v2d Clutched August 27, 2018 Author Share August 27, 2018 Don't know what to do when involved in a car mishap? Fret not. http://membership.v2d.com.sg/ Our Accident Division will assist you in the following :1. Accident reporting. 2. Rental Vehicle replacement. 3. Accident recovery. 4. Legal aid ( If required )5. Bodily injury ( If required ) Do not hesitate to get us at our hotline : 61007676 / 86687676. @ Pro-Jex V2D Link to post Share on other sites More sharing options...
v2d Clutched September 21, 2018 Author Share September 21, 2018 AMSOIL DOMINATOR octane booster 1.Improves performance2.Removes carbon deposits3.Maximizes power4.Reduces engine knock5.Improves ignition6.Improves responsiveness7.Helps fuel burn cleaner AMSOIL DOMINATOR® Octane Boost (AOB) significantly increases engine response and power in all two- and four-stroke gasoline-fueled engines by increasing octane up to four numbers. Just one treatment reduces engine knock, improves ignition and helps fuel burn cleaner. Maximizes power and improves performance in all two-cycle and four-cycle gasoline engines. Increases octane up to 4 numbers. Reduces engine knock, improves ignition and engine response, helps fuel burn cleaner and inhibits corrosion. Recommended for off-road and racing use. AMSOIL GASOLINE ADDICTIVE 1.Improves fuel mileage an average of 2.3% and up to 5.7%2.Reduced emissions-hydrocarbons (HC) up to 15%-carbon monoxide (CO) up to 26%-nitrous oxides (NOx) up to 17% 3.Restored power and performance4.Reduced need for costly higher octane fuel5.Reduced noise from carbon rap and pre-ignition6.Better drivability7.Smoother operation AMSOIL GASOLINE most potent gasoline additive available today. As a concentrated detergent, it is unsurpassed in cleaning combustion chamber deposits, intake valve deposits and port fuel injector deposits. AMSOIL P.i. helps maintain peak engine efficiency, fuel economy, power and drivability in newer low mileage engines. In engines with accumulated deposits, testing showed AMSOIL P.i. provided the following clean-up benefits after only one tank of gasoline. Link to post Share on other sites More sharing options...
v2d Clutched September 26, 2018 Author Share September 26, 2018 PROMOTION:Intake manifold & throttle body servicing @$50. Tested and proven on cars, bikes and boats running on carburetor or fuel injection. http://www.facebook.com/v2d.com.sg You will experience following after this procedure : 1- Easier start up. 2- Very light throttle response. 3- Fuel efficient.4- Engine vibration will be minimized. Air-Con Cleaner using USA Nano Mist Technology @$50. Air conditioners are ideal media for bacteria, mildew and other germs, which can eventually cause musty smell and trigger allergic reactions. Hence, we strongly recommend for car owners to take on this optional final step – it is a process whereby our specialist will perform a final disinfection using Nano Mist Technology on the whole interior. It crackdown germs, mold and mildew on the filter, remove harmful germs in the air-duct , disinfects ventilation system and eventually remove 99.9% of all odors and bacteria. If you clean and maintain your house regularly, why not your car interior? Car owners rarely deep clean in all areas of car's interior on regular basis. This in turn, various molds and bacteria to thrive and grow in these untreated conditions. These uninvited guests can have damaging effects on the health, causing allergies, and in the long run, might lead to serious respiratory and lung problems. Hence, keeping your car interior clean and pest-free is extremely important to the well-being of You and your Family! Boost up!!!#HKS EVC#CustomPiping. Link to post Share on other sites More sharing options...
v2d Clutched October 31, 2018 Author Share October 31, 2018 Don't know what to do when involved in a car mishap? Fret not. http://membership.v2d.com.sg/ Our Accident Division will assist you in the following :1. Accident reporting. 2. Rental Vehicle replacement. 3. Accident recovery. 4. Legal aid ( If required )5. Bodily injury ( If required ) DELIOS ROTORS. Each disc is 100% measured and inspected to meet our strict tolerances and specifications.What you will notice:More BiteBetter Release ControlMore Stopping PowerIncreased Pedal ResponseIncreased Corner SpeedLonger lifeNoise level reduced for quiet brakingEasy pad bed in through the use of double face grinding or burnished finishExtended service life of the wheel suspension and wheel bearings. Honda Airwave 1.5A Cooling System Replacement!!! Subaru Forester back for undercarriage rebuild and cooling system upgrades!!! #Hyundai #Elantra back for steering column and steering rack rebuild ! #Amsoil #HighZinc Formula !!! 10W40 Aircon and cooling system rectification!!! #MITSUBISHI #ASX back for cooling coil replacement & AMSOIL HIGH ZINC SERVICING !!! Link to post Share on other sites More sharing options...
v2d Clutched November 27, 2018 Author Share November 27, 2018 Drive a cool car today! Revitalise the air-con in your prized vehicle with PRO-JEX V2D’s tested and proven system that removes odour, kills 99.9% bacteria to refresh your spirit and even offers fuel savings. Call us now at 86687676 to enjoy our promotional rate @$80. Offer is for a limited time period only! Don't know what to do when involved in a car mishap? Fret not. http://membership.v2d.com.sg/ Our Accident Division will assist you in the following :1. Accident reporting. 2. Rental Vehicle replacement. 3. Accident recovery. 4. Legal aid ( If required )5. Bodily injury ( If required ) Do not hesitate to get us at our hotline : 61007676 / 86687676. Synergy @ KB No 25 Kaki Bukit Road 4 #03-93 / #03-94. S417800. Honda Civic came to install BC Racing Coilover! Honda civic Ek4 servicing using amsoil signature 5w30! Drive a cool car today! Revitalise the air-con in your prized vehicle with PRO-JEX V2D’s tested and proven system that removes odour, kills 99.9% bacteria to refresh your spirit and even offers fuel savings. Call us now at 86687676 to enjoy our promotional rate @$80. Offer is for a limited time period only! Mercedes Benz CLA200 back for original auxiliary battery replacement !!! #Honda #Stream #Rn6 back for #Fujiace front and rear brake rotors and brake pads replacement complete with #Brembo brake fluid bleeding !!! Complaint from client :Spongy brake feel when brakes depressed . Tested Satis. Back for #Delios high performance rotors and #Brembo brake pads replacement! Complete with #Brembo brake fluid bleeding!!! Link to post Share on other sites More sharing options...
v2d Clutched November 27, 2018 Author Share November 27, 2018 #Volkswagen #GolfR Back for #MST intake upgrades !!!! PRO-JEX V2D We specialize in the following : •24 hour breakdown recovery & Towing services.•Accident recovery•Motor Insurance (New / Renewal)•Motor Vehicle Inspection and Valuation•COE renewal•Vehicle Maintenance and ECU Diagnostic (DTC)•Engine Performance Tuning•Fuel-Saving Enhancements•Furnishing of Original / OEM Parts•Diagnostic Services Mercedes Benz C180 Coupe back for air con system rebuild!!! Honda Accord EuroR CL7R back for BC BR COILOVERS upgrades !!! Link to post Share on other sites More sharing options...
v2d Clutched January 8, 2019 Author Share January 8, 2019 We are the STAR MERCHANT for Air Conditioning Category 2019! PROMOTION:Intake manifold & throttle body servicing @$50. Tested and proven on cars, bikes and boats running on carburetor or fuel injection. http://m.facebook.com/v2d.com.sg You will experience e following after this procedure : 1- Easier start up. 2- Very light throttle response. 3- Fuel efficient.4- Engine vibration will be minimized. Pls call us @+6586687676Website: www.v2d.com.sgFB Page: http://m.facebook.com/v2d.com.sg Preparations for tougher inspection standards for Motor vehicles and Bikes !!! It's here @PRO-JEX V2D #NEUTO is the world first patented Smart Hydrogen Dry Cleaning System that can effectively DIAGNOSE, PRESCRIBE, MONITOR and CLEAN the car engine with pure and dry Hydrogen Gas stored in the Solid State Metal Hydride Canister. It is exclusively invented for vehicles running on Internal Combustion Engines. NEUTO DRY HYDROGEN AUTO-THERAPY is the cleaning service and treatment provided by NEUTO system. Dry Hydrogen Auto-Therapy removes stubborn micro molecular carbon layers at hard to reach places like air manifolds, piston rings, valves, and spark plugs without causing any damage to the car engine wall and components in the engine. NEUTO Dry Hydrogen Auto Therapy can naturally cleanse the car engine in the most sustainable organic way. Link to post Share on other sites More sharing options...
v2d Clutched May 16, 2019 Author Share May 16, 2019 High Power Ignition Coils Ready stocks for Mitsubishi Lancer Cs3!!! @ Pro-Jex V2D PRO-JEX V2DWe specialize in the following :•24 hour breakdown recovery & Towing services.•Accident recovery•Motor Insurance (New / Renewal)•Motor Vehicle Inspection and Valuation•COE renewal•Vehicle Maintenance and ECU Diagnostic (DTC)•Engine Performance Tuning•Fuel-Saving Enhancements•Furnishing of Original / OEM Parts•Diagnostic Services Do not hesitate to get us at our hotline : 61007676 / 86687676.Synergy @ KB No 25 Kaki Bukit Road 4 #03-93 / #03-94. S417800. Link to post Share on other sites More sharing options...
v2d Clutched May 17, 2019 Author Share May 17, 2019 Hello everybody !!! TEAM V2D is organizing another track day on 30 June 2019.(Sunday)!!! MIMC track (Melaka) Please WA us@ 96381098. Estimated cost for the track is $150 per participation while for spectator is $50 per person. Food and drinks will be cater for during the event. The objective for organizing this track day is for us to learn and share pointers on how to handle our rides, handle the power of our rides and how to react during taking corners and any unforeseen circumstances! If you still need anymore information, fee free to contact us! Thank you. Please reserve ASAP. As we need 30 participation. Link to post Share on other sites More sharing options...
v2d Clutched June 3, 2019 Author Share June 3, 2019 Fast cut in cut out for the fans !!! Better operating temperature in our hot tropical climate!!! https://www.facebook.com/v2d.com.sg/videos/470739063685340/ Link to post Share on other sites More sharing options...
v2d Clutched June 10, 2019 Author Share June 10, 2019 PROMOTION: Intake manifold & throttle body servicing @$50.Tested and proven on cars, bikes and boats running on carburetor or fuel injection. https://www.facebook.com/v2d.com.sg/videos/810836445968034/ You will experience e following after this procedure : 1- Easier start up.2- Very light throttle response.3- Fuel efficient.4- Engine vibration will be minimized. Pls call us @+6586687676 http://wa.me/6586687676 Website: http://www.v2d.com.sgFB Page: http://m.facebook.com/v2d.com.sg Link to post Share on other sites More sharing options...
v2d Clutched June 14, 2019 Author Share June 14, 2019 High Power Lgnition Coils installed on Mitsubishi Lancer CS3 1.6A #HighPowerIgnitionCoils installed on #Mitsubishi #Lancer #Cs3 1.6Auto. Link to post Share on other sites More sharing options...
v2d Clutched June 26, 2019 Author Share June 26, 2019 Suzuki Swift back for undercarriage and air con system rebuild!!! Link to post Share on other sites More sharing options...
v2d Clutched July 3, 2019 Author Share July 3, 2019 3 in 1 ServicePackage ThrottleFlush AcNanoMist Pls call us @+6586687676 http://wa.me/6586687676 Website: www.v2d.com.sg FB Page: http://m.facebook.com/v2d.com.sg Link to post Share on other sites More sharing options...
v2d Clutched July 15, 2019 Author Share July 15, 2019 High Power Ignition Coils and Sadr Fuel Regulator installed on Mitsubishi Lancer Cs3!!! Please call us @+6586687676 http://wa.me/6586687676 Website: www.v2d.com.sg FB Page: http://m.facebook.com/v2d.com.sg Link to post Share on other sites More sharing options...
v2d Clutched July 25, 2019 Author Share July 25, 2019 Restore Horsepower with Liqui Moly Catalytic System Cleaner! BMW E46 in for Liqui Moly engine tune-up!!! https://www.facebook.com/vincent.chua.5/videos/10220122549363621/ Please call us @+6586687676http://wa.me/6586687676Website: www.v2d.com.sgFB Page: http://m.facebook.com/v2d.com.sg Link to post Share on other sites More sharing options...
v2d Clutched August 27, 2019 Author Share August 27, 2019 BMW M5 back for full undercarriage rebuild!!! KWcoilovers Please call us @+6586687676http://wa.me/6586687676Website: www.v2d.com.sgFB Page: http://m.facebook.com/v2d.com.sg Link to post Share on other sites More sharing options...
v2d Clutched September 17, 2019 Author Share September 17, 2019 (edited) Honda Fit back for full servicing and rebuild!!! Handling improvement upgrades in progress!!! Please call us @+6586687676http://wa.me/6586687676Website: www.v2d.com.sgFB Page: http://m.facebook.com/v2d.com.sg Edited September 17, 2019 by v2d Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
Car repair and maintenance
Servicing at Tan Chong
Used Mercedes buyer spends $40,000 on repairs
Is Tan Chong Servicing Package NPMP value for money?
Grinding racket
Grinding racket
