Kippei 3rd Gear February 17, 2015 Share February 17, 2015 Has anyone experience hard shifting esp 1 - 2 when the transmission is cold during the morning. When it warm up, it then shift smoothly. It is normal? ↡ Advertisement Link to post Share on other sites More sharing options...
Jamesc Hypersonic February 17, 2015 Share February 17, 2015 Has anyone experience hard shifting esp 1 - 2 when the transmission is cold during the morning. When it warm up, it then shift smoothly. It is normal? Yes, just let it warm up first. 6 Link to post Share on other sites More sharing options...
Kippei 3rd Gear February 17, 2015 Author Share February 17, 2015 ok :) I thought my transmission haywire liao Link to post Share on other sites More sharing options...
Fcw75 Hypersonic February 17, 2015 Share February 17, 2015 Got change transmission oil before? Link to post Share on other sites More sharing options...
Aaronlkl Supersonic February 17, 2015 Share February 17, 2015 Has anyone experience hard shifting esp 1 - 2 when the transmission is cold during the morning. When it warm up, it then shift smoothly. It is normal? Your ride manual or auto? 7 Link to post Share on other sites More sharing options...
Bicolor 5th Gear February 17, 2015 Share February 17, 2015 Your ride manual or auto? Haha, you probably missed his topic title - "Hard-shifting when auto transmission is cold" 1 Link to post Share on other sites More sharing options...
Bicolor 5th Gear February 17, 2015 Share February 17, 2015 Has anyone experience hard shifting esp 1 - 2 when the transmission is cold during the morning. When it warm up, it then shift smoothly. It is normal? I recall you posted a similar topic on this before, where one workshop apparently under-filled your ATF when you did a change. You also mentioned it was better after topping up. So it's starting again now? Was the ATF you changed to the correct specification for your car? If the jerk is really annoying you can first try doing a drain and fill, with either the correct OEM spec ATF or a good quality synthetic one. The hard shift seems quite common on many auto cars I've driven so far, and on some of the cars in my care I found that doing a drain and fill with a good quality synthetic ATF can do wonders sometimes, or at least significantly reduce the jerk and smoothen out shifts. If after doing so, the problem still persists, you may want to get it checked out at a workshop which specializes in automatic transmissions. Not all gearbox problems mean you have to get the entire gearbox changed, sometimes it's just something as minor as the TCM or valve body. Link to post Share on other sites More sharing options...
Aaronlkl Supersonic February 17, 2015 Share February 17, 2015 Haha, you probably missed his topic title - "Hard-shifting when auto transmission is cold" Oh ya.. lol 7 Link to post Share on other sites More sharing options...
Detach8 5th Gear February 17, 2015 Share February 17, 2015 (edited) Sometimes hard shifting could be caused by insufficient or wrong pressure build up in the transmission. What I do with my old Nissan is that after I start the engine, I hold on the brakes and put the car in reverse - "R". Note we usually reverse-park in Singapore, so the reverse gear is almost always engaged when the tranny is warm and as a result suffer less wear than the first or second forward gear, unlike other countries where people park head-in (or if you live in a landed estate). I leave it in "R" for a few seconds while holding on to the brakes just to let the transmission build pressure, before shifting into "D". Then it shifts normally from thereon. Edited February 17, 2015 by Detach8 1 Link to post Share on other sites More sharing options...
Kippei 3rd Gear April 9, 2015 Author Share April 9, 2015 Just an update Feeling with nothing to lose i bought this http://www.amazon.com/Lubegard-60902-Automatic-Transmission-Protectant/dp/B0007ZAJRM/ref=cm_cr_pr_product_top?ie=UTF8 Now there is no more hard shifting in the morning. Link to post Share on other sites More sharing options...
Warthog Clutched April 9, 2015 Share April 9, 2015 I don't think you can solve this problem by changing to a better transmission oil fluid. Link to post Share on other sites More sharing options...
Kippei 3rd Gear April 9, 2015 Author Share April 9, 2015 Anyway i have nothing to lose before I opt for a $2xx transmission filter change and flush. At least at this point of time, i can conclude the valve is not the main cause of issue here. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
Crazy weather in Singapore ?
Car air-con
Car air-con
Car inspection questions
