RS Chip Tuning
azaouogh
Any consensus on whether really improve FC yet? These chips not cheap, but if it improves FC over long term it might pay for itself
Don't try to justify the cost of the chip by fc savings when all you are after is the improved performance
I met Nick to get my new W205 C180 Monster Tuned. btw its custom tuned not piggy back.
When I roll up the dyno, they measured 170bhp and 275Nm at the Crank, that's 10% higher than the spec given by MB which is 154bhp and 250Nm.
I was told that I'm gonna expect up to 30% of power gain from stock which I thot would be 170bhp as base HAHA. but sadly It's 30% gain from paper.
So end of the tune I gained another 21% to 201bhp & 333Nm at crank!
The Peak torque comes in 200rpm earlier from 2400 rpm to 2200rpm all the way to 4400rpm.
Haven test the 0-100kph. but the turbo lag is still awful and kicks in unpredictably. But somehow I found out that when I half throttle the car, I can get the turbo to kick in then I can proceed to floor. and instance when I floor it at startup the turbo refuses to kick in :(
how can I correct Turbo lag guys?
FC wise I've yet to test. Will update u guys! but somehow the tank lasted me 2/3 days more than usual.
Edited by Stanfordho96
Petrol lasts longer.?Beware of tuning it too "Lean" [:(] ,it can harm the engine [bigcry] ,esp in our hot climate,some tuner just want to show you high HP,don't care how your engine will lasts.
Running lean in SG & in MY is a big no no.  The petrol itself also helps cool & lubricate the engine.
Dont end up FC improve 25%, but engine life decrease by 50%.
  • Praise 4
  On 1/17/2016 at 3:47 PM, Stanfordho96 said:
isit? then only custom tune mod turbo boost??
Yes ..it is the case ..obd plug and play is great but no turbo boost means same same as NA if if your carbis turbo charged.
No sure what you meant by custom tuning ...remapping and reflash of ecu ? No, you can have piggyback thst takes over ecu signal to get to the various tweaked components without reamapping and reflash of ecu ...pls check out racechip ultimate whose distro and mfgr participated in the recent motor show.
lmao that sounds like what a SE will say haha. haha if RSChip dont tweak turbo boost then tweaks AF mixture?
I did Monster tune for my ride, custom reflash
Spoke to rschip uk ..it also tweaks valve timing and transmission timing in addition to AF mix ...actually same like your customised tuning for NA but racechip does also turbo booat which is key but missing
