, 2016 Share January 30, 2016 On 1/5/2015 at 2:38 AM, Xers007 said: Many have done that... best is to have cams covering all sides... my neighbor put two more at the sides. total 6 camera. super KS. .. i ask him how about putting one on top face the sky and one at the bottom face the road. then you will know if ppl throw thing down on your car and construction road damage your car carriage or not ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Car camera recommendation
Explore High-Performance FineVu Dashcams by Auto Interior Pte Ltd
Marbella DashCam Users
Wifi IP CCTV
Wifi IP CCTV
Huawei Mate 20 Pro / Leica Camera
