Nzy Twincharged June 20, 2015 Share June 20, 2015 (edited) I feel not on slope also need to pull handbrake. Cuz although its not a slope but the ground might not be perfectly level so the car can still roll forwards or backwards putting alot of strain on the parking pawl. I had a friend whose P gear not working cuz the car still can roll even in P. Before his P gear stopped working, he has a habit of not pulling handbrake unless on slope. I remember it clearly cuz when I borrowed his car, he kept emphasizing to me must pull handbrake cuz his P gear not working already. Edited June 20, 2015 by Nzy ↡ Advertisement Link to post Share on other sites More sharing options...
BobbyTan_74287 4th Gear June 20, 2015 Share June 20, 2015 On 6/20/2015 at 4:22 AM, Blackyv said: Then we should hear from horse mouth. Who's gb koyak and their rule of engagement?, share here please .. I believe most gb can last more than 10yrs, anything lesser could be handling.. Those gb koyak after 5yrs, what is your style? Those gb kaput after 7yrs,? Those gb gone after 9yrs? Those koyak below 5yrs should be genetic defect, very likely not related to how it was being handled.. But can still share if you want (except that one obvious model which everybody knows, no need to share..) Those above 10yrs should be wear and tear, not a good reflective of handling style... Hehehe... Anyone wanna start? My old car gb kaput after 7.5 years used. Every morning I needed to start engine and waited for 5 mins for the engine to warmed up before I can move off. If I stopped my car for more than 4 hours, I again need to wait for 5 mins. Finally I spent $3,500 to overhaul the gb. Link to post Share on other sites More sharing options...
Beng2 5th Gear June 20, 2015 Share June 20, 2015 I put to N after stopping. Apply parking brake. Off engine. Remove key and leave car. Find that sometimes after putting to P when parking the car, the car jerks a bit when D is engaged again, with a bit of knocking sound. Old GB. Link to post Share on other sites More sharing options...
Blackyv Turbocharged June 20, 2015 Share June 20, 2015 On 6/20/2015 at 10:01 AM, BobbyTan_74287 said: My old car gb kaput after 7.5 years used. Every morning I needed to start engine and waited for 5 mins for the engine to warmed up before I can move off. If I stopped my car for more than 4 hours, I again need to wait for 5 mins. Finally I spent $3,500 to overhaul the gb. Errr.... Warming up engine or not before moving off got nothing to do with gb leh... What is your sop with gb handling before engine cut off ? Link to post Share on other sites More sharing options...
BobbyTan_74287 4th Gear June 20, 2015 Share June 20, 2015 On 6/20/2015 at 12:05 PM, Blackyv said: Errr.... Warming up engine or not before moving off got nothing to do with gb leh... What is your sop with gb handling before engine cut off ? Is as per normal, put to P, off air-con, pull hand brake and then off the engine. I went to AD and the Techincal Advisor said gb needed replaced which required $12k. So he told me went outside to get overhaul which is much much cheaper. Link to post Share on other sites More sharing options...
zerobim08 4th Gear June 20, 2015 Share June 20, 2015 I think this is much ado about nothing. No matter which method you used to turn off I think the wear on the gearbox is so insignificant compared to when the gearbox is actually in use like hard acc or deceleration especially when the mechanism is still has not warmed up. ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding – Mar 2025
Coolant level going down
Car of Politician
Car of Politician
Anyone missing a car plate?
