Lktay Clutched October 28, 2022 Share October 28, 2022 @Spidey10 I have problem buying my wipers last time , so I end up buying the wiper refill and change them myself. I brought mine online from Shopee and Ali Express => including delivery is about $ 4~5/pc. It is ok to buy slightly longer and cut to actual length. ↡ Advertisement Link to post Share on other sites More sharing options...
Spidey10 Supercharged October 28, 2022 Share October 28, 2022 1 hour ago, Lktay said: @Spidey10 I have problem buying my wipers last time , so I end up buying the wiper refill and change them myself. I brought mine online from Shopee and Ali Express => including delivery is about $ 4~5/pc. It is ok to buy slightly longer and cut to actual length. yes...must do homework lah before buying on line....know yr wiper size and why not buy something better - Bosch. I bought mine and it fits perfectly....DIY and bang, less than 1 hr work...and is still working well after 3 yrs... My good fren now this Ali and Shopee.. Link to post Share on other sites More sharing options...
Thomascivic86 Clutched June 3, 2023 Share June 3, 2023 Check light came on, error code P2003. Its regarding DPF. Anyone got this error code? How do you fix it? Thanks! Link to post Share on other sites More sharing options...
Limws1 1st Gear July 30, 2023 Share July 30, 2023 @Thomascivic86 Did you resolve the DPF warning light? Mine came on at 130k km. Never came on before. C&C can't resolve the problem. Link to post Share on other sites More sharing options...
Thomascivic86 Clutched July 30, 2023 Share July 30, 2023 Nope. Sold the car this month. Mileage was at ard 140k km plus. Now it appeared in sgcm, magic on mileage. @Limws1 1 Link to post Share on other sites More sharing options...
Limws1 1st Gear July 30, 2023 Share July 30, 2023 @Thomascivic86 Ok thanks. Ha..ha, whoever buy your car is in for a surprise. Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 30, 2023 Share July 30, 2023 On 7/30/2023 at 11:10 PM, Limws1 said: @Thomascivic86 Did you resolve the DPF warning light? Mine came on at 130k km. Never came on before. C&C can't resolve the problem. Hi how can that be? They have their korean manufacutrer engineering to support them, they can jutst call or email them? should be able to solve it. Link to post Share on other sites More sharing options...
Limws1 1st Gear July 31, 2023 Share July 31, 2023 @Ct3833 Visited C&C twice, they can't solve as long as there is no error code found. I always think that there are no good car mechanics in Singapore. C&C proves me right. Now my car regenerate too often and when it regenerates, the vibration is so bad it shake my teeth. Link to post Share on other sites More sharing options...
Fazer66 1st Gear August 23, 2023 Share August 23, 2023 anyone experiencing fuel leaking when pump full tank ? Link to post Share on other sites More sharing options...
teomingern 6th Gear August 23, 2023 Share August 23, 2023 Seriously fuel leaking? Meaning you see fuel dripping from somewhere in the fuel line or fuel tank onto the ground from the car as you pump? Link to post Share on other sites More sharing options...
Fazer66 1st Gear August 24, 2023 Share August 24, 2023 fuel tank onto the ground but is only when I pump full tank Link to post Share on other sites More sharing options...
Greddy82 1st Gear October 14, 2023 Share October 14, 2023 Hi guys. Can I get a review on buying a 2017-2018 used Caren? Issit recommended and any known issues with the GB or car overall? Thanks Link to post Share on other sites More sharing options...
Limws1 1st Gear October 17, 2023 Share October 17, 2023 @Greddy82 Avoid diesel car if you can. Watch Korean car repair videos on YouTube. Search for DPF. 1 Link to post Share on other sites More sharing options...
Lktay Clutched October 17, 2023 Share October 17, 2023 @Greddy82 Pick up power is good for front torque. At this moment, my 2017 carens at 135K mileage still good and FC is about 13~12 km/l, depending on your highway vs urban road(start & stop traffic). No major issues so far , maybe I am just lucky. 1 Link to post Share on other sites More sharing options...
Alvintcs Neutral Newbie November 7, 2023 Share November 7, 2023 Hi, am driving 2018 Kia Carens, managed to resolve DPF issue with fuel additive, but randomly experience jerking while driving, the jerk only occurs randomly while pressing on accelerator. Anyone experiencing the same ? Link to post Share on other sites More sharing options...
Lktay Clutched November 7, 2023 Share November 7, 2023 Hi bro, Last time(5 years back) I had DPF is engine light up and lost power, KM replace it free as under warranty. The engineer told me if drive above 90km/h for 30 minutes, the system will efficiently burn those carbon away. Touch wood so far ok, as I "burnt them" one in a while in Malaysia NS highway. I have used injector cleaner before but not fuel additive, so I not sure if the fuel additive the one causing the jerking unless you have use it before on Kia Carens. If 1st time use, pls check if the fuel additive is suitable for Euro 5 diesel model or you might have to "recycle" your fuel system. Link to post Share on other sites More sharing options...
Limws1 1st Gear November 7, 2023 Share November 7, 2023 @Alvintcs I also have DPF problem currently with my Kia Carens. May I know what fuel additive did you use? I encountered jerkiness when the DPF is regenerating while driving. For my case, it is caused by a faulty particulate matter (PM) sensor. No more jerkiness after replacing the sensor but the DPF problem persists. My DPF problem is caused by a loose intercooler hose causing air leakage which lead to rich fuel air ratio. C&C did not do a good job when they replace the DPF two years ago. So now the DPF has problem which also cause the PM sensor to become faulty. My DPF is only two years old. Link to post Share on other sites More sharing options...
Limws1 1st Gear November 7, 2023 Share November 7, 2023 @Alvintcs I also have DPF problem currently with my Kia Carens. May I know what fuel additive did you use? I encountered jerkiness when the DPF is regenerating while driving. For my case, it is caused by a faulty particulate matter (PM) sensor. No more jerkiness after replacing the sensor but the DPF problem persists. My DPF problem is caused by a loose intercooler hose causing air leakage which lead to rich fuel air ratio. C&C did not do a good job when they replace the DPF two years ago. So now the DPF has problem which also cause the PM sensor to become faulty. My DPF is only two years old. ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator Cap
Radiator Cap
Hyundai Sonata (2015)
2025 Kia EV3
2025 Kia EV3
KIA EV5
KIA EV5
KIA FY24 Carnival - Hybrid
