Kklee
If really want to change, i would suggest to ask for the name of the company for the head unit installer.
Request for a quote from the installer will be better.
Ask BM, later they chop us.
Info sharing on auto lock doors for Toyota cars.. I tried and it works ..
Step #1
Close all the doors.
Make sure your parking brake is on.
Don't do this on an incline especially if your choice requires the car to be shifted into Neutral.
This depends on your key type:
Normal key: Switch ignition to the ON position (2nd position).
Smart key: Turn ignition to the IGNITION ON mode (2nd press of the start button). Do not step on the brakes or your car will start!
REMINDER! Step #2 has to be done within 10 seconds of doing step #1!
Step #Option==============================Shift to=====Door lock switch to
1 Lock immediately when shifting out of Park=======P=============Lock======
2 Unlock immediately when shifting into Park=======P============Unlock=====
3 Lock when vehicle speed is about 20kpn=========N=============Lock=====
4 Unlock based on driver side door===============N============Unlock====
Shift the gear lever to either P or N.
If you're already in the correct shift option, you don't need to change it. So if it says above you need to shift to P, and you're already in P, leave it. Same for N. Of course, if you're in P and need to shift to N, do it (step on the brakes to shift!).
Press the driver side door lock switch to your choice for 5 seconds.
Release after 5 seconds.
If You're Successful
If you're successful, all doors will lock then unlock. This is the signal that the setting has been turned on OR off. Yes this is horrible. The only way to know if the setting is correctly set is to try it out. This is a problem for Option #3 as it means you have to actually drive.
Mine already have step 3 activated. Can I activate step 2 without doing step 1? just want to unlock when at park position.
I think you have misunderstood the steps. After you have done on the follow steps
Step #1
Within 10 seconds choose the 4 steps that you intend to have.
Step #1
option 3 (Lock when vehicle speed is about 20km/h) already activated . Trying to activate option 2 (Unlock immediately when shifting into Park).
Done as instruction, still cannot activate option 2 [confused]
330? u buy from authorized dealer?
I think i buy iroad v7 too....seem good.
authorized dealer. 1yr warranty. any probs go back to him.
it's good enough for my usage.
if power on button, press twice. no foot brakes applied.
within 10secs, switch to appropriate gear: N. press brake if gear doesn't move. then hold unlock key (which is the all lock/unlock key on driver's side) for 5 secs. let go.
you will hear a reaction from all four locks. done.
my thanks to junye11 for the info, cos i pressed 10secs initially like in other models, nothing worked.
workshop heard instructions wrongly, locked doors once out of P position. to undo, just repeat procedure for the particular option again.
To all bros here. May I know whats the popular settings among bros here for lock and unlock. Thanks.
1. Lock when after 20km/h, Unlock when shift to P.
2. Lock when after 20km/h, Manually Unlock.
3. Lock when shift out of P, Unlock when shift to P.
4. Lock when shift out of P, Manually Unlock.
Default is what huh?
Default is good when travel to Malaysia - always locked.
Default is as follow:
1. Lock when after 20km/h, Manually Unlock.
Yeah, this is the best for me.
You joker ah..
If you dunno what's default, then how can you say it's good.
But you are right. Default is good esp in Malaysia - always locked.
You joker ah..
Just to clarify mah. [laugh]
Using this setting. Lock when after 20km/h, Unlock when shift to P.
Can share which shop?
Thanks.
Hi all can check the ECO Indicator On or Off the car got feel different ? Like more power when Eco indicator is switch to off ?
anyone has a picture of how the back of the old HU (panasonic variant) looks like? Can share here?
have been busy with work (i've a life to deal with), and need to go into storage boxes to take HU out. hence don't expect immediate response.
here's the pics.
from my avatar, can see i park in MSCP.
any fellow drivers cold start and drive off, up and down ramp in MSCP, can hear a faint hum/groan in the steering? a lil louder than the tyre sound and engine noise.
seems to me is the steering box. SE say they use electric motor and no more hydraulic.
after use for an hr or two, or maybe due to environment noise, the sound went away.
any ideas?
