deepbluekm Clutched April 13, 2016 Share April 13, 2016 The sound quality is much better than the original unit from Toyota. Yes the 5750 has a USB but it's at the back so have to put it to the front with the extended cable provided. I am not sure if there is GPS preloaded for the 5750. Maybe the 8750 has it.Hi, sorry for bring up a few months old post.. can I check with you is there any warranty for your 5750? Cover by AutoImage? So far do you getting any problem? Plan to getting one too. Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Axeman24 2nd Gear April 13, 2016 Author Share April 13, 2016 Hi, sorry for bring up a few months old post.. can I check with you is there any warranty for your 5750? Cover by AutoImage? So far do you getting any problem? Plan to getting one too. Thanks! Hi, should you buy from Autoimage, if its still under warranty, they will help you send the damage unit to the service centre. I have installed it for 1 year already so far there is no problem with the set. I only connect my IPhone to it so that I can listen to music which I download from Sportify, Apart from that, I did not use the Pioneer app and the mirror app which I find that is quite limited on the 5750. If you which to have more features, then I would suggest you go for the 8000 series. I hope this helps. Cheers. Link to post Share on other sites More sharing options...
deepbluekm Clutched April 13, 2016 Share April 13, 2016 Hi, should you buy from Autoimage, if its still under warranty, they will help you send the damage unit to the service centre. I have installed it for 1 year already so far there is no problem with the set. I only connect my IPhone to it so that I can listen to music which I download from Sportify, Apart from that, I did not use the Pioneer app and the mirror app which I find that is quite limited on the 5750. If you which to have more features, then I would suggest you go for the 8000 series. I hope this helps. Cheers.Thanks for quick response and helpful info. Btw, the Pioneer HU can play DVD and display on screen right? Just to double confirm hehe Link to post Share on other sites More sharing options...
Axeman24 2nd Gear April 13, 2016 Author Share April 13, 2016 Thanks for quick response and helpful info. Btw, the Pioneer HU can play DVD and display on screen right? Just to double confirm hehe Yes of cos it can. Link to post Share on other sites More sharing options...
deepbluekm Clutched April 13, 2016 Share April 13, 2016 Hi, should you buy from Autoimage, if its still under warranty, they will help you send the damage unit to the service centre. I have installed it for 1 year already so far there is no problem with the set. I only connect my IPhone to it so that I can listen to music which I download from Sportify, Apart from that, I did not use the Pioneer app and the mirror app which I find that is quite limited on the 5750. If you which to have more features, then I would suggest you go for the 8000 series. I hope this helps. Cheers.Thanks for quick response and helpful info. Btw, the Pioneer HU can play DVD and display on screen right? Just to double confirm hehe ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Land Cruiser Mini
Toyota Corolla Cross
Next Generation Toyota Crown
Toyota shows how GR Yaris is made, hints at more GR cars
8th Gen Toyota Camry (XV70)
