Enye Hypersonic May 27, 2015 Share May 27, 2015 much closer to home this time. SINGAPORE - Passengers on a Singapore Airlines (SIA) flight bound for Shanghai on Saturday had a bit of a scare when both engines experienced a temporary loss of power amid bad weather. The incident occurred at 39,000 ft about 3.5 hours after Flight SQ836, operated by an Airbus A330-300, left Changi Airport. "Both engines experienced a temporary loss of power and the pilots followed operational procedures to restore normal operation of the engines" said the airline's spokesman. The flight with 182 passengers and 12 crew on board continued to Shanghai and touched down safely at 10.56pm local time, he added. The engines were thoroughly inspected and tested upon arrival in Shanghai with no anomalies detected. SIA is reviewing the incident with engine maker, Rolls-Royce and Airbus. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Vid Hypersonic May 27, 2015 Share May 27, 2015 much closer to home this time. SINGAPORE - Passengers on a Singapore Airlines (SIA) flight bound for Shanghai on Saturday had a bit of a scare when both engines experienced a temporary loss of power amid bad weather. The incident occurred at 39,000 ft about 3.5 hours after Flight SQ836, operated by an Airbus A330-300, left Changi Airport. "Both engines experienced a temporary loss of power and the pilots followed operational procedures to restore normal operation of the engines" said the airline's spokesman. The flight with 182 passengers and 12 crew on board continued to Shanghai and touched down safely at 10.56pm local time, he added. The engines were thoroughly inspected and tested upon arrival in Shanghai with no anomalies detected. SIA is reviewing the incident with engine maker, Rolls-Royce and Airbus. Read this news this morning and it send chills down my spine. They found no problems with the engine which makes me wonder if SIA will use the plane for the return flight? [:/] 1 Link to post Share on other sites More sharing options...
13177 Hypersonic May 27, 2015 Share May 27, 2015 (edited) Bad weather really can caused lots of problems while plane is flying up there! Edited May 27, 2015 by 13177 1 Link to post Share on other sites More sharing options...
Enye Hypersonic May 27, 2015 Author Share May 27, 2015 Read this news this morning and it send chills down my spine. They found no problems with the engine which makes me wonder if SIA will use the plane for the return flight? [:/] Another report said they did 😨 Link to post Share on other sites More sharing options...
Vid Hypersonic May 27, 2015 Share May 27, 2015 Another report said they did 😨 Seriously.... :lll._.: Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic May 27, 2015 Share May 27, 2015 I hate travelling on Airbus...but sometimes bobian..... Link to post Share on other sites More sharing options...
Soya Supersonic May 27, 2015 Share May 27, 2015 Airbus oso use DSG ah?........ 8 Link to post Share on other sites More sharing options...
RadX Moderator May 27, 2015 Share May 27, 2015 Airbus oso use DSG ah?........ JAmes Page come scold you then you know 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 27, 2015 Share May 27, 2015 when you have 3 major conglomerates from 3 different nationalities - German, French and Brits with 3 totally different kinds of traits, working to piece up one airplane, you know what you are getting... 3 Link to post Share on other sites More sharing options...
Soya Supersonic May 27, 2015 Share May 27, 2015 (edited) JAmes Page come scold you then you know oppps....... . Edited May 27, 2015 by Soya Link to post Share on other sites More sharing options...
Pocus Turbocharged May 27, 2015 Share May 27, 2015 JAmes Page come scold you then you know Don't need James Page, when got some VW loser fan dislike your post as anonymous and give comments as "........" Can't even type out the reason properly, must be the DSG in his head got problem. 7 Link to post Share on other sites More sharing options...
13177 Hypersonic May 27, 2015 Share May 27, 2015 Toothiewabbit, on 27 May 2015 - 11:42 AM, said:I hate travelling on Airbus...but sometimes bobian..... What's wrong with airbus? Link to post Share on other sites More sharing options...
Soya Supersonic May 27, 2015 Share May 27, 2015 when you have 3 major conglomerates from 3 different nationalities - German, French and Brits with 3 totally different kinds of traits, working to piece up one airplane, you know what you are getting... dun comprain abt airbus lah. would u rather fly this next time?........ You may fly on a Made-in-China aircraft sooner than you think http://www.cnbc.com/id/101409883 Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 27, 2015 Share May 27, 2015 can claim insurance for scare sustained??? dun comprain abt airbus lah. would u rather fly this next time?........ You may fly on a Made-in-China aircraft sooner than you think http://www.cnbc.com/id/101409883 look like a whale 1 Link to post Share on other sites More sharing options...
Pinobii Hypersonic May 27, 2015 Share May 27, 2015 Scary especially for some who takes this flight! I don't like Airbus, Boeing is better The new batch of Airbus purchased around 2 years back already like quite old and noisy, not as good as Boeing ones 3 Link to post Share on other sites More sharing options...
B777jubilee 2nd Gear May 27, 2015 Share May 27, 2015 For 2 engines to die simultaneously, it is usually nothing related to the engine itself. The possible outcome are: Lose of fuel feed to the engines Weather conditions (not enough oxygen in the engines to ignite the fuel) It seems that upon initial checks in Shanghai the aircraft exhibit no mechanical issues plus the engines managed to be reignited at lower altitude. This points to me with weather as the likely cause but then we have to wait for investigation report. Previous simultaneous loss of both engines are due to aircraft running out of fuel or the aircraft flying into volcanic ash clouds which results in engine dying due to lack of oxygen to ignite the fuel mix. 11 Link to post Share on other sites More sharing options...
Ake109 6th Gear May 27, 2015 Share May 27, 2015 Wonder if they made an announcement to the passengers or just restart and keep quiet. If both main engines shut down suddenly, does the APU kick in immediately? Can the on board batteries power all the electrics? Wondering if in such a case, do the lights dim, TV screens go off etc. 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 27, 2015 Share May 27, 2015 looks very anti-aerodynamic leh. dun comprain abt airbus lah. would u rather fly this next time?........ You may fly on a Made-in-China aircraft sooner than you think http://www.cnbc.com/id/101409883 ↡ Advertisement Link to post Share on other sites More sharing options...
Singapore Airlines and Malaysia Airlines to launch code share flights
SIA ditches ‘flight to nowhere’ idea, rolls out A380 restaurant, delivery menu and training facilities tour
Singapore Airshow 2020 Returns On 15 Feb, With Insane Flight Displays & Superhero Cameos
BreadTalk Will Delist Company On 5 Jun After Posting $5.8 Million Loss In 2019
China: 1st time in Shanghai
Krisflyer Miles Lose Value - use them up now
