Advancer 3rd Gear February 22, 2015 Share February 22, 2015 Hi one of my car tire cannot be charged, suspect the charging valve is stuck.What should I do? Can the valve be replaced or must I change tire? ↡ Advertisement Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic February 22, 2015 Share February 22, 2015 Tyre cannot charge one They only can be pumped. 5 Link to post Share on other sites More sharing options...
Shibadog Turbocharged February 22, 2015 Share February 22, 2015 Hi one of my car tire cannot be charged, suspect the charging valve is stuck. What should I do? Can the valve be replaced or must I change tire? valve can be changed. 2 Link to post Share on other sites More sharing options...
Wolfy3769 2nd Gear February 22, 2015 Share February 22, 2015 go to a tire shop to resolve... maybe need to change the valve... this is safer.. any problem, the tire shop will be able to resolve... rather than u do it in a carpark and end with a flat tire.. 2 Link to post Share on other sites More sharing options...
Advancer 3rd Gear February 22, 2015 Author Share February 22, 2015 Would it be expensive just to change the valve? Changing car in 2 weeks, don't wanna spend too much money on this old car. 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic February 22, 2015 Share February 22, 2015 Would it be expensive just to change the valve? Changing car in 2 weeks, don't wanna spend too much money on this old car. I see you are very kancheong! Opening 2 threads! I paid $10 for the valve recently! 1 Link to post Share on other sites More sharing options...
Advancer 3rd Gear February 22, 2015 Author Share February 22, 2015 I see you are very kancheong! Opening 2 threads! I paid $10 for the valve recently! Yes paiseh. Was afraid either forum is inactive. Thanks for the response, will visit a tire shop later. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 22, 2015 Share February 22, 2015 Hi one of my car tire cannot be charged, suspect the charging valve is stuck. What should I do? Can the valve be replaced or must I change tire? The one-way check valve that is screwed into the tubless valve stem may have a fault or sized spring due to water or dirts. The check valve can be easily removed with s simple 4 way tyre tool. 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic February 22, 2015 Share February 22, 2015 Yes paiseh. Was afraid either forum is inactive. Thanks for the response, will visit a tire shop later. No problem. Hope you can resolve your problem soon. Link to post Share on other sites More sharing options...
lausai88 Hypersonic February 22, 2015 Share February 22, 2015 Tyre cannot charge one They only can be pumped. lol Link to post Share on other sites More sharing options...
Eyke Supercharged February 22, 2015 Share February 22, 2015 Tyre cannot charge one They only can be pumped. Tyre cannot pump one. They only can be inflated. 5 Link to post Share on other sites More sharing options...
Pocus Turbocharged February 22, 2015 Share February 22, 2015 Valves are cheap, around 10+ don't worry. Link to post Share on other sites More sharing options...
Forte3737 5th Gear February 22, 2015 Share February 22, 2015 Hi one of my car tire cannot be charged, suspect the charging valve is stuck. What should I do? Can the valve be replaced or must I change tire? Your English standard until primary 6 is it? 2 Link to post Share on other sites More sharing options...
Advancer 3rd Gear February 22, 2015 Author Share February 22, 2015 (edited) Your English standard until primary 6 is it?Hi is it necessary to make fun of people like this?I am using charging because I use the term at my work when we charge the aircraft tire. I don't think its wrong. You can go read up the dictionary, charge can also mean to fill(air, water, etc). Edited February 22, 2015 by Advancer 7 Link to post Share on other sites More sharing options...
lausai88 Hypersonic February 22, 2015 Share February 22, 2015 Hi is it necessary to make fun of people like this? I am using charging because I use the term at my work when we charge the aircraft tire. I don't think its wrong. this is just a forum, take it easy man. Just ignore the comments. Happy CNY 5 Link to post Share on other sites More sharing options...
Forte3737 5th Gear February 22, 2015 Share February 22, 2015 Sure. Hi is it necessary to make fun of people like this?I am using charging because I use the term at my work when we charge the aircraft tire. I don't think its wrong.You can go read up the dictionary, charge can also mean to fill(air, water, etc). Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic February 22, 2015 Share February 22, 2015 (edited) Hi is it necessary to make fun of people like this? I am using charging because I use the term at my work when we charge the aircraft tire. I don't think its wrong. You can go read up the dictionary, charge can also mean to fill(air, water, etc). Not make fun but trying to let you know for car tyre, we normally call it pump or inflate tyre. No offense, happy CNY Edited February 22, 2015 by Thaiyotakamli Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 22, 2015 Share February 22, 2015 (edited) Valves are cheap, around 10+ don't worry. The tubless stem and valve is dirt cheap, the cost of s$10.00 is more for labour in removing the wheel from the car and removing the tyre from the rim using a tyre changing machine. If they use this simple tyre valve tool they could easily make much more profit from labour time saving. Edited February 22, 2015 by Yeobh ↡ Advertisement Link to post Share on other sites More sharing options...
Nearly 2,000 HDB car parks to have at least 3 EV charging points each by 2025
Tyre puncture
Tyre puncture
Tourador Tyres
Tourador Tyres
Recommended Tyres for EVs by Experience
