F430 1st Gear May 30, 2020 Share May 30, 2020 39 minutes ago, Blackhawk01 said: Hi F430. Heard of autokinetics. Have you tried vantage vag? VAG is definitely recommended. You pay what you get. ↡ Advertisement Link to post Share on other sites More sharing options...
Blackhawk01 1st Gear May 30, 2020 Share May 30, 2020 15 minutes ago, F430 said: VAG is definitely recommended. You pay what you get. I believe any branch is good to replace coilover for audi. Thanks F430. Link to post Share on other sites More sharing options...
A320Skipper Neutral Newbie May 31, 2020 Share May 31, 2020 On 5/29/2020 at 11:51 AM, Wishnl said: Sound good bro... Any bros here change to PA sports suspension? can share how is the feeling, i was also looking at changing to aftermarket but this seem like a better choice. I did. The handling is good, the car corners well, and it comes with the lowered look. Worth considering, unless you know exactly what you want out of the setup that only the aftermarket ones can offer. Link to post Share on other sites More sharing options...
SZ_ford 5th Gear June 1, 2020 Share June 1, 2020 18 hours ago, A320Skipper said: I did. The handling is good, the car corners well, and it comes with the lowered look. Worth considering, unless you know exactly what you want out of the setup that only the aftermarket ones can offer. is this the same suspension that comes on A5? Link to post Share on other sites More sharing options...
Blackhawk01 1st Gear June 1, 2020 Share June 1, 2020 On 5/31/2020 at 6:19 PM, A320Skipper said: I did. The handling is good, the car corners well, and it comes with the lowered look. Worth considering, unless you know exactly what you want out of the setup that only the aftermarket ones can offer. Hi Bro. Can post a side view of your ride? Is the gap between the wheel and arc wide? Thank you. Link to post Share on other sites More sharing options...
Dice 3rd Gear June 4, 2020 Share June 4, 2020 (edited) On 5/29/2020 at 12:35 PM, SZ_ford said: agree offset is important. same rim looks bigger when totally flushed 20'' look small even on the newest a6 Mine after swapping out 18s (top) for 19s. A4. Very keen to know the look of audi sport suspension from PA since they will cover warranty. Edited June 4, 2020 by Dice 3 Link to post Share on other sites More sharing options...
Blackhawk01 1st Gear June 5, 2020 Share June 5, 2020 Mine also 19inch on original suspension. Gaps are wide. Keen to see how does it look like too. Link to post Share on other sites More sharing options...
SZ_ford 5th Gear June 5, 2020 Share June 5, 2020 10 hours ago, Dice said: Mine after swapping out 18s (top) for 19s. A4. Very keen to know the look of audi sport suspension from PA since they will cover warranty. i think u can see it on a5, if im not wrong is 1-2cm drop of cos, if the bro can post his, better still. ***Sport suspension A specifically tuned suspension system that rests 10 to 20 millimetres lower than a typical suspension on the same vehicle, with firmer springs and dampers. Sport suspension is a feature available on select Audi vehicles. Link to post Share on other sites More sharing options...
Blackhawk01 1st Gear June 5, 2020 Share June 5, 2020 Spoiler Spoiler I like this ride height. This A4 is on 20inch rims. Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 5, 2020 Share June 5, 2020 This looks like aftermarket suspension. Link to post Share on other sites More sharing options...
Blackhawk01 1st Gear June 5, 2020 Share June 5, 2020 Yes. Picture from Internet. Looks very aggressive Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 5, 2020 Share June 5, 2020 2 minutes ago, Blackhawk01 said: Yes. Picture from Internet. Looks very aggressive Can you butt tahan or not with 19" inch wheel? The suspension has to be stiff. 1 Link to post Share on other sites More sharing options...
Blackhawk01 1st Gear June 5, 2020 Share June 5, 2020 19 inch on original suspension is still OK. The b16 coilover can set damping in 10 steps. Don't know will it be harsh or not. Link to post Share on other sites More sharing options...
Gate75 Neutral Newbie June 22, 2020 Share June 22, 2020 Any recommendations on car paint touch up? Scratched my bumper Link to post Share on other sites More sharing options...
Volvobrick Supersonic June 22, 2020 Share June 22, 2020 1 hour ago, Gate75 said: Any recommendations on car paint touch up? Scratched my bumper Respray, or buy touch up paint for a few dollars from Aliexpress etc and DIY, especially if the scratches are minor and at the bottom. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged June 22, 2020 Share June 22, 2020 (edited) On 6/5/2020 at 3:28 PM, inlinesix said: Can you butt tahan or not with 19" inch wheel? The suspension has to be stiff. . on a separate note, those on original 20 inch civic type R have sort of downsize to 18 inch If the A4 comes with DCC may still be able to get away with the ride comfort on 19 inch with some tweaks on the tires aspect ratio so how many have booked the leylong A4? Edited June 22, 2020 by Sdf4786k Link to post Share on other sites More sharing options...
RickyWee 3rd Gear July 7, 2020 Share July 7, 2020 (edited) Virtual launch of the new Audi A4 Sedan 2020 Edited July 7, 2020 by RickyWee 2 Link to post Share on other sites More sharing options...
Lotr 6th Gear July 7, 2020 Share July 7, 2020 1 hour ago, RickyWee said: Virtual launch of the new Audi A4 Sedan 2020 Got memory seats now but the rims are not the ones in the blue car in the video ↡ Advertisement Link to post Share on other sites More sharing options...
2020 Polestar 2
2020 Polestar 2
COE Bidding - January 2025
2024 Suzuki Swift
2024 Suzuki Swift
