Acema Clutched May 30, 2015 Share May 30, 2015 Hi Guys,The previous shop i went over tighten my lug nut. Currently its broken and 1/4 of it is stuck inside the rim.Currently unable to remove the rim to change tire or brake pad.Any shops to recommend which has the specialize tools?There are 2 nuts that are broken and i was quoted $150 per nut and require to leave car for about 2 days. I tried googling and there are some shops with special tools that can cut down the timing and cost. Anyone got any experience to share?Do let me know the price range and shop.Thx in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Kippei 3rd Gear May 30, 2015 Share May 30, 2015 take a pic of the dmg. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 30, 2015 Share May 30, 2015 (edited) Most likely what they will do is to sacrifice a size smaller wrench socket (very cheap for China made ones) and hammer the socket and jam it with the broken and stuck lug nut. Dan use a torque wrench to unscrew it out. No need what special tools. I have seen ppl done it before. For ppl who tells you need special tool this and that, they are hinting for you to pay more for the job. Edited May 30, 2015 by Watwheels Link to post Share on other sites More sharing options...
Dtitan 1st Gear May 30, 2015 Share May 30, 2015 Happened to me once many moons ago... Went to a workshop at Tampines industrial area near to SAFRA there Think I paid abt $30 or 50 I can't remember for 1 broken screw Hope it helps Link to post Share on other sites More sharing options...
Acema Clutched May 30, 2015 Author Share May 30, 2015 Unable to take a pic as they have screw back the lug nut. The very end of the lug nut is stuck inside. so if the shop unscrew, only 4/5 of the lug nut will be out. Any shop specialize in doing this? Happened to me once many moons ago...Went to a workshop at Tampines industrial area near to SAFRA thereThink I paid abt $30 or 50 I can't remember for 1 broken screwHope it helps Its not the screw that has been broken but the lug nut. Any idea of the shop name? Maybe i can drop by to take a look. Link to post Share on other sites More sharing options...
Acema Clutched May 30, 2015 Author Share May 30, 2015 take a pic of the dmg. Not the image of my rim But look something like this. 1/5 of the lug nut still stuck inside. Link to post Share on other sites More sharing options...
Kb27 Supersonic May 30, 2015 Share May 30, 2015 Special tools required is usually lug nut/bolt extractor. http://www.amazon.com/Irwin-Industrial-Tools-54125-Specialty/dp/B001ACPRFU However, it depends on the state of the broken off nut. Ws charged by what tools they have, their skill in removing that broken off nut. Unfortunately, you can't dictate how they do it or with what tools they have or have not. Link to post Share on other sites More sharing options...
Dtitan 1st Gear May 31, 2015 Share May 31, 2015 Bro Sry Dun remember shop name as it is very long ago.... 1 Link to post Share on other sites More sharing options...
nazerath Turbocharged May 31, 2015 Share May 31, 2015 Nut extractor or like what they say, use another socket n hammer it in then impact driver to take it out. Not sure if the nut remover is so deep. Quite problematic. 6 Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear June 1, 2015 Share June 1, 2015 any way is to drill thru the nut. it the same concept as removing a rounded nut. ↡ Advertisement Link to post Share on other sites More sharing options...
Takata airbag recall
[Concept] Honda 0 Series EVs
2014 Honda Odyssey
2014 Honda Odyssey
Any Top Notch Buffet Catering to recommend? PLEASE!!
Honda Vezel - Part 3
