Detach8 5th Gear May 8, 2015 Share May 8, 2015 It seems a lot of people here don't know how to drive around a roundabout. Almost kena hit by a cockernarden at International Business Park, and the joker still think it's his right of way. Let me set this straight: If you are in the LEFT lane, you are supposed to exit at the immediate next exit or go straight (depend on the number of the entry lanes and roundabout lanes). These rules are INTERNATIONALLY KNOWN. There's no special rule for Singapore. When a driver sees a car in the LEFT lane passing 2 exits, it is assumed he is clear to come into the roundabout with the knowledge that the other driver will be exiting. AND... signal your intent to exit the roundabout (left signal) or continue going around (right signal). Same rules actually apply for the roundabout at Suntec but most drivers here are too cock so it's seems to be a unspoken rule to change lane to the left before you exit. ↡ Advertisement 7 Link to post Share on other sites More sharing options...
shrjun 5th Gear May 9, 2015 Share May 9, 2015 duly noted :) Link to post Share on other sites More sharing options...
Optramagnum 6th Gear May 9, 2015 Share May 9, 2015 On 5/8/2015 at 6:37 PM, Detach8 said: It seems a lot of people here don't know how to drive around a roundabout. Almost kena hit by a cockernarden at International Business Park, and the joker still think it's his right of way. Let me set this straight: If you are in the LEFT lane, you are supposed to exit at the immediate next exit or go straight (depend on the number of the entry lanes and roundabout lanes). These rules are INTERNATIONALLY KNOWN. There's no special rule for Singapore. When a driver sees a car in the LEFT lane passing 2 exits, it is assumed he is clear to come into the roundabout with the knowledge that the other driver will be exiting. AND... signal your intent to exit the roundabout (left signal) or continue going around (right signal). Same rules actually apply for the roundabout at Suntec but most drivers here are too cock so it's seems to be a unspoken rule to change lane to the left before you exit. Good reminder, but we dun need a scolding here. Please mind your tone, Saint. 2 Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 9, 2015 Share May 9, 2015 On 5/8/2015 at 6:37 PM, Detach8 said: Let me set this straight: If you are in the LEFT lane, you are supposed to exit at the immediate next exit or go straight (depend on the number of the entry lanes and roundabout lanes). These rules are INTERNATIONALLY KNOWN. There's no special rule for Singapore. what if the exit is with 2 lanes and you are on the left lane, would you still go straight? 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 9, 2015 Share May 9, 2015 Having said that (international rule), Singapore's roundabout can be very special.... with traffic lights. 2 Link to post Share on other sites More sharing options...
Beregond Supersonic May 9, 2015 Share May 9, 2015 i use the pinoeer round about at pinoeer road north below AYE every day , 2 lane go in, there is no lane marking dotted or any thing inside if u go in from the left lane u become on the outside, basically u can chose to exit any exit u want if any car go in from the right lane , u become inside, and u want to exit left, and it happen the vehicle on your left chose to go ahead, well u need to slow down signal left and filter out, thats how i see it lol 1 Link to post Share on other sites More sharing options...
Pinobii Hypersonic May 9, 2015 Share May 9, 2015 Another tricky and crowded roundabout is Tuas exit It has 3 lanes for queuing but actually only have space for 2 cars to drive around it If you use it everyday, think it should be ok coz you will definitely be vigilant and the key is give way when needed Maybe in your case, that's a newbie to that place and not sure how to drive on the roundabout On normal turnings, sometimes lane formation also not correct, the roundabout is even more complicated especially for first timers 1 Link to post Share on other sites More sharing options...
serenade 6th Gear May 9, 2015 Share May 9, 2015 Once we are on the left-most lane (car 1) , we must exit roundabout at the next exit. The car on the inner lane (car 2) wil filter to the left-most lane before the next exit to leave the roundabout. Assuming that car 1 on the left-most lane did not exit as he was supposed to, and continues travelling on the same lane, while car 2 is exiting. There will be a collision. If we take Newton Circus as an example (at a time without traffic lights). A car coming from Clemenceau Avenue on the left most lane is supposed to exit at next exit which is Scotts Road. A car already on the roundabout 2nd lane can also exit from 2nd lane into Scotts Road at the same time as long as car 1 follows this rule as Scotts Road has multi lanes. 3 Link to post Share on other sites More sharing options...
Toothiewabbit Supersonic May 9, 2015 Share May 9, 2015 Many hairy moments at the 3 roundabouts located at Sports Hub. Just because there are not many vehicles in area, I observed many did not bother slow down before the stopline before entering the roundabouts. 4 Link to post Share on other sites More sharing options...
Detach8 5th Gear May 9, 2015 Author Share May 9, 2015 Simple example. In a two lane entry/exit roundabout with 4 exits (12, 3, 6, 9 o'clock) going clockwise. The inner lane (right lane) car can go straight, i.e enter 6 o'clock and exit 12 o'clock. If you are on the outer lane (left lane) and enter at 6 o'clock, it is a MUST to exit at 12 otherwise you will collide with cars from the inner lane exiting at 12! There is no need for cars in the inner lane to filter left before exiting, although signalling is highly recommended as a form of courtesy. If you are in the outer (left) lane, enter at 6 o'clock, but intend to go to 3 o'clock, then you MUST filter into the inner (right) lane. I think these information are easily available via Google, so there's no need to explain too much here... please Google if unsure/curious. I don't mean to give a lecture but this is not the first time I almost got hit. In other countries people simply just drive through roundabouts but here it's always a mayhem of lane changing, lane straddling (driving in between two lanes) and improper signaling. Somemore the guy who almost hit me had a MCF decal. Link to post Share on other sites More sharing options...
Beregond Supersonic May 9, 2015 Share May 9, 2015 the most hairly 1 i came across is the jin buroh, jurong pier flyover that 1. if u first timer and kenna peak hour, will have nightmare Link to post Share on other sites More sharing options...
Detach8 5th Gear May 9, 2015 Author Share May 9, 2015 http://www.highwaycode.info/images/hc_rule_185_follow_the_correct_procedure_at_roundabouts.jpg This is pretty clear. Link to post Share on other sites More sharing options...
Tigerwoods Turbocharged May 9, 2015 Share May 9, 2015 thanks Spore roads started to have the roundabout after it almost vanished 20 yrs ago. Almost all drivers forgotten the rules. I also had a near accident at the Staduim area. I observed every single driver there, all CMI. 2 Link to post Share on other sites More sharing options...
Beregond Supersonic May 9, 2015 Share May 9, 2015 (edited) On 5/9/2015 at 6:31 AM, Detach8 said: http://www.highwaycode.info/images/hc_rule_185_follow_the_correct_procedure_at_roundabouts.jpg This is pretty clear. but u see the blue car didnt turn left at the first or 9 clock exit, instead it show it go straight and exit at 12. if the green car want to exit at 9 ? how lol Edited May 9, 2015 by Beregond Link to post Share on other sites More sharing options...
BobbyTan_74287 4th Gear May 9, 2015 Share May 9, 2015 On 5/8/2015 at 6:37 PM, Detach8 said: It seems a lot of people here don't know how to drive around a roundabout. Almost kena hit by a cockernarden at International Business Park, and the joker still think it's his right of way. Let me set this straight: If you are in the LEFT lane, you are supposed to exit at the immediate next exit or go straight (depend on the number of the entry lanes and roundabout lanes). These rules are INTERNATIONALLY KNOWN. There's no special rule for Singapore. When a driver sees a car in the LEFT lane passing 2 exits, it is assumed he is clear to come into the roundabout with the knowledge that the other driver will be exiting. AND... signal your intent to exit the roundabout (left signal) or continue going around (right signal). Same rules actually apply for the roundabout at Suntec but most drivers here are too cock so it's seems to be a unspoken rule to change lane to the left before you exit. Actually there is only one rule - always give way to the right vehicle. 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 9, 2015 Share May 9, 2015 On 5/9/2015 at 5:01 AM, Beregond said: i use the pinoeer round about at pinoeer road north below AYE every day , 2 lane go in, there is no lane marking dotted or any thing inside if u go in from the left lane u become on the outside, basically u can chose to exit any exit u want if any car go in from the right lane , u become inside, and u want to exit left, and it happen the vehicle on your left chose to go ahead, well u need to slow down signal left and filter out, thats how i see it lol i would disagree there if its a exit with 2 lanes. The vehicle on the left MUST exit and should not go ahead. Left and right car can exit simultaneously. 1 Link to post Share on other sites More sharing options...
Pinobii Hypersonic May 9, 2015 Share May 9, 2015 I don't mean more than just sharing what I see daily and of coz we should follow the rules This is what I see every morning Enter at 6 o'clock Cars on 3 lanes move and slowly filter to become 2 lanes on the basis of give and take Cars on left lane will signal left but will almost never exit at 12 o'clock, they will exit at 3 o'clock on the left lane The cars on right lane will also exit at 3 o'clock but on the right lane If you know the Tuas exit roundabout well, please share, thanks! Link to post Share on other sites More sharing options...
1fast1 Supersonic May 10, 2015 Share May 10, 2015 (edited) In principle, @Detach8 is correct. There is an internationally-recognised way to navigate a roundabout. However, in practice, local customs often override international convention. In Singapore, the problem is that drivers are often arseholes. They don't give way, in fact they're often intent on blocking others as if their very lives depended on it. Hence, a driver in the appropriate middle or inner lane of a roundabout has no confidence about being able to filter into the exiting lane when he needs to. When there is no etiquette, the system breaks down. There is no sense in haranguing "CMI" drivers about their lack of theoretical know-how when the issue is a very practical one to do with local attitudes. And this sort of thing is hardly unique to Singapore; in fact we're not even the only developed nation to "not know" how to drive on roundabouts. Just look at Paris' Arc de Triomphe. http://youtu.be/-2RCPpdmSVg Now, after viewing that video, don't you think driving along Newton Circus (or *any* other roundabout here) is far more civilised? While we just have organised chaos, the French have decidedly disorganised chaos. Perhaps the root cause is the same - the French are known for having a disproportionately large number of arseholes too, just less repressed ones than in Singapore. Edited May 10, 2015 by Turboflat4 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
New 2015 Toyota Alphard and Vellfire
2026 8th Generation Lexus ES
Lee Sheng Auto - One Stop Auto Repair Centre! From accident repair & claims, spray painting, diagnostics, general repairs to servicing.
Toyota Corolla Cross
