richard_crl032 6th Gear August 4, 2021 Share August 4, 2021 9 minutes ago, Egg6 said: @richard_crl032 Hi Richard, Can PM me price for the package? approaching 96k mileage soon. TIA. Done 🙏 ↡ Advertisement Link to post Share on other sites More sharing options...
Sunshines11 1st Gear August 6, 2021 Share August 6, 2021 @thefalcon Thks!! 🙂 Link to post Share on other sites More sharing options...
Meepok Neutral Newbie September 14, 2021 Share September 14, 2021 Hello. I'm driving a FNA and it has been a good ride so far but recently the aircon is not cold (with hissing sound). Suspected this is due to the common condenser leak. However, my car warranty is over by over a few months (Jun 2021) and the service advisory from MI told me that they won't cover it as the warranty period is over. I'm quite disappointed with that as this is a known issue and in some countries, they actually did a recall. I was so angry when I told the SA about this and he said the condenser issue is not a known issue and keep repeating the warranty is over. I decided to bring my car to workshop and will likely replace the condenser if it is leaking. Question here is what is the reason of leaking condenser? Never have this issue from my previous car for just over 3 years. Is it due to the stock condenser? Should I go for a aftermarket condenser or change back to the original condenser? Would love to hear from the Forester buddies here. Many thanks. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 15, 2021 Share September 15, 2021 11 hours ago, Meepok said: Hello. I'm driving a FNA and it has been a good ride so far but recently the aircon is not cold (with hissing sound). Suspected this is due to the common condenser leak. However, my car warranty is over by over a few months (Jun 2021) and the service advisory from MI told me that they won't cover it as the warranty period is over. I'm quite disappointed with that as this is a known issue and in some countries, they actually did a recall. I was so angry when I told the SA about this and he said the condenser issue is not a known issue and keep repeating the warranty is over. I decided to bring my car to workshop and will likely replace the condenser if it is leaking. Question here is what is the reason of leaking condenser? Never have this issue from my previous car for just over 3 years. Is it due to the stock condenser? Should I go for a aftermarket condenser or change back to the original condenser? Would love to hear from the Forester buddies here. Many thanks. Leaking because of the quality. Even you change in MI, they will use back the same part and likely will fail again after a few years. I've changed mine outside and they have used another brand. You can confirm that first before deciding to proceed or not. Link to post Share on other sites More sharing options...
Meepok Neutral Newbie September 15, 2021 Share September 15, 2021 1 hour ago, Stratovarius said: Leaking because of the quality. Even you change in MI, they will use back the same part and likely will fail again after a few years. I've changed mine outside and they have used another brand. You can confirm that first before deciding to proceed or not. @Stratovarius Thanks for the reply. What brand did you changed? KoyoAir? Do you mind sharing the price? Link to post Share on other sites More sharing options...
cmdsea 3rd Gear September 15, 2021 Share September 15, 2021 @Stratovarius Exactly my experience.! My work colleague and I are both driving FNA. Mine is 2016 and his 2017. Mine was out of warranty so I took it to an outside workshop. He gave me a choice of a replacement OEM coil or a Taiwanese coil for $100 cheaper. When I asked him which he would use if it was his own car without hesitation he said the Taiwanese one was cheaper and better. and I replaced it with a different brand. Now coming to 6 years and touch wood no more problems. For my colleague, within 2 years his condenser coil also spoilt and MI replaced it FOC under warranty, but with same original lousy quality OEM coil. Last week, after another two years the same problem has occurred and he has just replaced it at the same workshop I used. Cost was $620 2 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 15, 2021 Share September 15, 2021 1 hour ago, Meepok said: @Stratovarius Thanks for the reply. What brand did you changed? KoyoAir? Do you mind sharing the price? Ya. i think is koyoair. Cant remember the exact price but is around 400plus. But @cmdsea changed at 620, so i cant be sure. I only changed the condenser. The ws owner was proposing to change out the coils too to be sure but i only proceed with the condenser since its already leaking. Link to post Share on other sites More sharing options...
Meepok Neutral Newbie September 15, 2021 Share September 15, 2021 11 minutes ago, cmdsea said: @Stratovarius Exactly my experience.! My work colleague and I are both driving FNA. Mine is 2016 and his 2017. Mine was out of warranty so I took it to an outside workshop. He gave me a choice of a replacement OEM coil or a Taiwanese coil for $100 cheaper. When I asked him which he would use if it was his own car without hesitation he said the Taiwanese one was cheaper and better. and I replaced it with a different brand. Now coming to 6 years and touch wood no more problems. For my colleague, within 2 years his condenser coil also spoilt and MI replaced it FOC under warranty, but with same original lousy quality OEM coil. Last week, after another two years the same problem has occurred and he has just replaced it at the same workshop I used. Cost was $620 Thanks for sharing the cost. I wonder what the brand of the stock condenser and if it has the same issue in other car make. Link to post Share on other sites More sharing options...
Meepok Neutral Newbie September 15, 2021 Share September 15, 2021 6 minutes ago, Stratovarius said: Ya. i think is koyoair. Cant remember the exact price but is around 400plus. But @cmdsea changed at 620, so i cant be sure. I only changed the condenser. The ws owner was proposing to change out the coils too to be sure but i only proceed with the condenser since its already leaking. My understanding is condenser is the coil; do you meant compressor? Link to post Share on other sites More sharing options...
Rayleigh 6th Gear September 15, 2021 Share September 15, 2021 Hissing sound should be coming from the compressor. Correct? Link to post Share on other sites More sharing options...
Stratovarius Turbocharged September 15, 2021 Share September 15, 2021 6 minutes ago, Meepok said: My understanding is condenser is the coil; do you meant compressor? My understanding from the ws is if ac not cold, can be either the cooling coil or the condenser leak, or both. i guess u know where is the condenser. For the cooling coil, i think is located near the front passenger side of the front dash. Cooling coil very hard to see w/o dismantling things. So if you see the condenser is already leaking, change that first. If your ac is not cold and condenser is not leaking, then it is likely the coil needs to be changed. https://www.carousell.sg/p/subaru-impreza-gh-aircon-cooling-coil-replacement-1015477977/ 1 Link to post Share on other sites More sharing options...
Tohto Hypersonic September 15, 2021 Share September 15, 2021 27 minutes ago, Meepok said: My understanding is condenser is the coil; do you meant compressor? Condensor is located in the front of the car, behind the grill. Cooling cool is behind the glove compartment. 2 different parts. The compressor is in front of the engine. Total 3 parts for the aircon system. 2 Link to post Share on other sites More sharing options...
Meepok Neutral Newbie September 15, 2021 Share September 15, 2021 3 minutes ago, Stratovarius said: My understanding from the ws is if ac not cold, can be either the cooling coil or the condenser leak, or both. i guess u know where is the condenser. For the cooling coil, i think is located near the front passenger side of the front dash. Cooling coil very hard to see w/o dismantling things. So if you see the condenser is already leaking, change that first. If your ac is not cold and condenser is not leaking, then it is likely the coil needs to be changed. https://www.carousell.sg/p/subaru-impreza-gh-aircon-cooling-coil-replacement-1015477977/ I see. Quick search shows https://www.preciseauto.sg/blog/13/7/2016/replacement-of-cooling-coil-in-the-air-con-system Just like what you described. 1 Link to post Share on other sites More sharing options...
shutterbox 3rd Gear September 17, 2021 Share September 17, 2021 received this from MI any good for a 55k mileage SJG? Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 17, 2021 Share September 17, 2021 Buy Liqui moly brand and pour yourself. How difficult can it be. 3 Link to post Share on other sites More sharing options...
Tohto Hypersonic September 18, 2021 Share September 18, 2021 On 9/17/2021 at 10:25 AM, shutterbox said: received this from MI any good for a 55k mileage SJG? Save your money from sale push by them lah. Link to post Share on other sites More sharing options...
Orixy 2nd Gear September 22, 2021 Share September 22, 2021 Thanks to the recommendations and feedback from the various bros here especially Richard, i just got my FXT a set of Tein EnduroPro Plus with STI pink springs. Got them installed by bms in under 1.5hrs and aligned by Kenny. The drive now is noticeably more planted yet more comfortable than the stock setup it replaced. The bumps from road imperfections are now so nicely evened out and i feel that FXT should have been setup this way from the beginning! Even carpark humps become less intrusive than stock, which came a a nice surprise given the slightly lowered stance with the pink springs. Bends and corners are also easier to judge and handle during the turning. Overall a good investment for my daily driven. The stock shocks and springs are also holding well given 75k km mileage, so if anyone is dekitting and wants to buy stock shocks and springs do PM me 🙂 3 Link to post Share on other sites More sharing options...
Bplakad 1st Gear September 22, 2021 Share September 22, 2021 @Orixy Can I have Kenny's contact for wheel alignment please. ↡ Advertisement Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
Hyundai Sonata (2015)
New Subaru XV
New Subaru XV
2015 Mazda CX3
2015 Mazda CX3
2016 / 2017 Subaru Impreza
