FXT May 20, 2016 Share May 20, 2016 The water droplet is normal lah. It is at a corner that the cloth cannot reach when drying the car. But is still outside. It will dry by itself. As for when you let go the brake, it is also normal. My previous car also same. This can help to prevent the car from rolling back. As for reverse, it seems the programme to be at a very slow for safety reason. After googling water droplets in Subaru BRZ taillights, I guess the water droplets I see on my car are normal I read somewhere that the handbrake applies a backup drum brake (separate from the disc brake) on the rear wheels. So it's normal for AWD car to continue moving forward in D, on level ground, even with handbrake up 2 clicks without foot on accelerator? My previous FWD Toyota MPV wouldn't move with handbrake applied ↡ Advertisement Link to post Share on other sites More sharing options...
Sarion 4th Gear May 20, 2016 Share May 20, 2016 I read somewhere that the handbrake applies a backup drum brake (separate from the disc brake) on the rear wheels. So it's normal for AWD car to continue moving forward in D, on level ground, even with handbrake up 2 clicks without foot on accelerator? My previous FWD Toyota MPV wouldn't move with handbrake applied c'mon, you have over 200bhp in FXT and why would you think the drum brake pads will hold when gear is in 'D'? shouldn't it be in N or P? the drum brake pads are meant to last almost forever, which also means they wear very slowly and doesn't grip that well. I have driven my previous car all the way up multi-storey carpark and parked, after dropping off family at drop-off point, then realized handbrake was on. and that was only 170bhp car. 2 Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear May 21, 2016 Share May 21, 2016 Not really patches/spots on the exterior black plastic. It's more like white streaks, somewhat like abrasion. Very unlikely that I unknowingly hit something though. Cause the white streaks are at different places on the rear bumper. I tried using armorall protectant gel. Didn't work. I'll see whether MI can get this fixed when they check the brakes at the same time. Try getting this from Stamford tyres or autobacs. in the long run, it's inevitable that black plastic parts will dull http://www.amazon.com/Meguiars-G15812-Ultimate-Plastic-Restorer/dp/B0055PD1H4 Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear May 21, 2016 Share May 21, 2016 After googling water droplets in Subaru BRZ taillights, I guess the water droplets I see on my car are normal I read somewhere that the handbrake applies a backup drum brake (separate from the disc brake) on the rear wheels. So it's normal for AWD car to continue moving forward in D, on level ground, even with handbrake up 2 clicks without foot on accelerator? My previous FWD Toyota MPV wouldn't move with handbrake applied Why do you keep mentioning 2 clicks? When you pull handbrake, you should lift it up with reasonable strength and distance rather than counting the number of clicks. If you need to pull the handbrake very high for it to be effective, MI can adjust it for you to be lower. And why are you in D gear when your handbrake is on? Shouldn't you be in P gear? 1 Link to post Share on other sites More sharing options...
FXT May 21, 2016 Share May 21, 2016 Thanks for the replies. Will try out the meguiars plastic restorer. I applied the handbrake while waiting for traffic light when I noticed the car would still move forward. So I guess it's normal. I still have problems with the squeaking brakes though. Will need to get that checked. And has anyone else noticed the reverse speed is different sometimes? Not sure if it's a problem but it's definitely strange 1 Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear May 21, 2016 Share May 21, 2016 Thanks for the replies. Will try out the meguiars plastic restorer. I applied the handbrake while waiting for traffic light when I noticed the car would still move forward. So I guess it's normal. I still have problems with the squeaking brakes though. Will need to get that checked. And has anyone else noticed the reverse speed is different sometimes? Not sure if it's a problem but it's definitely strange At cold starts, the engine RPM will be higher so the engine may coast slightly faster without you stepping on the accelerator. But u seem to experience the other way round: car reverses faster at cold starts... Seriously, this is really something weird to be concerned with... Uneven ground, steering angle, throttle input could affect your reverse speed. And the speedometer won't be accurate at such low speeds and short distance. Pls Pay attention to your surroundings rather than noticing any difference in reverse speed, in case you ram into something or even someone... Drive safe Link to post Share on other sites More sharing options...
Aviator2016 Clutched May 21, 2016 Share May 21, 2016 Hi, have been considering Forester NA for awhile. Apart from the price quoted, what are the common items to ask or can be expected from SE? So far been quoted 3 free servicing 1k, 5k, 10k and floor mats. Link to post Share on other sites More sharing options...
Icecube187 2nd Gear May 21, 2016 Share May 21, 2016 Hi, have been considering Forester NA for awhile. Apart from the price quoted, what are the common items to ask or can be expected from SE? So far been quoted 3 free servicing 1k, 5k, 10k and floor mats. Front + rear blackvue cameraFront sensors 20,30,40k (2yr) servicing package 1,5,10k is not considered a freebie. Forget abt the car mats, cheap stuff buy yourself. 1 Link to post Share on other sites More sharing options...
Hoseyboh Twincharged May 22, 2016 Share May 22, 2016 Hi all Newbie here, just to share. Booked a XT yesterday at $120K. MI clearing stocks n need to hit target. All colours available except white. Thanks 2 Link to post Share on other sites More sharing options...
Tunge 1st Gear May 22, 2016 Share May 22, 2016 Front + rear blackvue camera Front sensors 20,30,40k (2yr) servicing package 1,5,10k is not considered a freebie. Forget abt the car mats, cheap stuff buy yourself. Are all these what u managedto get fr ur SE? Or u mean these are the usual freebies to ask for but my or may not get 1 Link to post Share on other sites More sharing options...
Rayleigh 6th Gear May 22, 2016 Share May 22, 2016 Hi all Newbie here, just to share. Booked a XT yesterday at $120K. MI clearing stocks n need to hit target. All colours available except white. Thanks Very good price. Link to post Share on other sites More sharing options...
Tohto Hypersonic May 22, 2016 Share May 22, 2016 Are all these what u managedto get fr ur SE? Or u mean these are the usual freebies to ask for but my or may not get MI are very stingy, so don't expect to get much from the all the SE. 1 Link to post Share on other sites More sharing options...
Hoseyboh Twincharged May 22, 2016 Share May 22, 2016 Very good price. Sorry, to be precise it's $120.6. Didn't read the Agreement properly. Link to post Share on other sites More sharing options...
Friendstar Supercharged May 22, 2016 Share May 22, 2016 Sorry, to be precise it's $120.6. Didn't read the Agreement properly.Aiyo. 600 only. 120.6 still a very good price! Link to post Share on other sites More sharing options...
wongexcel 1st Gear May 22, 2016 Share May 22, 2016 Today zaobao 1 Link to post Share on other sites More sharing options...
mrhan1982 4th Gear May 22, 2016 Share May 22, 2016 Hi all Newbie here, just to share. Booked a XT yesterday at $120K. MI clearing stocks n need to hit target. All colours available except white. Thanks Wa... I booked a red FL (last colour of ex-stock) a few weeks earlier than u but paid 123k (price including change leather seats to brown colour)...Zzzz.. Now their new stocks come with all colours so fast. They are getting aggressive. MI is a silent killer try to conquer more of the suv market here. Btw, any freebies u got from your SE besides the free carmat and first 3 servicings? I only got these. MI not so into giving freebies but they try to give us a no frills deal. I'm still waiting to collect mine this coming fri or sat. Good to see there will be more and more xt out on the roads. Today zaobao Looks like the XT is gaining more attention in Spore. its off-roading capabilities will be well appreciated even in our local roads. In recent years, I feel that our road conditions have become much worse than before: more pot holes, uneven patching (after digging), road works here and there, and more speed humps. My current sylphy suspension is taking quite a hit with all these road imperfections. I'm starting to hear creaking sounds from the rear suspension after 24k km.... Not sure if any bros out there are feeling the same punishments to your rides? Link to post Share on other sites More sharing options...
Swaku 1st Gear May 22, 2016 Share May 22, 2016 Wa... I booked a red FL (last colour of ex-stock) a few weeks earlier than u but paid 123k (price including change leather seats to brown colour)...Zzzz.. Now their new stocks come with all colours so fast. They are getting aggressive. MI is a silent killer try to conquer more of the suv market here. Btw, any freebies u got from your SE besides the free carmat and first 3 servicings? I only got these. MI not so into giving freebies but they try to give us a no frills deal. I'm still waiting to collect mine this coming fri or sat. Good to see there will be more and more xt out on the roads. Looks like the XT is gaining more attention in Spore. its off-roading capabilities will be well appreciated even in our local roads. In recent years, I feel that our road conditions have become much worse than before: more pot holes, uneven patching (after digging), road works here and there, and more speed humps. My current sylphy suspension is taking quite a hit with all these road imperfections. I'm starting to hear creaking sounds from the rear suspension after 24k km.... Not sure if any bros out there are feeling the same punishments to your rides? I agree the road conditions sucks these days. Many road works and they last for a long time too. That's the reason why I took out my coilover from my current car as I also buay tahan too. Looking forward to collecting the new car soon. My wife told me "No more lowering car ok!". Ha.. Link to post Share on other sites More sharing options...
Hoseyboh Twincharged May 22, 2016 Share May 22, 2016 Want more freebies, take long high loan can liao. The reason I got dis price cause my friend also booked a XV together lah... ↡ Advertisement Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
Hyundai Sonata (2015)
New Subaru XV
New Subaru XV
2015 Mazda CX3
2015 Mazda CX3
2016 / 2017 Subaru Impreza
