QQDreamer 4th Gear July 29, 2020 Share July 29, 2020 10 hours ago, AHBA said: Beside the thermostat, is there a possibility the coolant temperature sensor that send signal to dashboard is bad? I had the coolant temperature sensor near the thermostat changed beginning this year there are 2 temp sensor. one near thermostat, the other at the radiator there. so did you changed both or just 1 of them? ↡ Advertisement Link to post Share on other sites More sharing options...
AHBA 2nd Gear July 30, 2020 Share July 30, 2020 20 hours ago, StreamRSZ said: there are 2 temp sensor. one near thermostat, the other at the radiator there. so did you changed both or just 1 of them? I changed only the one near the thermostat Link to post Share on other sites More sharing options...
QQDreamer 4th Gear July 30, 2020 Share July 30, 2020 4 hours ago, AHBA said: I changed only the one near the thermostat is your thermostat original or aftermarket? maybe you can consider replacing the thermostat at the radiator side. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear July 30, 2020 Share July 30, 2020 11 hours ago, StreamRSZ said: is your thermostat original or aftermarket? maybe you can consider replacing the thermostat at the radiator side. sorry i mean temp sensor at the radiator side Link to post Share on other sites More sharing options...
AHBA 2nd Gear August 1, 2020 Share August 1, 2020 On 7/30/2020 at 8:08 PM, StreamRSZ said: is your thermostat original or aftermarket? maybe you can consider replacing the thermostat at the radiator side. OK, will do that. Thanks Link to post Share on other sites More sharing options...
knownothingaboutcars Neutral Newbie October 4, 2020 Share October 4, 2020 On 5/6/2020 at 11:38 AM, Nemesis_lane said: Yup seems all cars. Anyway next problem i am trying to rectify is how to get better full mileage. I suspect it has to do with the tyres. Present using Pirelli P7 tyres on 17inch 255/45 rims. Tyre man said perhaps after 1 year when all tyres are worn out, can consider getting it downsized to 16incg. May see fuel savings though not much. Present ful consumption is 9km/L. 80% city driving. 1.6A, no mods hihi when I took over my fd4A i also had 8-9km/l, but now is around 11.5km/L these are the things i did but i not sure if some of these do help 1. upgraded air intake system 2. used STP ultra cleaner, 1 bottle per full tank, total used 2 bottle 3. Changed new touradors tires(was using primacy 3 before this), i am also using 17/45/225 , 235KPA 4.ceramic additive to my engine oil Hope this helps! Link to post Share on other sites More sharing options...
Confusedboi Supercharged October 13, 2020 Share October 13, 2020 Those on 17 inch tyres that want to downsize can consider going back to 205/55/16 tyres for slightly better FC. Link to post Share on other sites More sharing options...
AHBA 2nd Gear October 31, 2020 Share October 31, 2020 Need help. I am having this weird issue with my battery. It happened 10 days ago. I unlocked the car, opened the door & the instrumental panel lit up as usual. But the car could not start when I turned the key, no cranking sound & the instrumental panel lighting went off. it's just like the battery is dead. I got off the car, closed the door to check on the battery terminals & everything is intact. When I re-opened the door, the instrumental panel lit up again. I quickly inserted the key & turned but couldn't start. Same as the first time. I tried the third time. Closed the door & opened, instrumental panel lit up, inserted the key & it started! Then I noticed the head unit was in reset mode. I wonder how it could be because the battery should be working. I checked the battery voltage via OBD2 & it showed 14.1 with the engine running This problem happened this morning again but I was able to get the engine started at the second attempt. Similar to the first incident, the head unit went into reset mode. I checked the battery & it showed 14.1 to 14.2 What could the problem be? Link to post Share on other sites More sharing options...
Ct3833 Supersonic October 31, 2020 Share October 31, 2020 (edited) 26 minutes ago, AHBA said: Need help. I am having this weird issue with my battery. It happened 10 days ago. I unlocked the car, opened the door & the instrumental panel lit up as usual. But the car could not start when I turned the key, no cranking sound & the instrumental panel lighting went off. it's just like the battery is dead. I got off the car, closed the door to check on the battery terminals & everything is intact. When I re-opened the door, the instrumental panel lit up again. I quickly inserted the key & turned but couldn't start. Same as the first time. I tried the third time. Closed the door & opened, instrumental panel lit up, inserted the key & it started! Then I noticed the head unit was in reset mode. I wonder how it could be because the battery should be working. I checked the battery voltage via OBD2 & it showed 14.1 with the engine running This problem happened this morning again but I was able to get the engine started at the second attempt. Similar to the first incident, the head unit went into reset mode. I checked the battery & it showed 14.1 to 14.2 What could the problem be? Could be the main relay problem . Of course there could be other possibilities. For your reference but don't be blinded by just one possible cause. https://mechanicbase.com/electric/main-relay-symptoms/ Edited October 31, 2020 by Ct3833 Link to post Share on other sites More sharing options...
AHBA 2nd Gear November 2, 2020 Share November 2, 2020 On 10/31/2020 at 12:37 PM, Ct3833 said: Could be the main relay problem . Of course there could be other possibilities. For your reference but don't be blinded by just one possible cause. https://mechanicbase.com/electric/main-relay-symptoms/ Bro thks for the info. Is this main relay refers to PGM-FI Main Relay 1? Or it's something else? Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 2, 2020 Share November 2, 2020 13 hours ago, AHBA said: Bro thks for the info. Is this main relay refers to PGM-FI Main Relay 1? Or it's something else? Yes it is the same but you need to be sure if it is a delay problem or not. It is just one of the possibility. Link to post Share on other sites More sharing options...
AHBA 2nd Gear November 3, 2020 Share November 3, 2020 18 hours ago, Ct3833 said: Yes it is the same but you need to be sure if it is a delay problem or not. It is just one of the possibility. Noted. Thanks bro Link to post Share on other sites More sharing options...
AHBA 2nd Gear November 23, 2020 Share November 23, 2020 Anyone knows any workshop in the West that does repair work on steering pump? I can get the repair kit myself Link to post Share on other sites More sharing options...
Nemesis_lane 1st Gear February 13, 2023 Share February 13, 2023 @Jumpmanz I wanna do roof lining, are you still in contact with e roof lining peeps in pekan nanas? Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear February 13, 2023 Share February 13, 2023 13 hours ago, Nemesis_lane said: @Jumpmanz I wanna do roof lining, are you still in contact with e roof lining peeps in pekan nanas? Yup ah hong is still doing. Shop shifted to just beside the shell station now. I am also going back to ask him to help me wrap some flat bed trolleys. Link to post Share on other sites More sharing options...
Nemesis_lane 1st Gear February 15, 2023 Share February 15, 2023 @Jumpmanz thank you. Is the shop called 'mefa sofa furniture trading'? Planning to do my headliner, rewrap the seats n centre console. Would you happen to have Ah Hong's number or would you know his rates for this ? Link to post Share on other sites More sharing options...
Lomingo_1 Neutral Newbie March 12, 2023 Share March 12, 2023 Hello Honda lovers! I myself understand what it's like - when you can't solve a particular problem with a car for a long time, it starts to infuriate. About the thermostat, man, here https://www.hondacarreview.com/ look for tips. I really love this blog, because it covers a variety of issues on our favorite cars. And in general, sometimes it is useful to keep the pulse on the news about the models of your brand. In any case, save yourself. Link to post Share on other sites More sharing options...
RainbowZhong April 5, 2023 Share April 5, 2023 Hi all! Just want to share on my humble workshop at 3700 Yishun Ring Road, just beside Caltax at Chong Pang. Anyone whom have any car servicing/repair needs please feel free to look for me. Guarantee professional and quality service. Cheers 🙂 Thanks & appreciate for the support! ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
Takata airbag recall
