ER-3682 Supersonic May 17, 2016 Share May 17, 2016 I have been using the i-Stop in my Mazda 6 for the past over 3 Years,clocked a total of 185 hours of "stop" time,the only down point is it needs a very expensive battery & rather short life[18 months]. ↡ Advertisement Link to post Share on other sites More sharing options...
Hoonigan 1st Gear May 17, 2016 Share May 17, 2016 I'm making a smart guess that the piston is somewhere over the TDC of the stroke. So the piston is about to be released downwards as soon as it is fired. Why it didn't had enough force to push it all the way down ? Well, another smart guess from me is that the other cylinder that would be pushed up to compress its own compartment would set an equilibrium such that it didn't allow it to push all the way down, despite the air and fuel mixture is already in compression. Well, might not be correct. But you guys interested may look for Uncle Google for answer. But my idea makes sense. Link to post Share on other sites More sharing options...
Check13 3rd Gear May 25, 2016 Share May 25, 2016 totally turn off by the A S S or auto start stop. u cant save much especially if u r on diesel which is already so cheap. it's more a marketing and over glorified function. Link to post Share on other sites More sharing options...
Watwheels Supersonic May 25, 2016 Share May 25, 2016 totally turn off by the A S S or auto start stop. u cant save much especially if u r on diesel which is already so cheap. it's more a marketing and over glorified function. It's a useful function for the car makers that's for sure. This is how they pass the CO2 emission test. In city driving the idling engine at red lights produce more unburnt fuel, more CO2 and more toxic gases. Hence shutting down the engine at idle stop the production of harmful gases and save fuel. Traditionally city driving mpg or emssion figures score badly but with the start-stop system the figures improve a lot. It looks a lot better on paper. It's strictly beneficial to the car makers. Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 25, 2016 Share May 25, 2016 Mfg also wanted to do a part to save the Earth. Link to post Share on other sites More sharing options...
K20VTEC 2nd Gear May 26, 2016 Share May 26, 2016 Honda Jap says that their start-stop systems uses the starter motor to restart the engine. However, they have designed the starter motor with the start-stop system in mind. So it's probably a beefed up starter. Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 26, 2016 Share May 26, 2016 (edited) Honda Jap says that their start-stop systems uses the starter motor to restart the engine. However, they have designed the starter motor with the start-stop system in mind. So it's probably a beefed up starter. I wonder Honda needs a 'special' battery for its Start/Stop system.?Mazda needs a "Q85" battery,which is rare & expensive.. Edited May 26, 2016 by ER-3682 1 Link to post Share on other sites More sharing options...
Etnt Turbocharged May 27, 2016 Share May 27, 2016 After using stop-start then realise: Sg traffic really comes to a halt often, whether on highway or small roads. Filter lanes and right turn lanes are nightmares. Local traffic light takes really long to turn green from red Link to post Share on other sites More sharing options...
inlinesix Hypersonic May 27, 2016 Share May 27, 2016 I wonder Honda needs a 'special' battery for its Start/Stop system.?Mazda needs a "Q85" battery,which is rare & expensive.. Most start-stop system requires deep cycle battery. AGM is just 1 type of deep cycle battery. These battery definitely cost more. Link to post Share on other sites More sharing options...
K20VTEC 2nd Gear May 27, 2016 Share May 27, 2016 I wonder Honda needs a 'special' battery for its Start/Stop system.?Mazda needs a "Q85" battery,which is rare & expensive.. Vezel does not. Restarting of engine is done using the electical juice in the capacitor as far as im aware. There is no load on the battery in engine bay during start-stop situations. Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 27, 2016 Share May 27, 2016 Vezel does not. Restarting of engine is done using the electical juice in the capacitor as far as im aware. There is no load on the battery in engine bay during start-stop situations. Not for Mazda,if we use normal battery,the i-Stop won't work. Link to post Share on other sites More sharing options...
K20VTEC 2nd Gear May 29, 2016 Share May 29, 2016 Not for Mazda,if we use normal battery,the i-Stop won't work. But Mazda's i-Stop as far as I recall does not require the use of starter motor to restart the engine right? Honda uses the starter motor Link to post Share on other sites More sharing options...
ER-3682 Supersonic May 29, 2016 Share May 29, 2016 But Mazda's i-Stop as far as I recall does not require the use of starter motor to restart the engine right? Honda uses the starter motor I heard so.....no need starter motor...I rather have a robust starter with a normal battery,Q85 battery is damm difficult to get outside & very expensive. Link to post Share on other sites More sharing options...
Kopites Supersonic May 29, 2016 Share May 29, 2016 Honda Jap says that their start-stop systems uses the starter motor to restart the engine. However, they have designed the starter motor with the start-stop system in mind. So it's probably a beefed up starter.I concur. Morning it take at least two traffic light distance before stop/start can kick in. 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 29, 2016 Share May 29, 2016 I concur. Morning it take at least two traffic light distance before stop/start can kick in.2 traffic lights is quite fast. No Aircon in morning? Doubt the cabin will be cool enough by then or you set the temps high. Link to post Share on other sites More sharing options...
Kopites Supersonic May 30, 2016 Share May 30, 2016 2 traffic lights is quite fast. No Aircon in morning? Doubt the cabin will be cool enough by then or you set the temps high.I set at 25 auto. Morning I prefer cool not cold. Hahaha Honestly not much fuel saving I reckon. Just the fact that this car come with such function so just use it. Otherwise I would have gotten other with minimun electronic gadgets. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged May 30, 2016 Share May 30, 2016 (edited) toyota has one of the better start stop motor .. almost rolls royce quality of start stop. I suppose the electric motor of the prius helps a seamless transition. Jag is a must have in the XE. If you dont invoke the start stop, the vibration into the cabin is like the olden days crown taxi at the traffic lights. Edited May 30, 2016 by Sdf4786k Link to post Share on other sites More sharing options...
K20VTEC 2nd Gear May 30, 2016 Share May 30, 2016 I concur. Morning it take at least two traffic light distance before stop/start can kick in. It depends on a few conditions. If morning your engine is still cold, start stop will not activate, if cabin temp does not meet aircon set temp, start stop will not activate as well. If you current cabin power usage is higher than capacitor juice available, it won't activate as well. If your car is affected by Honda's recall for Vezel, would be recommended for you to turn off start stop till you get the part replaced. toyota has one of the better start stop motor .. almost rolls royce quality of start stop. I suppose the electric motor of the prius helps a seamless transition. Jag is a must have in the XE. If you dont invoke the start stop, the vibration into the cabin is like the olden days crown taxi at the traffic lights. Yes that's true. But I noticed that for Prius, when the juice is low or something, when the car restarts, there is also some vibration to the cabin. What i'm curious about hybrid is lets say when you start your engine in the morning, you use electric power, when you reach your expressway, your car has been using electric power and when you accelerate hard to join the expressway, won't the engine not be up to operating temp? Is the oil pump electrically working the moment you start the engine?? ↡ Advertisement Link to post Share on other sites More sharing options...
Discriminatory practices towards the aged
The 2017 Alfa Romeo Giulia
Man who removed bus stop bench to check its dimensions for f
To be Happy, start thinking about Death!
Stop False Accusation
Why cant i start a new tread in the General discussions?
