Enye Hypersonic December 4, 2021 Share December 4, 2021 2 hours ago, Vtim said: this is a fellow Sharan owner on RaceChip, also 7N2 with EA888Gen3 engine, still on stock IS20 Turbo, slight drop on lower rpm but after mid to high of 2k rpm can see gain. Some off the shelve tuning box only intercept the Boost sensor, wic imo will not do much. RaceChip & RSchip intercept 2 sensors, Boost sensor and MAP sensor, so as you can see the chart below there is a gain in both BHP & Torque. For mine Sharan, I using JB4, which will intercept 4 sensors + ODB2 (which can set the max boost level as a safe measure against overboost, once it detected the pre set value, it will prompt the ECU to go into limp mode which will drop the boost level into half of stock value), Boost Sensor + MAP Sensor + CAM position Sensor + O2 sensor. while there is a marked difference with and without piggyback, the absolute torque and hp numbers on the chart look low compared to the stock numbers from factory any explanation of this from the mech running the dyno? ↡ Advertisement Link to post Share on other sites More sharing options...
AdamMoors Clutched June 24, 2022 Share June 24, 2022 @azaouogh I actually used this a few years. I think I bought it at fullcartuning.com. It worked brilliantly for me to be honest. Have also seen it some shops around town though. Link to post Share on other sites More sharing options...
Lycanthrope 4th Gear November 12 Share November 12 has anyone tried Supertuneauto ? ↡ Advertisement Link to post Share on other sites More sharing options...
Music Concerts
Music Concerts
Piano - moving piano
Microsoft’s Majorana 1 chip carves new path for quantum computing
Carpark that only accept cashcard (with chip)
Torque wrench hunt
Torque wrench hunt
2023 Mercedes-AMG C63 S E Performance
